Question about Advent Modena M101
No power in my laptop. I press power button and only see red battery light for few seconds.
    Top Expert:
  • 12,223 Answers
Please measure the output voltage from the adapter , see the label printed in your adaptor if the voltage read with the exactly voltage: exampe label printed: 17.8, and you measure 17.8 the adaptor is o.k
If do not the adaptor is faulty. repair or replace
However you must try with the battery to Start, of course the battery must be charged in full, if the battery is o.k the laptop will be on. If not the power supply inside is faulty. REPAIR.
God bless you
Posted on Jul 31, 2013
Packard Bell Easynote Laptop MV35-V-007. How do i get the laptop to power on.
Press and hold the power button. It may take a few seconds.
May 06, 2016 | Computers & Internet
No power. I press power button and only see red battery light for few seconds and nothing, No power
measure the output from adaptor example if the label printer says:17,8vdc, you will measure the exaclty 17,8 if do not , the adaptor is faulty. However the comuter must be run with the battery, of course must be full in charge. If does is o.k If it NOT , the power supply inside is faulty.repair
God bless you
Jul 30, 2013 | Advent Modena M101
Toshiba Satellite laptop will not boot. Shows power from outlet and battery but no indicator light is present for the last two in the five light sequence.
Its an old trick that got my Dell laptop working
Unplug the laptop remove the battery press the power button,...nothing will happen, wait a few seconds put battery back in laptop plug it in hold upside down press power button until it boots
If that doesn't work it could be a bad/loose/dead bios battery What is the model of the laptop?
May 11, 2011 | Toshiba Computers & Internet
Remotes will not sync with console
Hi there, this information comes straight from Nintendo's website. Anything I'd be typing would basically be repeating what comes from Nintendo directly:
Turn the Wii console power OFF by pressing the POWER Button on the front of the console. Unplug the power cord from the wall outlet for a few seconds. After a few seconds have elapsed, plug the cord back into the wall outlet.
Turn the power of the Wii console ON. When you see the Health and Safety screen, open the small flap on the front of the Wii console to find a red button labeled "SYNC." Press and hold the SYNC Button down for 15 seconds. This will clear all the syncs on the Wii, allowing you to get a clean start to begin the process described below.
After holding the SYNC Button on the Wii console down for at least 15 seconds, you can now "re-sync" your Wii Remotes:
With the first Wii Remote you wish to sync, remove the battery cover on the back of the Wii Remote to find a small red button just below the batteries.
Press and release the small red button just below the batteries on the Wii Remote; the blue lights on the front of the Wii Remote will blink.
Quickly press and release the red SYNC button on the inside of the white flap on the front of the Wii console (picture).
When the Player LED blinking stops and stays lit, the syncing is complete. The LED that is illuminated indicates the player number (1 through 4).
May 03, 2011 | Nintendo Wii Console
Will not power up. Green light on power source
Red battery light means battery is charging. It should start up even if battery is low. Try pressing on the area above and to the right of the power button, while you are pressing the actual power button.
May 13, 2010 | Acer Aspire 9500 Notebook
Laptop won't turn on
try separating the laptops battery for 8 Hrs to let the mother board discharge and cleaning the mother board and memory slots and cpu socket with the air blower
Mar 21, 2010 | Office Equipment & Supplies
Gateway M-6862 laptop will not turn on; battery light flashing re
Seems to be a problem of not enough power.
First check the voltage output of the charger(adapter) and match it with its specs.
Also try to reset the hardware using the following steps:
1 Disconnect battery and the charger
2 Let it sit for 1-2 minutes.
3 Press and hold down the power button for 30 seconds.
4 Reconnect battery and charger and try to start by pressing the power button.
Mar 07, 2010 | Gateway Computers & Internet
Laptop will not boot
ok, take the battery out and leave it unplugged for a few hours.  Only plug the ac adapter in after.  Press and hold the power button for 10 seconds.  Does it still do it?  If it does work, then chances are your mobo has bit the dust or you have knocked loose an internal charging part.
Mar 09, 2009 | Compaq Evo N410C Notebook
Will not power on
Unplug it; pull out the battery; with the battery out of the laptop, press the power button for a few seconds; let it sit for a few minutes. Then reinstall the battery and see if it powers up. This method doesn't always work but I've seen it work on more than one occasion.
Feb 26, 2009 | HP Pavilion DV6700Z Notebook
Wii fit
Have had this problem before with wii sports. What I did was turn off the wii console and unplug from the power, leave for a few seconds then turn it back on when the health & safety screen comes up
  1. Turn the Wii console power OFF by pressing the POWER Button on the front of the console. Unplug the power cord from the wall outlet for a few seconds. After a few seconds have elapsed, plug the cord back into the wall outlet.
  2. Turn the power of the Wii console ON. When you see the Health and Safety screen, open the small flap on the front of the Wii console to find a red button labeled "SYNC." Press and hold the SYNC Button down for 15 seconds. This will clear all the syncs on the Wii, allowing you to get a clean start to begin the process described below.
  3. After holding the SYNC Button on the Wii console down for at least 15 seconds, you can now "re-sync" your Wii Remotes:
  4. With the first Wii Remote you wish to sync, remove the battery cover on the back of the Wii Remote to find a small red button just below the batteries.
  5. Press and release the small red button just below the batteries on the Wii Remote; the blue lights on the front of the Wii Remote will blink.
  6. Quickly press and release the red SYNC button on the inside of the white flap on the front of the Wii console (picture).
  7. When the Player LED blinking stops and stays lit, the syncing is complete. The LED that is illuminated indicates the player number (1 through 4).
Jun 23, 2008 | Nintendo Wii Console
Advent Modena M101 Logo
54 people viewed this question
Top Advent Computers & Internet Experts
Lee Durbin
Lee Durbin
Computer Links
Are you an Advent Computer and Internet Expert? Answer questions, earn points and help others
