Question about Dacor Millennia MOV130 Electric Single Oven
Dacor Wall Oven Epicure EO130
The display reads "U55 Latch/Door Door Unlocking" and the oven won't heat up. I can scroll through all the menus, but it won't DO anything. I can't find anything to tell me what that code means. The oven is only a few months old. I will call Dacor as it is still under warranty but I am wondering what this problem might be. Thanks for any help.
  • 1 more comment
  • Sumana Nov 03, 2007
    I have sort of a same problem. The panel reads "U22 over temp" and I don't know what to do.
  • Anonymous Mar 12, 2014
    dacor epicure oven will not heat
  • Anonymous Mar 13, 2014
    Door always indicates door is open
  • 725 Answers
I would call the store you bought it from or dacor as it is under factory warranty...
Posted on Aug 31, 2007
SOURCE:
Dacor Single Oven Epicure Millennia: There is a continuous clicking noise occurs when the oven is off. It almost sounds as if something is still running but it is not the fan nor is it the heating...
had this issue b4 the door latch was not communicating with the over control board? not sure in ur case but can check with multi meter
Jun 16, 2014 | Dacor Ovens
My dacor microwave convection oven won't turn or heat but but the exhaust, time etc. works.
I found the answer on other posts on this website and it saved me $500! I had the same problem with my Dacor Model ECD2278 double oven. After I ran the self cleaning the top oven would not come on and the lower oven ran almost double the temp that was set. To fix: disconnect power to the oven at the circuit breaker. Open the oven door. You'll see the grille/grate/steel cover in front of the door latch mechanism, and it should have about 4 screws holding it in place. Remove the screws then remove the grille cover. On my model the tiny red reset button was on the right side on top of a black plastic round piece which is about 1" in diameter. Press the little button down til it clicks.
Oct 25, 2012 | Dacor ECS127 Epicure Stainless Steel...
F8 alert. What does this mean? The clock and "cancel" buttons work, but no heating buttons work, and self-clean will not operate.
F8 code means your door latch assy needs to be replaced, them you have options:
1. Turn it off on the circuit braker
2. Replace the door latch.
It will continue to try to lock itself most likely, as door latch micro-switch logic is messed up.
Hope helps.
Jan 03, 2011 | Dacor ECD230 Epicure Electric Double Oven
The display reads OFF on both ovens, I have never seen this before and the ovens won' work
This means you have turned the oven OFF The solution is to hold down both of the Cancel buttons for about 10 seconds and the oven should turn back ON.
Nov 21, 2010 | Dacor ECD230 Epicure Electric Double Oven
Oven is locked cancel/secure bottom is not working turning the electrical box does not work.. what do we do
Try pressing in on the door while trying to release it. The friction of the latch may be keeping the latch from opening.
Nov 26, 2009 | Dacor ECS230 Epicure Electric Double Oven
Display panel works, but oven will not come on
I take it the oven will not heat. there is a safety thermo inside the grilles. it can be reset.. turn the power off at the breaker... remove the grille..inside of the door. then look inside the thermo is has two wires going to it and a red button in the middle.. push the red button down it will reset the thermo with a click... replace grille and restore power... hope it helps.. replace grille
Sep 19, 2009 | Dacor Epicure 30" Double Wall Oven,...
Display reads U60 Cooling Fan - oven won't heat
I got Dacor to give me the number sequence -- - push "cancel" and "#" at same time - when screen asks for "service ID" enter "S1234" (get "S" by pushing "7" 5 times) - screen will list "U60 Cooling Fan" as number 1, so select "1" - select "clear all", this should clear the error - hit "cancel" to get out of that screen
Hope this works for you! Best suggestion I have is DON'T BUY DACOR!! We also own their 30" dishwasher, which has been a nightmare experience as well.
Apr 09, 2008 | Dacor ECS230 Epicure Electric Double Oven
My Dacor wont heat, broil or convection after self cleaning. No heat but everything else works The bake, broil, and convection elements on my Dacor CPS130 electric wall oven will not heat.  The oven has...
like another person stated-from the front behind the door, take off the 6 screws and the cover by the latch. there is an "oven hi temp limit switch" It is crome with 2 heavy black wires connected to it. On the back side of this is a small red button which will reset the limit switch. I had the same issue (everything worked except the any of the heating elements) and quickly resolved.
Jan 07, 2008 | Ovens
Dacor Millennia MOV130 Electric Single Oven Logo
348 people viewed this question
Top Dacor Ovens Experts
Tyler T
Level 1 Expert
Jaime Hernandez
Paul Bade
Are you a Dacor Oven Expert? Answer questions, earn points and help others
