Question about Weedeater Garden
GAS OIL RATIO FOR HOMELITE ST175G WEED EATER - Weedeater Garden
trippssmengi
  • 76 Answers
SOURCE: oil ratio
you can use a 40:1 mix if it smokes then cut it back to 32:1 but a little more oil is better than not enough so start with the 40:1
Posted on Jan 18, 2009
sparksflyin
  • 47 Answers
SOURCE: oil/gas ratio for a modle UTO8110 homelite leaf blower
you can run 32:1 if you want to it wont hurt it but it may foul a plug since its more oil, 50:1 is the best ratio for your blower
Posted on Feb 05, 2009
taran_2005
  • 10515 Answers
SOURCE: I need to know the gas to oil ratio on a Homelite
heres a link for homelite service manual
http://www.odref.com/homelite/string-trimmers/service%20guide.PDF
pg 4 states that fuel/oil mix is 50;1
2.5 oz per gallon
Thanks.
Posted on Jun 28, 2009
  • 112 Answers
SOURCE: gas weed eater pull cord wont retract after pulling cord
remove the cover and the screw holding the recoil down, turning the pulley ccw should release the spring then wind rope around pulley and (hopefully yours has the slot in it) wind in the direction of the pulley teeth then, holding rope in slot put back on spring and wind cw till almost tight, and install screw. Usually you can do this without taking rope handle off. sometimes you have to remove handle. look at spring end in the middle and make sure its not broke as long as you have it apart. Its a easy fix.
Thanks for using fixya
Posted on Jul 25, 2009
  • 154 Answers
SOURCE: what is the gas/oil mixture rate?
50 to 1
Posted on Aug 03, 2009
Lost manual does this weed eater take regular gas or is it a mix
Want to give us a hint as to what kind of weed Eater this is? Most gas models use a mixture but the ratio can vary between manufacturers.
Jan 08, 2015 | Homelite Garden
Homelite ST175G gas oil ratio
50:1 = 2.6oz. 2 cycle oil to 1 gallon gas
Oct 08, 2014 | Garden
What is gas to oil mix ratio on weedeater string trimmer
The ratio is 40:1 Just add 3.2 ounces of 2 cycle oil to one gallon of fuel. Be sure to cap off the tank and shake to distribute the oil throughout the fuel before adding to weed eater.
Sep 19, 2014 | Poulan/Weed Eater No. Te475 952711797 17"...
What is the oil ratio for the poulon pro link weed eater
Hi brochon
Use a 50 to 1 ratio...1 pint 2 cycle oil to 6 gallons of gasoline
Please take time to rate me
Aug 28, 2011 | Poulan/Weed Eater No. Te475 952711797 17"...
Describe your Poulan/Weed Eater No. Te475 952711797 17" Le Gas Trimmer/Edger Problem Need gas to oil ratio for poulan prolink pp335 weed eater
I found the manual for this model weed eater, according to the manual the mixture...
and I quote "This engine is certified to operate on unleaded gasoline. Before operation, gasoline
must be mixed with a good quality synthetic 2-cycle air cooled engine oil designed to be
mixed at a Ratio of 40:1 ...."
and I quote once more from the manual "Helpful Tip. To obtain
correct oil mix ration, pour 3.2 ounces of 2 cycle synthetic oil into one gallon of fresh gas."
Hope that helps,
If you like I can send the manual via email if you need it.
:) happy weed thrashing
Aug 12, 2011 | Poulan/Weed Eater No. Te475 952711797 17"...
What is the gas to oil ratio for weed eaters?
Most gas weed eaters use 2-cycle engines. For the Homelite 2-cycle engine trimmers, use a 50:1 ratio of gasoline to the Homelite lubricant. (For 1 gallon of gas, add 2.6 oz of the oil.)
Many Homelite tool manuals are available here: http://www.homelite.com/service_support/product_owners_manuals . Scroll down to find your string trimmer.
I hope this helps.
Jul 16, 2011 | Homelite Garden
Need to know the gas ratio to use in a homelite(trimlitr) weed eater.
50:1 if that is too rich the weed eater will give off white smoke then use 30:1
Jun 18, 2011 | Homelite Mighty Lite Lawn Trimmer
What's the gas ratio homelite Z825Sd weed eater? Is it 20 to1, or 40 to 1, or 50 to 1?
Older two-strokes were at 20:1 in the days before EPA mandated exhaust emission restrictions and controls. Some of the new equipment lists at 50:1...but I would go with the 40:1 to be sure....and use synthetic oil for best results.
Sep 04, 2010 | Homelite Garden
GAS TO OIL RATIO
Homelite products are 40:1 gas to oil ratio
May 28, 2010 | Homelite Mighty Lite Lawn Trimmer
Weed eater TE475 - fuel ratio
FUELING ENGINE
WARNING:
Remove fuel cap slowly
when refueling.
HELPFUL TIP
To obtain the correct oilmix
ratio, pour 3.2 ounces of
2--cycle synthetic oil into
gasoline. Before operation, gasoline must be
air-cooled engine oil designed to be mixed at a
ratio of 40:1. Poulan/Weed Eater brand
synthetic oil is recommended.Mix gasoline and
oil at a ratio of 40:1. A 40:1 ratio is obtained by
mixing 3.2 ounces (95ml) of oil with 1 gallon (4
liters) of unleaded gasoline. DO NOT USE
automotive oil or marine oil.
Jul 05, 2009 | Yard Machines Garden
Garden Logo
357 people viewed this question
Top Weedeater Garden Experts
Matt Olenzek
Matt Olenzek
 steve
steve
Jerry Kramer
Jerry Kramer
Are you a Weedeater Garden Expert? Answer questions, earn points and help others
