Question about Ryobi Rht-2660DA Quik Fire Hedge Trimmer 26Cc
Fix Ryobi RHT2660DA hedge trimmer will not start
boscia
  • 163 Answers
SOURCE: add on hedge trimmer ryobi weed eater
I use a dremel with a sharpening stone, if u don't have one you can also use a power drill with a small sanding disk (1 inch) and course sand paper (30 or 40 grit). or you can use a bastard file. its too tight to use any kind of angle guide so just take your time and do it by eye. it shouldn't take much to get them sharp enough to do the job, over-sharpening is unnecessary and dangerous, and will make the blades dull faster. sharpen all the free blades, top and bottom, then start the trimmers to advance the blades to free up the sides you couldn't get. i use a light penetrating oil to clean the blades first, then lithium grease spray to lubricate.
Posted on Nov 28, 2008
  • 3 Answers
SOURCE: what is the gas & oil mixture for ryobi 26cc 22in hedge trimmer
If it is a 2 stroke engine, a 50:1 ratio should work. That's 50 parts gas to 1 part oil.
Posted on Dec 14, 2008
SOURCE: Ryobi 18V Hedge Trimmer Blade Question
Just buy a file and push 3 or 4 down strokes down the same slope of the cutter toward the sharp edge. Never file on the flat top of the cutter, only on the slope. Support the frame using a saw horse or pick-up bed. The support makes the file cut the metal better. You can do the same thing with chain saws. You just need the file that fits the cutter. You just hold a consistant angle and count out the same number of strokes. Also, clean out junk between the moving parts, tighten any loose screws, and drop a few drops of 3 in 1 oil between the moving parts. Having things sharpened at a shop is inconvenient and expensive.
Posted on May 24, 2009
  • 32 Answers
SOURCE: I have a model # RY39500 ryobi hedge trimmer 2
Sounds like the air screws need adjusted on the carburator. If there are 2 the one with the L above needs to be turned althe way to the right but not to tight and then backed out 1/2 turn to left. The one with the H anove it do the same except back it out 1 and 1/4 turns to left. If it only has 1 screw dot he same but back out 2 complete turns. Hope this helps?
Ralph at woodworking57@hotmail.com
Posted on Sep 15, 2009
Testimonial: "Thank you, worked great!"
SOURCE: Hedge trimmer starts fine then stops after 5 minutes
Carburetor high speed adjustment ( screw nearest the filter ) open ( counterclockwise ) 1/2 turn.
Adjust again as needed to run when hot.
make sure the gas mixture ratio is as required.
Henry
Posted on Sep 22, 2009
I just acquired a Ryobi HT 26 HedgeTrimmer. It starts , runs fine. But the blades don't run... Where do I start?
Have you lubricated the blades?
Could be a gear box problem.
Here's a link to the breakdown of what I hope your machine is.
http://www.magic-parts.co.uk/acatalog/Ryobi-RHT2660DA.PHP
May 22, 2016 | Ryobi Garden
Two stroke ratio calculator
If you are referring to the fuel mixture, it is 50:1. So for one gallon of gas, use 2.56 oz. ( US measure) of two stroke oil. Gas Oil Mixture Ratio Calculator
Jun 30, 2014 | Garden
I need a manual for a Ryobi RHT500R Electric Hedge Trimmer 500 Watt - 55cm
I found the manual for the Ryobi hedge trimmer here: fr.ryobitools.eu/local/uploaded/catalog/e_RHT500R-600RL_UM_UK_v1.pdf . The bolts you describe hold the blade to the hedge trimmer's motor. They shouldn't have come loose. However you can check if any of the bolts are loose or have backed out of the motor.
I would suspect either a part of the branch is stuck between the blades. I have one of the small edge trimmer which gets noisy when I get a woody weed stuck in the unit. Unplug the trimmer and look at the blade for some bark stuck between the layers. On each side there are multiple blades that overlap at parts of the cutting cycle.
A parts diagram for the RHT500R is available here: http://www.magic-parts.co.uk/acatalog/Ryobi_RHT500R.php .
II hope this helps.
Aug 23, 2012 | Ryobi Garden
Got the new Ryobi RHT2660DA petrol hedge trimmer today. Have mixed fuel to instructions and followed every step to the letter. It starts fine, but keeps stopping when I excelerate it, any ideas?
It is running too lean on the mixture, if it was new return it for re tuning, it will be an easy fix which will only take a few minutes.
Jan 21, 2011 | Ryobi Garden
When in operation the Ryobi S430 string trimmer leaks oil continuously. How can I fix this problem?
Ryobi told me the unit can't have the s430 trimmer bottom end raised higher than the engine at any time, or it will leak. Apparently they released a product to compete with other companies for cheap 4 cycle trimmers without much care for the end user.
Nov 29, 2010 | Ryobi Factory-Reconditioned 30cc 18" Gas...
Ryobi rht2660da hedge trimmer starts but will not rev fully and cuts out on full throttle thisproduct is brand new
If it brand new take it back to where you bought it, it's probably still under warranty. Why try to fix something you don't need to???
Aug 30, 2010 | Garden
I have a ryobi hedge trimmer p2601 and the plastic handle broke. Is there a way to get a stronger handle or just a replacement?
May 29, 2010 | Ryobi 18V Hedge Trimmer
Cant start ryobi 890r brushcutter
My Ryobi 890r brush cutter will start and then die
May 16, 2010 | Ryobi Factory-Reconditioned 30cc 18" Gas...
Henry
Sep 20, 2009 | Ryobi Factory-Reconditioned 30cc 18" Gas...
Ryobi Rht-2660DA Quik Fire Hedge Trimmer 26Cc Logo
160 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
