Question about Video Game Consoles & Games
I have an original Xbox 360 console and an original Xbox 360 Wireless Networking Adapter. I cannot connect to the Internet, but when I plug the adapter into the Xbox 360, the light turns red for a fraction of a second before turning off. How do I fix this?
    New Friend:
  • 34 Answers
You can not fix it yourself, or you'll void xbox 360 warranty policy. If your xbox is flashing red, you have set off the red-ring-of-death, also known as (rrod) the ring itself is telling you your xbox has been damaged and needs to be fixed (not by you tho, but by the xbox company).This can be mostly caused by poor airflow thru the system and overheating from the cause of it. For future reference, try to research about keeping your xbox from having this happen. One thing you will less likely find in this search for help , is that you should avoid having your xbox 360 standing up. I know you can have it standing up the long way, because it looks more awsome this way, but the thing about that is, your giving the console less air ventilation from flowing thru the xbox that is needed. put the xbox on its flat side with all air vents showing and not blocked. This will cause less of a chance from getting (rrod) again.
Posted on Aug 06, 2013
Tip
Setup your Xbox to a Wireless Network
Xbox game consoles can be connected <span style="text-decoration: underline;"></span> to a router<a href="http://compnetworking.about.com/cs/routers/g/bldef_router.htm"></a> for wireless access to the Internet and Xbox Live. Follow these instructions to set up the Xbox or Xbox 360 connections to a wireless home network.<br /><br /> <ol> <li>Connect the appropriate wireless network adapter<a href="http://compnetworking.about.com/od/hardwarenetworkgear/g/bldef_adapter.htm"></a> to the console. On the Xbox, a Wi-Fi adapter that connects to the Ethernet sometimes also called a wireless network bridge must be used. Alternatively, the Xbox 360 is also designed to work with certain Wi-Fi <i>game adapters</i> that connect to a USB port.<br /><br /></li> <li>Turn on the console and navigate to the wireless settings screen. On the Xbox, the menu path is "Settings -&gt; Network Settings -&gt; Advanced -&gt; Wireless -&gt; Settings" On the Xbox 360, the menu path is "System -&gt; Network Settings -&gt; Edit Settings."<br /><br /></li> <li>Set the SSID (network name) on the Xbox to match that of the wireless router. If your wireless router has enabled SSID broadcast, the SSID name should appear pre-selected on the Xbox display. Otherwise, select the "Specify Unlisted Network" option and enter the SSID there.<br /><br /></li> <li>Specify "Infrastructure" as the Network Mode. (Infrastructure is the mode used by wireless routers.)<br /><br /></li> <li>Set the Security Type to match that of the wireless router. If your router uses WPA encryption and the type of adapter connected to the Xbox does not support WPA, you will need to change your router settings to use WEP encryption instead. Note that the standard MS Xbox Adapter supports WPA while the standard Microsoft Xbox Wireless Adapter (MN-740) only supports WEP.<br /></li> <li>Save your settings and verify the network is functional.<br /><br /> On the Xbox, the Wireless Status screen displays whether a connection has successfully been made with the wireless router, and the Connect Status screen displays whether a connection has successfully been made through the Internet to Xbox Live.<br /><br /> On the Xbox 360, use the "Test Xbox Live Connection" option instead.</li></ol> Tips: <ol> <li>Even when your wireless connection between the Xbox and the router is working perfectly, you may still experience difficulty connecting to Xbox Live. These issues can be caused by the quality of your Internet connection or the firewall and Network Address Translation (NAT) settings of your wireless router. Additional troubleshooting may be required in these areas to achieve reliable Xbox Live connections.</li></ol><span style="font-weight: bold;">Troubleshooting</span><br /><br /> The built-in diagnostic of the Xbox can help with any falure.Navigate to the <i>System</i> area of the Xbox Dashboard, select the <i>Network Settings</i> menu option, then select <i>Test Xbox Live Connection</i> to run the test at any time. If the Xbox 360 built-in network diagnostic fails with the following message: <br /> <ul><i>Technical configuration error. Please contact Xbox Customer Support.</i></ul> This indicates a network issue requiring further investigation. The Xbox 360 network diagnostic contains the following tests run in the order listed below. Steps for troubleshooting Xbox 360 connectivity issues depend on which test reports the failure. <br />If you have an original Xbox 360 console, you need to attach an Xbox 360 Wireless Networking Adapter before you can connect your console to a wireless network.<br /> <b>Note</b> You can use an Xbox 360 Wireless Networking Adapter with the Xbox 360 S console. If your wireless router is not near your console, you may get a better wireless signal by using a wireless networking adapter. When you connect an Xbox 360 Wireless Networking Adapter to an Xbox 360 S console, the console will automatically use the wireless adapter instead of the built-in Wi-Fi.<br /> If you have an original Xbox 360 console, you need to attach an Xbox 360 Wireless Networking Adapter before you can connect your console to a wireless network.<br /><br /> Step 1: Attach an Xbox 360 Wireless Networking Adapter to the back of your Xbox 360 console.<br /> Step 2: If a network cable is plugged into the back of your console, unplug it. Step 3: Check the light on the Xbox 360 Wireless Networking Adapter.<br /> If you're using the black adapter with two antennas:<br /> <ul> <li><b>No light:</b> The adapter is not receiving power. Unplug the USB connector, and plug it in again. Still no light? Try plugging the adapter into a USB port on the front of the console.</li> <li><b>Green:</b> The adapter is connected to a wireless router, gateway, or access point.</li> <li><b>Flashing green:</b> The adapter is attempting to connect to a wireless network.</li> <li><b>Red:</b> The adapter is not recognized. Try plugging the adapter into a USB port on the front of your console. </li> <li><b>Flashing red:</b> There is a problem. The adapter might be experiencing a hardware failure.</li></ul><br /> Configure your wireless settings Go to <b>My Xbox,</b> and then select <b>System Settings</b>. <br />Select <b>Network Settings.<br /></b>Select <b>Configure Network</b>.<br /> <ol> <li>On the <b>Basic Settings</b> tab, select <b>Wireless Mode</b>. <br /> <b>Note</b> If Wireless Mode is still not available, there might be a problem with your hardware. <br /></li> <li>Select <b>Scan for Networks</b>. </li> <li>Select your wireless network name. <br /><br />If your wireless network is not listed, try either of the following:<br /> <ol> <li>Try improve the router signal by moving the router position.If you are not broadcasting your wireless network name, select <b>Specify Unlisted Network</b>, and enter your wireless network name and security type. </li></ol></li><br /> <li>Enter your wireless network password, and then select <b>Done</b>.</li> <li>Press the <b>B</b> button on your controller, and then select <b>Test Xbox LIVE Connection</b>. If you successfully connect to Xbox LIVE, you'll see this screen:Choose <b>Yes</b> when you are prompted to update the console software. <br /></li></ol>
on Jan 18, 2011 | Video Game Consoles & Games
Tip
How to set up the Xbox 360 Wireless N Networking Adapter
Overview
If you connected to Xbox LIVE after October 28, 2009, a software update was installed on your Xbox 360 console to support the Xbox 360 Wireless N Networking Adapter. If the update was installed on your console, all you need to do is to configure the wireless settings. To learn how to do this, please see the following article:
908877 (http://support.microsoft.com/kb/908877/ ) How to configure wireless settings on your Xbox 360 console
If you have not connected to Xbox LIVE since October 28, 2009, you will need to use the installation disc included with your Xbox 360 Wireless N Networking Adaptor to install software on your Xbox 360 console.
To install the software for a Wireless N Networking Adapter
1. If an Xbox 360 Wireless N Networking Adapter is plugged in to your console, unplug it.
2. Insert the installation disc included with the Xbox 360 Wireless N Networking Adaptor into your Xbox 360 console.
3. Turn off the console.
4. Turn the console back on.
The software update should start automatically. If the update does not start automatically, the software might already be installed.
Note If you receive a mixed media error message, please see the section titled "Mixed media error message" below.
5. When you are prompted to install the software, select Yes, update now.
6. If a network cable is plugged in to the back of your console, unplug it.
7. Once the installation is complete, plug the Xbox 360 Wireless N Networking Adaptor into the USB port on the back of your console.
For information about attaching and configuring your wireless adapter, please see the following article: 908877 (http://support.microsoft.com/kb/908877/ ) How to configure wireless settings on your Xbox 360 console
8. Remove the installation disc from the disc drive.
9. Turn off your console, and then turn it on again.
If you receive a mixed media error message, auto-play might be turned off. Here’s how to turn it on:
1. On your console, go to My Xbox, and then select System Settings.
2. Select Console Settings.
3. Select Auto-Play.
4. Select Enable.5. Repeat the steps for installing the wireless adapter (above).
Next step:
For information about how to configure the wireless settings on your console, please see the following article: 908877 (http://support.microsoft.com/kb/908877/ ) How to configure wireless settings on your Xbox 360 consoleDo not try to repair the wireless networking adapter.
Do not take your Xbox 360 console or accessories to a retailer for repair or service unless an Xbox support agent instructs you to do this.
Do not try to disassemble, service, or modify the Xbox 360 console, the power supply, or any accessories. If you do this, you might put yourself at risk of serious injury or death from electric shock or fire. For your own safety, such actions will void your warranty.
on Mar 04, 2010 | Video Game Consoles & Games
Cant connect to xbox live
What you need:A high-speed Internet connection such as cable A router, gateway, or wireless access point (WAP) that is compatible with Xbox LIVE. An Xbox 360 Wireless Networking Adapter (original Xbox 360 console only) Instructions: On your console, go to My Xbox, and then select System Settings. Select Network Settings. Select the name of your wireless network. Enter your wireless network password. Select Yes if you are prompted to update your console software. When you successfully connect to Xbox LIVE, your screen will look like this:
Jul 25, 2011 | Microsoft Wireless Network Adapter Xbox...
How do you get connected to xbox live
What you need
  • A high-speed Internet connection such as cable or DSL
  • A router, gateway, or wireless access point (WAP) that is compatible for xbox live
  • An Xbox 360 Wireless Networking Adapter (original Xbox 360 console only)
Configure and test
Next you need to configure your wireless settings and test your Xbox LIVE connection. The steps vary slightly, depending on your console's software.
  2. Select Network Settings.
  3. Select the name of your wireless network.
  4. Enter your wireless network password.
  5. Select Yes if you are prompted to update your console software.
Jul 04, 2011 | Video Game Consoles & Games
I have just got in broadband but my xbox aint picking up my wireless signal upstairs,ive got the wireless adapter for the xbox,its picking up a few neighbours network connections,surely my xbox should be...
It is possible that the Xbox will be unable to pick up the wireless signal being transmitted by your gateway because the signal is too weak.
The connection speed of your internet has nothing to do with the strength of the signal. The best way to test this would be to try to connect to your wireless internet on a laptop while sitting near the xbox. If you cannot, you will know that the signal isn't powerful enough to reach that location.
There are three common options to amplifying your signal if necessary.
1) Purchase a High-gain antenna for your wireless gateway
2) Purchase a wireless repeater
3) Purchase a new router/gateway with a longer range capability. A "Wireless N" enabled router would be optimal for this application.
Apr 12, 2011 | Microsoft Xbox 360 Console
How do i hook my mi-fi internet to the xbox 360? i have purchased an adapter and can not figure out how to get the internet working
Here's how to configure your wireless settings:
  1. On the console, go to My Xbox, and then select System Settings.
  3. If you are prompted to select a wireless network, complete these steps, otherwise skip to step 4.
    1. Select the name of your wireless network.
    2. Enter your wireless network password and select Done.
    3. The console will automatically try connecting to Xbox LIVE. If you get an error message, go to the following webpage for help: support.xbox.com/pages/xbox-live/troubleshoot/connection-issues/connect-xbox-live.aspx (http://support.xbox.com/pages/xbox-live/troubleshoot/connection-issues/connect-xbox-live.aspx)
    Note If you do not see the name of your wireless network, select Advanced Options. Then select Specify Unlisted Network and enter your wireless network name. Select your wireless security type (WEP, WPA, WPA, or No Security). This security type needs to match the security of your wireless network.
  4. Select Configure Network.
  5. On the Basic Settings tab, select Wireless Mode.
    Note If wireless mode is not available and you are using the black Wireless N Networking Adapter, try using the software installation disc included with the adapter. For more information about how to do this, please see the following article: 977641 (http://support.microsoft.com/kb/977641/ ) How to set up the Xbox 360 Wireless N Networking Adapter
  6. Select Scan for Networks.
  7. Select your wireless network name.
    If your network is not listed, try the following:
    1. Select Specify Unlisted Network, and enter your wireless network name (also referred to as your Service Set Identifier [SSID]).
    2. Select your wireless security: WEP, WPA, WPA2, or No Security (if your network doesn't have a password).
      If you can't connect to your wireless network, try improving your wireless signal using the tips in the following article: 909336 (http://support.microsoft.com/kb/909336/ ) Your Xbox 360 console receives a weak wireless signal
  8. Enter your wireless network password, and then select Done.
    Note Make sure that you have entered the correct password. An incorrect password might allow your console to connect to your wireless network, but you might receive an IP address error when you test your Xbox LIVE connection.
  9. Press B on your controller, and then select Test Xbox LIVE Connection.
Mar 07, 2011 | Microsoft Xbox 360 Console
How do i configure a wireless adapter for xbox live
To use the Xbox 360 Wireless Networking Adapter with Xbox Live, you must have a high-speed Internet connection (cable or DSL).
Your wireless networking adapter is designed to attach directly to the back of your Xbox 360™ console.
Refer this article http://www.xbox.com/hi-IN/support/xbox360hardware/system_setup/setup_accessories/wirelessnetworkadapter.htm#Attach
Jun 01, 2010 | Microsoft Wireless Network Adapter Xbox...
Link Your Console to Another Console
Console-to-Console Connection: Wireless Some Xbox games offer console-to-console, or system-link, play, in which two or more players (depending on the game) can wirelessly network their consoles for multiplayer use. Console-to-console wireless networks are also known as ad-hoc networks. In ad-hoc networks, a wireless adapter on one device connects directly to a wireless adapter on another device. An Internet connection isn't shared with this type of network, and the console-to-console connection is typically temporary. For console-to-console play, you need: Two Xbox 360 consoles. Two Xbox 360 Wireless Networking Adapters. An Xbox 360 game that supports system link play. To wirelessly connect your console to another console: Attach an Xbox 360 Wireless Networking Adapter to the back of each console as described in Use Your Xbox 360 Wireless Networking Adapter. On each console, go to the System area to enter your network settings. (They will be the same for each console.) If all settings are correct, exit the System area. The consoles should now be wirelessly connected to each other.
Nov 20, 2005 | Microsoft Xbox Console
Nov 20, 2005 | Microsoft Xbox 360 Console
Video Game Consoles & Games Logo
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
