Question about Cuisinart TOB-50 Toaster Oven with Convection Cooking
My toaster oven red light keeps blinking in the bake setting and will not get to tempature. What is wrong?
2 Suggested Answers
  • 5 Answers
SOURCE: Cuisinart Model TOB30BC Control Function
You can try to clean the contacts with alcohol (and/or very fine sand paper/brass brush...) as stated above, but the fix is a near term solution and eventually the contacts will arc and pit again. This leads to higher temperatures across the contacts and if the contacts fail before the plastic cam melts, your free to address the contacts for cleaning again. Just remember this failure will occur more frequently each time. Once the cam fails (melts) your out of luck. Write Cuisinart and tell them how unhappy you are with your toaster oven. If you get the same response I did (we only will replace it under warranty) then feel free to recycle it (or throw it away) and spend your money on a delonghi (no affiliation - my hand me down 7 yr old one keeps working great) or another brand. Companies these days should have better quality control on the products (from china) they slap their name on.
For the record, mine TOB030 has about 10 hrs run time on it before it failed @ 1.5yrs old. The inside is still brand spanking new!
Just my 2 cents.
Posted on May 30, 2008
Cancan I use a foil baking tray in the severin 220 rotisserie toaster oven
You should read the booklet which comes with Severin toaster oven. They can write everything which type foil we should use in oven.
Spit Roast Catering
Jan 25, 2014 | Severin to2015 toaster oven for 220 volts
The broil element and bake element both come on set for Bake.
You are correct in your diagnosis. The selection switch has 2 sets of contacts that should only make one when on bake. The contacts internal to that fuse are most likely fused together, the other thing that could be going on is a short circuit in the wires to the selection switch causing the same problem. Typically a repair unless under warranty would be costly unless you are up for the challenge of replacing the switch and checking the wiring yourself.
Apr 20, 2010 | DeLonghi XU1837 Trilogy Bake 'N' Broil...
How to remove grease splatter from toaster oven
set a bowl of ammonia in it over nite. do not turn oven on the fumes will ease the grease off. wipe clean in the morning with a dry cloth
Sep 18, 2009 | Oster 6058 Toaster Oven with Convection...
Kitchenaid kco1005 toaster oven broken timer dial/knob
My kitchen aid toaster oven when set on baking the light is not coming on.
Aug 20, 2009 | KitchenAid KCO1005OB 1400 Watts Toaster...
Burnt pie
YES YOU ARE your trying to bake something in a toaster oven :) toaster ovens have two modes toast /bake in this mode top and bottom elements get hot .and broil in this mode only the top elements get hot . the problem is the marketing the word OVEN makes you think of a normal oven that the bottom elements do all the work . toaster ovens work well melting stuff and toasting . thats about it . if you must bake in it try placeing a sheet of foil on top of your baked goods it might insulate the top of you food . good luck ... if this answer helped please rate it a 3 or 4 stars , this high rateing will help keep me in the paid answer department , thank you
Apr 13, 2009 | Toaster Ovens
Slow to heat Haier Convection Oven
you are correct . it is the convection . the fan blows the air around and away from the elements ,when that is happening the elements can never get hot enough to glow , as the oven gets hotter and at some point the air is so hot even with it blowing the elements will start to get red ... this is good because todays elements are thin and cheep and melt easy so the fan keeps the heat away from them and the elements last longer ...... if this answer helped please rate it a 3 or 4 stars .this high rate will help keep me in the paid answer department ... thank you
Apr 04, 2009 | Haier RTC1700 1700 Watts Toaster Oven with...
What is exactly a toaster oven?
A toaster oven is a cross between a toaster and an oven. But unlike a toast, you can cook things in it like you would on a regular oven. It might also be more comfortable than a regular oven, because it heats up faster and saves energy. I even bake cookies in it! The only problem is that it is usually much smaller than a standard oven, so you probably won't be able to bake a birthday cake or a roast in it. Other than that, it's a very useful device. have fun!
Aug 06, 2007 | Cuisinart TOB-30 Toaster Oven with...
Cuisinart TOB-50 Toaster Oven with Convection Cooking Logo
314 people viewed this question
Top Cuisinart Toaster Ovens Experts
D. E. Hev
Lawrence Oravetz
J.D. Browning
J.D. Browning
Are you a Cuisinart Toaster Oven Expert? Answer questions, earn points and help others
