Question about Dishwashers
Hobart amx 16
What is fault U L please ?
    Top Expert:
  • Dishwashers Master
  • 12,223 Answers
This error code:UL definitely means the unit is out of balance so make sure that the 4 rods with shock springs are connected and holding the tub up. If those check good then you probably have a bad RPS sensor. This is the part that senses the tubs movement clipped onto the stator motor itself and it tries to even out the shaking so that the unit doesn't move much. You can't repair this part so it would just need to be replaced.
God bless you
Posted on Jul 31, 2013
4 Suggested Answers
bigg t
  • 640 Answers
SOURCE: bof error hobart amx
Sorry so late for the reply.Im a hobart tech and i dont recall this model of your unit,are you sure the model isnt a am-14 or am-15?
Posted on Aug 24, 2008
SOURCE: hobart amx/aux-s dishwasher "bof" error code
press the 1st and third buttons on the display nxt to the start button then press the start button,this will change the the display to something like BOF1 then allow the achine to fill the rinse tank you will know when this has happened as the display will go out (all of it) then you can turn on the machine using the button marked with a I the start button will light red allow it to go green and you are ready to go ... if when you are boffing it it changes to FIL the your water pressure is to low good luc fella
Posted on Mar 04, 2009
vahai2004har
SOURCE: looking for a hobart amx dishwasher wiring diagram
sr. we are using Hobart dish /w but not working this properly .when i start d/w display red light coming but not green light also heater working water coming can you help me
Posted on Jan 15, 2012
Hobart glass wash machine AMX-GH wash with normal temperature but do not advance to rinse cycle
Can you describe the sequence of operation?
Fill ok?
Booster or tank heating ok?
wash pump running ok?
Sep 28, 2016 | Hobart Underbar Glass Washer
Hobart glass wash machine amx-gh continue washing does not advance to the rinse cycle with no error code
only a suggestion is it heating up what i remember it want move on until it heats up to it's working temperature, good luck
Sep 22, 2016 | Hobart Dishwashers
Hi I have a Hobart amx-16 quite an old machine now... when I pull down hood to start cycle, indicator comes up FIL.... during its cycle.... any advice please? Is there a reset function
This sounds like the dishwasher's filter might be clogged. It should be located under the bottom dish rack. It's fairly easy to disassemble. Just remove it and clean it out. Also, check under the filter to make sure there isn't any more debris and/or lime deposits there as well.
I hope this helps! :)
Jun 11, 2014 | Dishwashers
Bof fault code
The display of "BoF" on the display is simply a confirmation code to commence the next operation on the dishwasher. It is not a fault code.
Refer manual of a AMX model Hobart dishwasher. If your model is different the general codes are same.
http://www.dishwashers-direct.com/uploads/Operating%20instructions/Hobart/AMX%20RANGE%20OP%20MANUAL.pdf
Apr 19, 2014 | Hobart Dishwashers
Dishwaher hobart amx 900-16 has fil displayed what does this mean?
fil massage mean the water not came in the booster tank , maybe the water pressure is low or the solenoid valve is defective, always this massage come to me i change solenoid valve then it will work, check and tell me
May 12, 2012 | Dishwashers
Hi on one of our offshore rigs we have a AMX-16 dishwasher we require a parts manual for this machine so that we can order a new bottom spray bar we would also like to have a user manual for this machine
Hi rrydlewicz
I am on the Total Dunbar in the North sea Northern sector. I have an intermittent fault code problem I would like to solve, did you ever get hold of a manual for the Hobart dishwasher?
Drop me a line at colburn1@hotmail.com
Cheers mate
CBD. Elect tech
Mar 11, 2010 | Hobart AM14-253 Free-standing Dishwasher
Looking for a hobart amx dishwasher wiring diagram from 3 phase converting to single phase
Jun 04, 2009 | Hobart Dishwashers
Bof error hobart amx
Aug 16, 2008 | Dishwashers
Hobart amx/aux-s dishwasher "bof" error code
Mar 13, 2008 | Dishwashers
Dishwashers Logo
83 people viewed this question
Top Dishwashers Experts
Owen Barnes
