Question about Kenmore 20.3 cu. ft. / 575 liter Upright Freezer 23024
253.9287415 what is the year of manufacture Russ.
Upright freezer got wet @ bottom when basement flooded, is it worth fixing?
If you replace the starter on the compressor unit and start capacitor and timing unit, will work as new. good luck, take ur unit upstairs next time. Russ
Sep 02, 2011 | Whirlpool 19.6 cu. ft. Upright Freezer...
How to freeze squash
Take unit to carpark and lay it on it's side, get a monster truck, line up and kill it with 600hp, may tak 2 attepts but problem solved....Russ
Sep 02, 2011 | Freezers
20 cu ft freezer top 1 foot things don't freeze completely. Bottom 1 ft things don't freeze completely. But the middle 18 cu ft its frozen.
Gas is low, also check for air flow obstruction, this may fix it,,also seals at the base of the door....Russ
Aug 22, 2011 | Frigidaire Freezers
Freezer started defrosting and the sides where burning hot. I emptied it and unplugged it. The next day i plugged it in again and it froze a water bottle rather quickly but the sides where still burning...
Your defrost timer has stuck to on position, replace timer and all good or locate timer and spray lubricant into the dial and turn it several times with unit off, then try it after several hours, quick fix only but may last several years...good luck...Russ
Aug 22, 2011 | Frigidaire Freezer 20.3 Cu. Ft. Frost Free...
True GDM-72f freezer Fans don't start
Thermo fuse has failed on the core plate, tells the freezer its cold enough to start blowing air, you can bypass it but not recommended. hope that helps, Russ
Jun 11, 2011 | True 72 cu. ft. / 2039 liter Commercial...
What temperture should a chest freezer be set at
In the middle, 0-5 = 2 and a half 1-10 = 5, adjustment shuold not be far off that, if it is, the unit has a fault.
Hope that helps. Russ
May 17, 2011 | Kenmore Freezers
Need a circuit diagram for zanussi chest freeze zfc321wb thing has stoped working after only 2 years think the motor thermal switch is open circuit but need diagram to test properly can you help?
There should only be 2 wires for compressor operation, (brown and white or blue and white), it you only have 2 posts with wires to them on your thermostat, take the wires off the posts and join them, if compressor is good, it will start but do this with GREAT CARE, exposed wires are dangerous and be sure to disconect the power from the wall before and after doing the above, good luck. Russ
May 08, 2011 | Zanussi Freezers
RED TRIANGLE LIGHT STAYS ON CHEST FREEZER IS 10
defrost cycle is innactive, will ice up shortly and may not turn compressor off, defrost the unit totally(Turn off for 2 days with door open) and remove all water from the unit once done. Restart unit and should work normal for a week or so, ie...defrost cycle...get back to me if this is the case and will sort it from there, wgheaven@yahoo.com.au Russ
Mar 28, 2011 | Whirlpool Freezers
Hi. I have just aquired an "IGNIS" chest freezer, model AFE 460/IG, class T. On the bottom right hand side of the freezer ther is a dial (from 0 to 3) which can be altered using a screwdriver...
Pretty sure that the slide is for winter and summer operation, you are rite, the 3 position is the cold level and the 3 lights (Yellow, Red, Green). the Yellow indicates a caution,"" not at temp or faulty""the Red indicates the unit is active and the Green indicates at temp and operating correct. This unit is old and not much information is available however I hope from my experience, that will help you, any further problems call Russ on 08 95230552.
DONT FORGET TO VOTE, I SUPPLY MY TIME FOR FREE TO HELP. RUSS
Mar 02, 2011 | Freezers
Daewoo frnu20da Water/ice dispenser supply
Makes no sense, you would be back and forth every twenty minutes.
Jul 23, 2010 | Freezers
Kenmore 20.3 cu. ft. / 575 liter Upright Freezer 23024 Logo
61 people viewed this question
Top Kenmore Freezers Experts
Charles T Nevin
Charles T Nevin
christian nielsen
Dan Webster
Dan Webster
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
