Question about Toro 42'' Zero Turn Lawn Mower 22hp Kawa Consumer
Problems with stalling out when engaging levers. Thought it was the seat sensor. Help... Have tried everything....
  • 39 Answers
Could be the break switch as well, check that.
Posted on May 15, 2014
Why does my toro zero turn kill when levers pulled in seat switch good no break on mine,2011 model 74624
Posted on Aug 15, 2014
2 Suggested Answers
SOURCE: when pulling levers together the lawnmower stalls
Try turning the emergency brake off. If you move the arms in on my bad boy mower with the brake on the mower will die.
Posted on Jul 31, 2013
When I push up lever to engage the lawn mower blades it will not engage them and will stall the engine
If the operator seat saftey switch is defective the engine will stall.
safety-seat-micro-switch-fits-husqvarna-lr100-lt100-lt130-ayp-craftsman-rally-jonsered-mowers-532121305-121305-450-p-soavr15tiwcrglcekobpw2on-2-5.jpg Hope this helps?
Jun 23, 2017 | Garden
Engine starts idle well and sshut off when attempt engage blades
Chances are one of two sensors is broken or out of adjustment.
Either will cause engine shutdown when blades are engaged.
The first is the seat sensor. If you rise out of the seat with the blades engaged, the engine will die. That sensor is usually a switch located under the seat. The second is the Reverse lever (Or gear position). Newer tractors will shut off if operated in reverse with the blades engaged. This sensor may be more difficult to find, but it is usually another switch located around the gear shifter (or hydrostatic control lever).
Jul 06, 2015 | Garden
I have mdl#917.270781, motor stops when try to engage mower blades. Removed deck and it still stood when you lift engaging lever.. I replaced interlock switch 153664, but did not help.
I don't your problem is the PTO switch but is either a bad operator seat switch or loose connection. The operator seat switch connector has a built-in shorting strip that engages when the connector is loose or unplugged.
May 09, 2015 | Craftsman Garden
When pulling levers together the lawnmower stalls out. Tried everything from letting it warm up to shifting weight on seat. Help.... very frustrating....
Jul 30, 2013 | Toro 42 In 22 Hp Kawasaki Vtwin...
My new zero turn simplicity stalls when i disingage the parking lever
hi there Brian 357638
sounds like you have a safety switch problem
try disconnecting seat switch and retry if works could be wire grounding some where or faulty switch then try fitting a jump wire to seat switch wire connector retry or you have a blade engagement switch playing up or a nuetral switch playing up but more likely a seat switch
take a look
cheers pauly46
Jul 03, 2011 | Garden
Engine stalls when blade is engaged
the best way to check is to run the engine with you on it then lift off the seat and see if the seat sensor is cutting off then put a bag with some weight in it and turn on the engine it should run ok if the sensor is working and lift the back box to see if the sensor works there.. the other cause could be a build up of grass in teh cutter area stopping the blades fron moving this can caus a stall if you get a hose and blast under the cutter guards and make shure the grass shute is clear for the grass to exit this may help to mine cuts out if there is a blockage here and the grass cant get out after it has been cut it builds up at the exit plates.. Hope this works AB
Sep 07, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Cub cadet Z Force 48 inch zero turn blades won't engage
I hope this will help you...under the side panels on each side of the mower, there are "reverse lockout safety switches", they are supposed to stop the blades when both handles are pulled back. If one or both of the switches are out, the deck will not engage. Also, under the right side panel (when sitting on seat) there should be 3 relay switches, the one closest to the motor controls the PTO., if this is out, the PTO will not engage.
Jun 25, 2009 | Cub Cadet Street Sign- tractor lawn riding...
I have a Sears 26 hp garden tractor that stalls when I let off of the clutch/brake or engage the mower blades. I have bypassed the under seat swith, and I have also bypassed the clutch/brake switch. The...
does it run off of a pto system or is it a lver type if its a lever type there is a switch under the lever also you might have something caught in the deck causeing it not to engage blades if i can further help e-mail me wade at wadembly@aol.com
Jun 24, 2009 | Craftsman 26 Hp 54" Deck Yard Tractor
Mower starts but when the blade is engaged it stalls. Mower starts fine but when I press the lever to engage the blade the mower stalls immediately?
Check the pulleys on the deck...one of them is jammed or rusted to the point that will not turn.
Apr 04, 2009 | Garden
Craftsman GT5000: Dies when switch is pulled to engage blades
Hi
Check for burnt fuse behind dash. If no burnt fuses check if getting power to magnetic clutch mounted on bottom of engine crankshaft. Make sure wires are not broken by magnetic clutch. Make sure the safety seat switch is working. Make sure you are sitting on the seat when you try to engage the blades. If that does not work try pushing and wiggling the seat sensor. Check make sure wire is attached to safety switch under seat.
Apr 04, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Toro 42''  Zero Turn Lawn Mower 22hp Kawa Consumer Logo
254 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
Mike Squire
Roland W VanLue
Roland W VanLue
Are you a Toro Garden Expert? Answer questions, earn points and help others
