Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
No hot water for warm water cycle cold water only
Your line is semi plugged
Posted on Aug 20, 2013
zaids
  • 456 Answers
SOURCE: cold/cold cyle wash water not cold
try to do cold cycle first without doing warm cycle first
Posted on Apr 12, 2008
IrishDruid
  • 2712 Answers
SOURCE: Washer will won't run cold water cycle
Some washing machines allow cold water to enter only during certain cycles. Others intermittently allow hot and cold to enter, to temper the temperature of the water. Consult your owner's manual if you are unsure about whether the machine is acting abnormally.
If you're sure the machine is not working the way it used to--or should--check the following.
  • Is the cold water turned on? If not, turn it on.
  • Is the washer getting hot water but no cold water? If so, check to see if the control panel settings are correct.
  • Is there cold water coming through the proper hose? If not, check to see if the screen inside the water-inlet valve is clean. (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If it's clean, you probably have a defective water-inlet valve. If so, you need to replace the valve.
  • Hope that helps! Should you have any further questions, please feel free to post them here.
    P.S. – I would greatly appreciate a FixYa! rating if the solution I provided fixed or helped you fix your problem.
    Thank you for using FIXYA!
    Cheers!
    IrishDruid
    Posted on Oct 12, 2008
    duby1990
    • 367 Answers
    SOURCE: no cold water Whirlpool top load washer AP595033
    Your cold water celenoid has gone out. There is no way to just replace the cold itself, So you have to buy the whole water valve. That will fix ya up!
    Posted on Nov 19, 2008
    gdmisp
    • 66 Answers
    SOURCE: hot water doesnt work, switch to warm and warm comes out.
    If the cold works on cold wash but the hot don't work on hot wash . Then yes the switch is bad.give What model is it?
    Posted on Jan 16, 2009
    onthejob5130
    • 640 Answers
    SOURCE: water temperature control not working
    the fill hoses are backwards,,,reverse fill hoses...on the job...also your under warranty ..call for service but you can do it your self..
    Posted on Jan 17, 2009
    Rinse cycle water temp
    You may have a leaking hot water electrovalve, replace it.
    Sep 06, 2016 | LG WT4870CW 27" Top Load Washer with 4.5...
    Cold/cold cyle wash water not cold
    Apr 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
    There is a hot water valve & a cold water valve on the Dexter T300 machines but it is a 2 coil valve. does the hot water valve supply only hot water or does one side provide water to perhaps the...
    supplies hot water when needed, cold water when needed. and then warm water when needed. so the second coil is for warm water. it basically mixes the hot and cold water.
    Mar 17, 2011 | Washing Machines
    Unit will not complete wash cycle that uses hot or warm water
    do you have cold? will stop at rinse cycle and hum if you have no cold
    Jan 09, 2010 | Washing Machines
    Warm water filling up washer, with no hot water hooked up to wash
    exactly
    it will maintain 60 degrees but cycling hot cold
    thermistor
    Sep 29, 2009 | Maytag Performa PAV2200
    Hot water goes into cold water washes
    It is normal for the machine to cycle between hot and cold water when filling even if selecting a cold cycle. The reason for this is because even a cold cycle requires the water temperature to be 78F for the soap to break up efficiently.
    During the cold months the water in your pipes is probably less than 78F so the machine will need to add some hot water to bring it up to this temperature. Basically, it is adding cold and then hot water to maintain a temperature in the tub of 78F for cold water cycles.
    Hope this helps, please rate my solution.
    Jan 12, 2009 | LG WM-1832C Front Load Washer
    Water temperature
    It sounds like your water inlet valve (also known as a Mixing Valve on some washers) HOT solenoid is sticking open. When you select either a hot or cold wash cycle, separate solenoids open or close to allow only cold water to enter the washer on the cold wash cycles and hot water to enter on the hot cycles. If the hot solenoid stays open, you will have hot water mixing with your cold water during the cold cycles. The result is warm water. I would recommend you replace the water inlet valve. This is a job the average DIYer can do. Please post back with your model number and I can assist you with locating a part number and/or give you specifics on how to access the valve to replace it.
    Aug 26, 2008 | Maytag Washing Machines
    Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
    Dan Webster
    Dan Webster
    Sal DeAngelo
