Question about Toro 42 In 22 Hp Kawasaki Vtwin Hydrostatic Zero Turn Tractor
When pulling levers together the lawnmower stalls out. Tried everything from letting it warm up to shifting weight on seat. Help.... very frustrating....
Try turning the emergency brake off. If you move the arms in on my bad boy mower with the brake on the mower will die.
Posted on Jul 31, 2013
Yamaha TDM 850 engine dies when clutch lever is released
Hi, Marcus the ignition circuit cut-off system comprising of the side stand switch, clutch switch and neutral switch has the following functions:
a. It prevents starting when the transmission is in gear and the side stand is up, but the clutch lever is not pulled.
b. It prevents starting when the transmission is in gear and the clutch lever is pulled, but the side stand is still down.
c. It cuts the running engine when the transmission is in gear and the side stand is moved down.
Periodically check the operation of the ignition circuit cut-off system according to the following tests.
With the engine turned off:
1. Move the side stand down.
2. Make sure that the engine stop switch is set to "RUN"
3. Turn the key to "ON".
4. Shift the transmission into the neutral position.
5. Push the start switch if the engine does not start the neutral switch may be faulty.
With the engine still running:
6. Move the side stand up.
7. Keep the clutch lever pulled.
8. Shift the transmission into gear.
9. Move the side stand down if the engine does not stall you may have a faulty side stand switch.
After the engine has stalled:
10. Move the side stand up.
11. Keep the clutch lever pulled.
12. Push the start switch if the engine does not start you may have a faulty clutch switch.
This check is most reliable if performed with a warmed-up engine.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Stalls When Release The Clutch Lever
The 1299 Engine dies when pulling the clutch lever in
Yamaha TDM850 1996 Service Manual
OEM parts for Yamaha
YAMAHA TDM850 Owner Manual
Aug 18, 2017 | 1994 Yamaha TDM 850
How to start a ryobi200blower blower 200
First , prime the priming bulb about 4 x...
Next put the choke lever in full choke position
Give a couple slow pulls, then a good strong pull...
(The unit should burp, run for a second)
Next put the choke lever in the half choke position
Pull rope
It should start and run, now put the choke lever all the way in the off position and let unit warm up a minute... if when you turn choke off it stalls out, u didn't warm it up enough...
Oct 10, 2015 | Garden
1994 Polaris 300 4x4 want shift into high range just grinds
Bad linkage between shift lever and the transmission.
Apr 07, 2015 | ATVs
1800 vtx stalls after clutch released
Hi, Anonymous the ignition circuit cut-off system comprising of the side stand switch, clutch switch and neutral switch has the following functions:
Bike stalls when letting out clutch
Bike only starts in neutral and Dies when put in gear
Honda VTX1800R Owner Manual service manual not owners
http://www.partsfish.com/page/oem-parts-for-honda
Honda VTX1800C Owner Manual
Jan 20, 2014 | 2006 Honda VTX 1800R Spec 3
Toro 4200 time cutter stalls when the handles are pulled in
I believe the timecutter has a safety switch that only allows the unit to start with handles in the out position, then you need to be on the seat to be able to pull handles in without stalling engine. Have you tried checking the seat switch? It sounds like one of your safety switches isn't working. Either the seat switch or the handle switches. That's where I would look first. Good luck!
Oct 24, 2013 | Briggs & Stratton Briggs Stratton...
I have a 2002 honda vt600c bought it from a guy that I watched ride it but after it sat over winter the clutch doesnt seem to work ..shift into 1st and it kills bike. any ajustments I can make or do
Sounds like the clutch plates may be stuck together. Happened to me after a long trip in the rain and bike sat for a few weeks after that. Had to take the cluch discs out and clean them
Mar 25, 2012 | 2004 Honda VT 600 C Shadow
Yamaha Radian stalling
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Re dies when put in gear Road Star Forum Yamaha Road Star
Bike dies when put it in gear plz help
Yamaha YX600 Service Manual
http://www.badrad600.com/Radian%20Manuals%20-%20Complete%20-%20Printable/Radian%20Owner's%20Manual%20Clean%20Complete%20Final.pdf
Mar 25, 2012 | 1987 Yamaha YX 600 Radian
Coupling is stuck / sticks together
Is the bike shooting forward while you have the clutch lever pulled in or when you let it out? If it's when you let it out you have to do it slower and roll on the accelerator so that it doesn't stall. If you have the clutch lever all of the way in and it shoots forward you may need to see a mechanic... I'm sorry if this doesn't help much.
Nov 20, 2008 | 1977 BMW R 75-7
Nov 10, 2008 | 1977 BMW R 75-7
Toro 42 In 22 Hp Kawasaki Vtwin Hydrostatic Zero Turn Tractor Logo
160 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
