Question about Garden
Have a problem with an Mag engine 7.2 hp gs300 electronic ignition on A Reform 206. When itgets hot it cuts the ignition?
Peaguet 206 engine cuts out when hot 2003 model petrol
REPLACE THE FAN CLUTCH AND BLADES, BE FINE, ALSO CHANGE THE THERMOSTAT
Jul 23, 2014 | Peugeot 206 Cars & Trucks
When the car is cool it will crank up, but when itget hot it shut off and wont crack backup
Does it crank and wont start, or does it not even crank over when hot? If it still cranks, if the starter cranks the engine over, then check for spark when it won't start. If you have no spark, something in your ignition system may get hot and fail-something like the crank position sensor, or the ignition control module.
Here is how to check for trouble codes on your Lesabre, and the code descriptions:
Jan 12, 2014 | 1992 Buick LeSabre
Peugeot 206 problems
  • Yes, possibly the water got up around ignition parts or electrical connections that are giving you problems. Have the engine computer scanned for diagnostic trouble codes. If the engine light was on, it should have set a code.
Dec 23, 2013 | Cars & Trucks
Engine cut out
Hi, Anonymous the following applies to carbureted also fuel injected models and the usual suspects are:
1. Severely discharged or damaged battery, 9 volts or lower.
2. Failed alternator/generator and or voltage regulator.
3. Loose or corroded battery terminals and or cables especially the "NEGATIVE" cable, look for loose, corroded, or broken connectors inside the cable harness at "BOTH" ends.
4. Failed main circuit breaker or ignition switch, check for loose connections and continuity.
5. Failed system and or ignition relay, check for continuity.
6. Failed ignition coil, ignition/electronic module.
7. Failed CKP, CPS, CMP, MAP, TPS, or BAS sensor, corroded, loose or broken wire connector pins/sockets.
8. Throttle cables and or idle speed improperly adjusted hot idle speed should be 950 RPM to 1000 RPM.
9. Air/fuel mixture screw improperly adjusted.
10. Water or dirt in the fuel system, carburetor or filter.
11. Restricted, blocked or kinked fuel line.
12. Fuel tank empty.
13. Gas cap is not venting properly or fuel tank venting system blocked.
14. A failed fuel pump, pressure regulator and or fuel injectors.
15. Vacuum line from intake manifold to petcock broken, cracked, or not attached, carburetor vent line plugged.
16. Needle and seat stuck closed in the float bowl.
For more information about your issue and free downloads that you need please visit the websites below and for specific information or questions, please feel free to contact me at xlch@mail.com. Good luck and have a nice day.
Buell Forum 06 XB12X strange symptoms cuts out
http://www.buellxb.com/forum/showthread.php?42437-XB12XT-Cutting-out-problem
http://www.steveturnbull.co.uk/buell/buellmenu.htm
TWIN Motorcycles Buell parts
Buell Motorcycle Owners Manuals
Aug 05, 2013 | Buell XB12X Ulysses Motorcycles
Ybr125 cuts out at 7000 revs and engine management light flashes
Hi, Anonymous and the usual suspects are:
1. Severely discharged or a damaged battery, should have 12.5 volts or better and be able to pass a load test if necessary.
9. Fuel tank empty
10. Water or dirt in the fuel system, or clogged filter.
12. Failed fuel pump.
13. Failed pressure regulator.
14. Faulty or clogged fuel injectors.
For more information about your issue and valuable "FREE" downloads that you need please click on the links below. Good luck and have a nice day.
https://yamahaclub.com/forums/topic/23502-ybr-125-queries
YBR125 engine light
Yamaha YBR125ED 2005 Service Manual
OEM parts for Yamaha
Yamaha YBR125ESD Owner Manual
Mar 12, 2013 | 2007 Yamaha yBR 250
What's the mag or coiul on a generac 6500 generator 13 hp
The "mag" is a magneto and it generates the high voltage pulse to fire the spark plug. The "coil" is about the same thing but it uses a set of points or an electronic ignition to control when the spark is delivered.
Sep 30, 2012 | Generac 6500 Watt Gasoline Generator - 49...
2009 Yamaha Vity engine keeps cutting out for no reason
10. Accelerator pump damaged or not working.
11. Water or dirt in the fuel system, carburetor or filter.
12. Restricted, blocked or kinked fuel line.
13. Fuel tank empty.
14. The gas cap is not venting properly or fuel tank venting system blocked.
yamaha vity 125 engine cutting out
KTM Duke 125 cutting out help
YAMAHA VITY XC125E Owner Manual
Yamaha XC125 Service Manual
Aug 11, 2012 | 2009 Yamaha Vity
My 2001 GS300 runs fine until it gets hot and starts missing. I changed wires, plugs and coil packs. what could cause this????
only thing left that would cause that problem would be the ignition module cold runs fine gets hot and shorts out common problem. good luck
Mar 11, 2011 | 2001 Lexus GS
My 12 hp tecumseh engine will run till it get hot
Hi. Follow the wires from the oil sensor to the On off switcfh. It sounds like you have have a wire that is grounding as the plastic coating get hot. Check the black wire from the electronic ignition tie plug off the module to the oil sensor for signs of chaffing. If the problem persists try disconnection ONE wire from the oil sensor and see if it will start. If it starts then either the engine is low on oil or the oil level sensor is bad.
Thanks for using FixYa.
Kelly
Apr 05, 2010 | THQ The Lawnmower Man
Craftman 18hp briggs @srat starts then cut off when it gets hot
I hope all that time and money was worth it - there are classic symptoms of a blocked gas cap vent. Vacuum forms in tank - no fuel flow - engine stalls. Wait a bit - air leaks in, engine starts again (for a while.....).
To completely elimnate a chassis wiring issue, simply disconnect the mag cable from the engine. The only possible culprit if there are still electrical problems is the coil itself - which you already replaced.
Oct 06, 2009 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
