Question about Maytag Dishwashers
Arms want turn during wash cycle. - Maytag Dishwashers
    Top Expert:
  • Maytag Master
  • 12,223 Answers
See the diagram and fix it. God bless you
Arms want turn during wash cycle. - 3d9702ff-f211-455c-bfd2-1f00f282ab88.gif
Posted on Jul 31, 2013
SOURCE: No pressure during wash cycle
check capacitor on motor. possibly not turning at correct speed
Posted on Jun 10, 2008
SOURCE: Noisy Bosch dishwasher SHU43C05UC
your main wash motor is faulty it must be replaced.
  • 27 Answers
SOURCE: Bosch dishwasher whining
if you listen to the appliance and the noise is louder on the rhs and low down this is probably the main wash motor they sometimes do whine if you can live with the noise leave it alone if not you basically have to take the whole applianmce apart for access to the motor costly repair would take a trained pro about 90 mins to replace the motor
if the noise is coming from the front of the appliance more to the lhs and is intermittant ie when it first starts up and then about half way through its likely to be the drain pump relitively easy to replace and you dont have to take the appliance to bits just go at from the front
good luck
Posted on Mar 13, 2009
john631068
  • 172 Answers
SOURCE: dishwasher makes grinding noise
Water-inlet valve Most cleaning problems are caused by the dishwasher not getting enough wash water, so the water-inlet valve is often to blame. This valve is usually at the bottom left or right of the dishwasher, behind the lower access panel. It's the device with the main water line from the house, a rubber tube to the dishwasher, and two wires attached to it. When a water-inlet valve is defective, you may hear the sound that's usually referred to as "water hammer." If the water-inlet valve is defective, you need to completely replace it. Dishwasher Water Inlet Valve Replacement
Be sure to read and understand any instructions that come with the new water inlet valve.
Posted on Nov 19, 2009
bugsy33
  • 33 Answers
SOURCE: My Bosch classixx has started making a terrible
build up of calcium clean your hoses check your lines they maybe blocked sound like a high pitch squeak something is stopping it from getting water
Posted on Dec 05, 2009
Why low pressure to the wash arms during wash and rinse cycle?
The small holes in the wash arms could be clogged with scale or the machine's pump and motor assembly are not working correctly.
Also make sure that the inlet valve is allowing enough water into the machine as too little water could also cause this problem.
Jul 12, 2014 | LG Dishwashers
Dishwasher hums intermitantly and after the wash cycle is completed
Sounds like you have a bearing going out. It could be in the system pump or the rotating washing arms. I would suggest getting ahold of Kitchenaid's customer support and relay when during which cycle the noise occurs and they should be able to identify whats going wrong.
Jan 22, 2014 | KitchenAid KUDE70FXPA Builtin Dishwasher
I have a whirlpool Adp8540 that seems to go through the wash cycle completely but when we open it up the water has not gone through the spraying arms and the soap is a solid mass at the bottom of the...
It is likely the water circulation system is faulty. This dishwasher uses a single motor to run the water pump and the drain pump. If you hear the wash pump operate during wash cycle then it is likely there is a blockage in the water circulation manifold which distributes the water through the arms.
If you do not hear the pump operate during wash cycle then the sensor is faulty. The sensor tells dishwasher to switch to drain cycle from wash cycle.
Try following the diagrams at top of this website to get idea of parts.
Oct 13, 2011 | Dishwashers
I have a GE front-loading washer. There is a horrible thumping noise as the drum turns. It is not constant - when I turn it by hand it seems to "thump" on every rotation of the drum. I ran it...
The thumping sound is a sure sign that the spider arms or the support arms that hold the wash drum are broken. It is a very expensive repair since you need to buy a replacement wash drum and spider arm assembly which almost cost as much as new washer. Get a few estimates before deciding whether to repair or replace the washer. Sorry.
Apr 23, 2011 | GE WSXH208A Front Load Washer
During the spin cycle there is a very loud knocking noise,
Could be the spider arms are broken. You can confirm this by turning the tub by hand, if you hear any kind of thumping sound as you turn the tub, then the spider is broken. The spider is the support arms that hold the wash tub to the drive shaft. It's very expensive to repair.
If there is no thumping sound when you turn the drum, it could be that one of the supports or spring is broken. Hope this helps.
Jul 23, 2010 | Frigidaire GLEH1642DS Front Load Stacked...
Both spray arms of my DU943PWKQ0 do not turn or spray. The motor is moving and the it drains without problem. During the wash and rinse cycle I can hear the sound of water, however it doesn't clean at...
Try rotating the spray arms by hand. It should rotate freely. If possible clean the arm rotating place by removing them.
Arms rotate by by pump pressure only. finally check the water pump also.
May 18, 2010 | Whirlpool DU943PWK - Multiple Color...
Unclean dishes food particles left on glasses
Most likely causes are:
Not enough water entering dishwasher (check level after fill... Should be slightly below bottom wash arm)
Water filling but draining during wash cycle. Check toward end of wash cycle but before drain. See if water level is diminished from start of wash cycle.
New 'water saver' dishwashers are notorious for having smaller water jets, and thus easier to stop-up jets. Check the jets on all wash arms to be sure they are cleared of food particles.
Another way to check the wash arms is to manually position them at specific locations, momentarily run the dishwasher for a few seconds, then open the door to inspect the location of the wash arms. Do this three or four times to eliminate the possibility of coincidence.
If the wash arms do not move from the location that you put them, the most likely cause is food particles stopping up the water jets. These jets not only clean the dishes but also the water pressure they generate turn the arms inside the dishwasher to properly distribute water pressure on the dishes.
Sometimes you can dislodge and remove food particles stuck in one of the jets with a toothpick or other small probe. Others require that you remove the arm(s) and get a little more creative. I use compressed air to clear mine, but not everyone has access to compressed air, so use whatever you can to remove the food particles.
Simply dislodging them from the water ports is usually not effective... As soon as water pressure is applied, the particles return to the jets and stop them up again. The real fix in this instance is to completely remove the food particles from the arm if you can.
Hope this help. Good luck.
Sep 11, 2009 | Dishwashers
Soap is not disolving. Falls out of holder and stays on door and floor of washer.
Are dishes also not coming clean? Most likely, there is not enough water chruning in the tub to rinse soap out of cup during wash cycle. Sufficient wash action will wash the soap out of the cup and dissolve it in the water within a few seconds of the cup opening.
Dishes don't get clean. soap still on inside of door. . . water coming up to fill line and hot enough and dishwasher drains after cycle, spray arms are clear. . . help!
Water from the wash arms must be able to reach the detergent cup during the wash. It sounds as though the machine may be over-loaded during the wash and water does not cause the detergent to mix with the wash tank water. Try washing a cycle with nothing in the machine. Does the detergent still stick to the door?
If no, the machine is overloaded. Wash fewer items or smaller items so spray will contact detergent.
If yes, you have probably lost wash pressure. Clean all screens and jets.
Hope this helps,
Kermit
Aug 13, 2008 | Dishwashers
Jun 05, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwashers Logo
Top Maytag Dishwashers Experts
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
