Question about Beverage-Air Refrigerators
I have a sp48-08 beverage air. I cleaned the entire unit. evap/ condensor and fans. Temp will not go down 47 degrees. What is the possible problem?
    Sergeant:
  • 308 Answers
Sounds like your temp sensors are out of range or your unit is stuck in defrost? But before you go there check your gasket make sure it is sealing all the way around.
Posted on Jul 30, 2013
SolutionGuy
  • 331 Answers
SOURCE: bev air cooler
Bill, the main reason I've noticed for higher than normal temps in these boxes is filthy condenser coils (this will affect pressures in your sealed system). Remove the front lower panel and inspect your coils. Use a coil brush or a dust broom to thoroughly clean them up, don't use water. You can also pick up some condenser coil cleaner in a spray can from your local appliance parts store, but it's not necessary (the fumes are strong and may be objectionable to your customers... it gets 'em really clean, though!) After cleaning the coils, allow 24 hours for temps to stabilize. If they don't, here is a site for Beverage-Air, contact your local servicer with you exact model and serial number for pressure specifications. http://www.beverage-air.com/technical.service.html Hope this helps! Let us know, will ya?
Posted on Aug 13, 2007
watugot
  • 290 Answers
SOURCE: kenmore 5022 please help
Do you have a heavy frost on the rear panel of the freezer section? If so, you have a defrost system problem. If you will post the complete model number I can help you diagnose which part you need to fix it. In the meantime, you can manually defrost it and it will work for about a week or so until the frost builds back up.
Posted on Oct 20, 2007
  • 135 Answers
SOURCE: no cooling
I'm not a real expert in this field, but I might as well try to help, worst case is this doesn't help you. You should try checking if the condenser and the compressor are running.
Posted on Jan 06, 2008
22yooper
  • 828 Answers
SOURCE: KENMORE TRIO 2004 59675523400 REEFER/FREEZER NOT COOLING
It is the compressor that has failed. The hum is it trying to start and the following click is the overload protector opening. What is the temperature where the refrigerator is located? Allow the compressor to cool down before trying to restart it. If it still does not restart after it has cooled off it is done.
Posted on Jun 03, 2008
aaronbeth
  • 110 Answers
SOURCE: I have a Beverage Air
You'll need to check the back-pressure on the low-side of the system, you have a faulty compressor. If there is a condenser fan motor make sure it is running when the compressor is on.
Posted on Jan 28, 2011
Error code e3
This often happens when the evaporator freezes up. The freezing temp is not normal and the frost sensor causes an error code. You should open the unit and clean the evap and condensor thoroughly. Let it thaw out if its frozen with ice. Drain the unit. Clean the evap thoroughly. Reasemble and run in fan mode to let the unit dry out. This should fix it 90% of the time. Rarely there will be an actual problem with the sensor in the rear of the unit, you can check the wires leading to the sensor when you have it open for cleaning - sometimes they will be broken when you remove and replace the filter.
Jul 30, 2012 | Windchaser PAC9 Air Conditioner
Beverage Air. Model: CFG24-1. The evaporator fan motor does not turn while unit is operating. The entire condensing unit is working, except the evaporator fan motor. When I removed the evaporator fan motor...
http://beverage-air.com/pdf/manualsbycategory/K%20Series%20-%20Bottom%20Mount%20Reach-Ins/CFG_CRG_KF_Series809-046A.pdf
The fan has a limit control wired in series that shuts the fan down until the coil temperature reaches 25*F. this prevents the fan from blowing warm around after defrost.
There is also a switch which is placed for the door to close. Either one may be defective.
Worst case is the freezer is not pulling down temperature wise.
Jan 19, 2011 | Beverage-Air CFG24 Freezer
Rv ac throws the breaker when outside temp gets high, unit works fine at night when outside temp cools down
Clean evap and cond coils
Place hand on a/c if too hot during the day but cool at night
then freon is being restricted in the condensor
Cleaning coils may help days
Put a trickle of water on the condensor during the day for a test.
.If this was helpful please rate me.
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Aug 07, 2010 | Dometic Rooftop RV Air Conditioner
The outside unit will work only briefly and bring the temp. down about 1 degree in 2 hours of running. Then the outside unit turns off for at least 2 to 3 hours.
Does the outside unit completley shutoff or does the
condensor fan keep on operating? If this is the case
the compressor could be overheating and shutting down. Try washing the condensor from inside out.
If you can read electrical diagram on the back of the
condensor electrical panel check to see if it has a
high pressure switch, if this is the case it probably
is cycling off this switch. Wash the Condensor and make sure the fan is operating.
If the big insulated line does not feel cool after 15 min. of operation you could be low on freon.
Jun 12, 2010 | Carrier 38CKC042 Air Conditioner
Beverage-Air Kegerator Not Staying Cold
It can take a very long time to get a keg of beer down in temperature. The heat transfer from a keg is slow due to the lack of air circulation inside the keg. You should also check your condenser coils, make sure they are clean. Door gasket should also be in good repair. Hope this helps.
Jan 20, 2009 | Beverage-Air Kegerator - Beer Keg Cooler...
Unit not freezing , evaporator fan wont run
If this is a Bev-Air, don't think the door switch will control the fan. At the evap, there is a temp sensor called a fan delay. When unit goes into defrost mode, this warms up. Some also serve a dual purpose. It will terminate the defrost cycle at a certain temp., say 51 degrees or so, at the evap. Anyway, when unit comes out of defrost, it keeps the fan off so it allows the evap to cool quicker and to prevent circulating warm air. This could be your problem. Not a hard fix but they can be a pain sometimes. Outside chance that the unit is low on refrigerant (freon). This will not let the evap get cold enough to trip the sensor back into position to turn the fan on. Good Luck. Restaurant Parts and More carry alot of Bev-Air stuff. 1-888-814-1110. Ask for Rick
Oct 09, 2008 | Beverage-Air 23.1 cu. ft. / 654 liter...
GE model TFX22R ice maker problem
First clean out the condensor coils. If you have pets it should be done at least 3 times a year. The other possible problem is if the gasket in either the fridge or freezer is worn out or has a gap it will not cool properly. Check that the fan underneath the unit by the condensor coils is running when the compressor is . Some smaller refrigerators have only condensor coils on the back and no fan. These units should have room for air flow on top and sides not built in flush with cabinets. Buy a thermometer for both the fridge and freezer compartments. You run the risk of food poisoning if the fridge temp can not be kept below 40 degrees. Freezer temp should be able to keep at least 0 - 5 degrees. (Ice cream is a very good indication of proper temp. It is the first thing that melts. Ice maker is a close 2nd.)
If these things don't work call for repair. Don't risk losing all your food!
Jun 24, 2008 | Maytag MSD2756G Side by Side Refrigerator
Refrigerators Logo
73 people viewed this question
Top Beverage-Air Refrigerators Experts
Dennis Boxerman
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Beverage-Air Refrigerator Expert? Answer questions, earn points and help others
