Question about Northstar M121 Navigation System
We have a Northstar system on our boat...the M121 and while out fishing today the screen went so dark we cant read it without a flashlight. Cant seem to be able to fix it either..any ideas?Thank-you
  • Carol Dueck Aug 02, 2013
    We have found out we need a new screen and cant seem to find one so may have to buy a complete new system for the boat...this sucks as its fishing season now!!!! :(
I have the same problem there is a resistor on the high voltage side burned cannot identify the number or resistance to replace it need diagram or parts list for machine
Posted on Jan 15, 2016
Mercury 2007, 3.5 4 stroke
Engines can be troublesome sometimes.. I dont think there is any reputable shop that cant quickly identify and repair this issue without too much problem. I would assume the issue lies in the carb\fuel pump area but compression reading before is mandatory to identify if the engine can run effectively first. What is the compression reading? I can steer you better once I know. Thank you, Lewis
Sep 07, 2013 | Boating
Search Fixya...shift rod adjustment 87 200hrs evenrude
WHEN YOU REINSTALLED, AND REBOLTED THE SHIFT ROD...DID YOU PULL UP ON THE ROD TO MAKE SURE IT WAS EITHER IN
1.NEUTRAL
2.FORWARD
3.REVERSE
AS WHEN IT WAS DISASSEMBLED?
Jul 04, 2013 | Boating
I have a new tablet, charged and protected but when I was changing contrast settings it went black and I cant get the screen to come back on past startup
Sorry about this.
Well, seeing it is a new tablet, either of two things can be done.
Your tab is booting beyond Startup but you ain't seeing it because of the contrast/black screen setting.
To confirm; step into a dark room/space and hold a flashlight very close to the screen, you'd see your tab is at its home screen already.
Anyway, you will have to default factory reset it as it is or you could attempt to navigate (while in the dark room/space and using/holding the flashlight) Swipe to open/unlock it----Settings----display and brighteness-----brightness----'move cursor up to increase brightness'. Done.
Second option with dark room/space is tedious and strenuous.
Factory/hard reset is an easy option to try.
At the same time, hold/press both the volume up key/button and the power button/key.
Follow the system prompt afterwards.
Or
Press/hold down the volume down button/key and the power button.
Follow the system prompt thereafter to factory/hard reset your tab.
Best of luck.
Oct 10, 2017 | Umi PIPO S1 Android 4.1 Dual Core 7 Inch...
Wheres my bilge pump
It's located in the rear compartment centered on the bottom of the boat in front of the transom.
Jun 22, 2012 | Nitro Collectable Fishing Boat...
Colour codes of output data cable explorer 650
From the owners manual (page 78, link below) NMEA out (+) is the white wire and NMEA (-) or ground is the black wire.
-Steve
http://www.northstarnav.ca/upload/Northstar/Documents/EXPLORER_650.pdf
May 14, 2012 | Northstar POWER/DATA CABLE FOR EXPLORER...
1992 alumaweld dash board went out, fuses all good but test light shows nothing
Their may be a loose wire that you missed somewhere. You'd probobly want to take it to a repair shop.
Mar 17, 2012 | Boating
Black screen
If it is connected to the boat motor check the voltage that is coming from the engine and clean the battery post. This solved the screen flickering.
If you don't want to do that just call Northstar customer support and see what they suggest.
Phone (Toll-free) 1-800-628-4487 or (Direct) 603-324-2042
That will get you better support.
Jun 09, 2010 | Northstar Explorer 657...
Northstar M121 Navigation System Logo
306 people viewed this question
Top Northstar Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Northstar Boating Expert? Answer questions, earn points and help others
