Question about Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum
It gets hot then shuts off. - Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum
  • Hoover Master
  • 18,407 Answers
Most problems with over heating is coased by blockages in the pipes, the main one is behind the brushbar take the sole plate off and there's a suction pipe that is normoly the one that's blocked ,hope this helps you......
http://hoover.com/file/500/http://hoover.com/file/500/
Posted on Jul 31, 2013
Was using my cleaner it went off and now it won't turn back on
Many models have a thermal reset to turn off the vacuum if it gets hot. Better vacuums have a mechanical reset switch that you push to reset. Most vacuums have an automatic thermal cutoff built into the motor, if it gets too hot it shuts off the power and will reset itself when it cools back down. If it shut off due to getting too hot it indicates a clog somewhere or the filters are clogged or the bag is full.
Jan 22, 2017 | Vacuums
Turned off can not restart
it has an auto shut off feature if the motor gets to hot try unplugging it wait 30 mins then try again
Jun 02, 2013 | Eureka AirSpeed Pet Bag Upright Vacuum
While vacuuming it gets hot and shuts down
It's probably just overheating. You have to take the vacuum apart and clean it thoroughly. There is probably a "plug" of dirt/hair/gunk clogging a hose.
I have had cheap vacuums that last years as long as I clean them regularly.
Feb 12, 2013 | Vacuums
I think my maxima got too hot and shut down. Is there a fuse that I may of blown that I can check or is the motor probably fried ? Thanks, Teri
The motor has a shut off when it gets too hot. Wait 30 minutes to an hour to turn it back on. The airway is blocked, causing motor to get hot. Check filter, clean it out, check hose for clog.
Aug 28, 2010 | Eureka 4700A Maxima Bagless Upright Vacuum
The region of the motor gets very hot during use. What can I do?
The Hoover is likely built with a temperature overload protector, to shut down the unit if it gets excessively hot. All the units will get heat build-up from the suction motor during use.
Sep 29, 2009 | Hoover Vacuums
Power cut out during cleaning
1 could have hit the thermal shut off. if it gets to hot they shut off, or it could be the cord some times they just go bad or it could be something else. Good Luck!
Jul 28, 2009 | Bissell 1698-1 PowerSteamer ProHeat Plus...
Vacuum shut off
The motor gets hot when airway is blocked. Check your filter for debris deep in the pleats, clean it out, also check the hose for blockage.
Apr 04, 2009 | Eureka 4700A Maxima Bagless Upright Vacuum
Lux Legacy shuting off by itself
i would say it is over heating but some times you cant tell because electrolux have a sensor so when the get hot the turn off till they gool down soo if you really like the vacuum get it look at by a vacuum repair man.
hope this helps
May 10, 2008 | Electrolux Lux 7000 Bagged Canister Vacuum
Motor gets hot in moments and shuts off
True, the motor has safety measures to stop it from overheating... that's why it shut down. You smelled something, so some kind of damage was done. It's possible that the over temp switch itself got fried. Doesn't sound too good from here.
Mar 08, 2008 | Filter Queen Majestic Canister Vacuum
Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum Logo
29 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
