Question about Sony DCR-DVD301 DVD Camcorder
Transferring data from disc after finalization was interrupted
Thank you, phillip, for your very helpful advice. is there a way to plug the camera into another source, play the disc, and then transfer to a new tape or disc? or is norton's much easier? thanks very much...
  • jb220 Sep 03, 2007
    thanks, again. you've been great. my only suggestion to you is that you should have offered this as a solution when i wrote and said the power was disconnected during finalization, the material was still on there, and i needed it to play on a dvd player. you mentioned norton's as the only solution, but not tranferring the data while it played on the camera. also, as you'll see if you look at the original question i posted, there is another, much easier possible solution if you accidentally interrupt the finalization process.
    Champion:
  • 217 Answers
Yapp!! Playing the disc using your camera and records the output into another media is the best way to transfer your disc data. Computer nowaday has built in digital capture card, you can record your movie through firewire or IEEE1394 connection(unit always comes with these cables). You can even edit youyr movie, I suggest you learn adobe premiere softwares. Norton is only better when your disc is unreadable or corrupted( thats why he called it data recovery) [:0)
Posted on Sep 01, 2007
SOURCE:
I interrupted my finalization of the disc on my handycam and now can not continue
You can try data recovery software such as CDroller or "Bad CD DVD repair"
Or send it off to a mini dvd recovery company such as www.minidvdrepair.com
I used them in the past with great results. I believe I paid around $100
Jan 08, 2013 | Sony DCR-DVD610 DVD Handycam Camcorder...
How do I finalise mini dvd disc when the camcorder I was using failed and was unable to be used again. I was on holiday at the time and had 4 discs that I had not finalised before the camera failed. I have...
Have you tried inserting the mini dvd discs into your computer's dvd drive? Some dvd drives (especially DVD writers) can read unfinalised discs. And then using a DVD writer and a DVD burning software (like Nero) you can then try to finalize the discs.
Aug 15, 2011 | Computers & Internet
How can i get mini dvd to play on dvd player
Make sure that MiniDVD has been finalized in camcorder then it can be playback in any other DVD Player.
Finalize option would be available in camcorder dvd setup menu, select it to finalize recorded mini dvd disc, please note UnFinalized mini dvd disc will only playback in camcorder because of its raw data and Finalization will validate this raw data so other dvd players will recognize this mini dvd disc for playback.
Hope these info will help you.
Thanks.
Dec 17, 2010 | Hitachi Video Cameras
Hi: Please i have the sony handycam model:dcr-dvd602e and i had recorded a whole disc with it ( 30 min.) then i finalize and it was completly finalized but after that or at the end of finalizing a message...
oops....something happened during the finalizing process and it failed. Hope you had a back-up in your computer of the disk. It doesn't need to be finalized to have it in the computer, just in case this happens. Looks like your disc got erased.
Oct 30, 2010 | Sony Handycam DCR-DVD108 DVD Camcorder
The display says 'red disable' then afetr a sort while goes to the flashing disc full symbols. My problem is that it won't let me finalise so can't save the data and use the disc on other things like my...
Do you get finalize option as grayed/ disabled?
If yes then plug ac power adapter in camera and finalize the disc.
Camcorder wont finalize on battery and need ac charger to perform finalize the disc.
Jun 03, 2010 | Sony Handycam DCR-DVD201E DVD Camcorder
Finalize disc does not appear on the menu of canon DC310
In order to Finalize you have to plug in the power adapter.
It took me forever to figure it out.
Jan 27, 2009 | Canon DC310 DVD Camcorder
EX-S1: fault in function and data transfer
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
May 04, 2008 | Casio Exilim EX-S1 Digital Camera
Finalizing Disc
YOU HAVE TO MAKE SURE YOUR IN PLAYBACK MODE AND MAKE SURE YOU HAVE YOUR POWER ADAPTER PLUGGED IN
Nov 18, 2007 | Canon DC210 DVD Camcorder
Do I have to use the AC adapter/charger when finalizing a DVD-R disc?
I got a hitachi camcorder at a flee market and it did not come with an instruction book. Everything is fine up to the part where I have to finalize the disc in order to play it back on my DVD player or whatever. I have all the cords but don't know where the outlet on the camcorder is, in order to plug into the ac charger.. In other words: Where do I plug the cords. I can't find anything on the camcorder that will ssupport the cords,, Is there a hidden slot somewhere on the camcorder???? Please help, Email me at...... [email protected]
Thanks Mel
Sep 05, 2005 | Hitachi DZ-GX20A DVD Camcorder
Sony DCR-DVD301 DVD Camcorder Logo
187 people viewed this question
Top Sony Video Cameras Experts
Ekse
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
