Question about Vehicle Parts & Accessories
What should the oil pressure read on my 2009 Chevy z71 4x4 5.3 flex fuel v8
    New Friend:
  • 5 Answers
38PSI at idle, 50-75 PSI at 2500 RPM
Posted on Jul 31, 2013
Got a p.o.300 misfiring. Had disconnected wire's from distributor and lost track. Need a diagram of correct placement.
google the engine make for the firing order
p0300 is random misfires and is seldom plugs and wires but more likely to be low fuel pressure ( dirty filter) or blocked injectors
Oct 15, 2017 | Cars & Trucks
Tip
Small Block Chevy V8 267, 305, 327, 350, 400 cid.
Bolts or Parts Lube or Sealer Torque to: 7/16 Main Caps (2 bolt) Engine Oil 70 ft-lbs. 7/16 Inner Main Caps (4 bolt) Engine Oil 70 ft-lbs. 7/16 Outer Main Caps (4 bolt) Engine Oil 65 ft-lbs. 3/8 Outer Main Caps (4 bolt) Engine Oil 40 ft-lbs. 18436572 The firing order Small Block Chevy V8 3/8 Connecting Rod Bolt Engine Oil 45 ft-lbs. 11/32 Connecting Rod Bolt Engine Oil 35 ft-lbs. Cylinder Heads
Engine oil
(blind hole)Sealer
(water jacket)
65 ft-lbs.
Rocker Studs (screw-in) Engine Oil 50 ft-lbs. Oil Pump Engine Oil 65 ft-lbs. Oil Pan Engine Oil 12 ft-lbs. Cam Sprocket (upper gear) Thread Locker 20 ft-lbs. Timing Cover Engine Oil 6 ft-lbs. Intake Manifold
(Cast Iron Heads)
Non- Hardening Sealer 30 ft-lbs. Valve Cover Engine Oil 3 ft-lbs. Exhaust Manifold Anti-Seize Lubricant 25 ft-lbs. Spark Plugs No Lube or Sealer 20 ft-lbs. Flex plate (Automatic)
Flywheel (Clutch)
Thread Locker 60 ft-lbs. Clutch Pressure Plate Thread Locker 35 ft-lbs. Center bolt
(Harmonic Damper)
Engine Oil 60 ft-lbs. Bell housing
(Transmission to Block)
Engine Oil
  • 25 ft-lbs.
on Jul 17, 2010 | 1985 Chevrolet Chevy
I have a 2004 flex fuel tahoe 5.3. P171 and p174. Codes on. Have replaced fuel pump , pressure reg., plugs and fuel filter. Hard to start but runs fine for awhile then starts acting up.
2002 Chevy Tahoe + P0171/P0174 - Chevrolet Forum - Chevy ...
chevroletforum.com > ... > General Discussion Forums > General Tech
Jul 8, 2007 - I have cleaned the MAF sensor, changed the fuel filter, ... I also have a 2002 Tahoe that is posting the p171 and P174 codes and .... I have a 2000 ChevyTahoe with a 5.3L V8. ... That seems normal for the light to go off after running, the IAC motor should have its own fault code, so it may not be that, but not ...Missing: flex
SilveradoSierra.com • P 171, P 174 error code : Vortec 5300 ...
Chevy 5.3 liter lifter noise and motor flush solution How to ...? 14:10https://www.youtube.com/watch?v=4RecrxxLT4sAug 29, 2011 - Uploaded by briansmobile1Chevy 5.3 liter lifter noise and motor flush solution How to .... was there an issue with the oil pressure gauge on the dash? my '04tahoe with the 5.3 when it's .... 2004 chevy suburban1500 5.3Lflex fuel - I followed this but still have the ticking. .... How to jack up your car without jacking up your car - Duration: ...Truck Jerking/Studdering Around 45-50 mph - Ford Truck Enthusiasts ...www.ford-trucks.com > ... > 1997 - 2003 F150Dec 6, 2010 - Right around 45-50 mph, my truck starts to jerk or studder as I attempt to .... the EGR system operation causes very lean air/fuel ratios that requires higher coil voltage to fire. .... 06 f150 5.4 jerking at 45-50, trucks12345, 2004 - 2008 F150, 6 ...1966 - 1977 Early Broncos, Ford Vans and other vehicles, 2014+ ...
Nov 29, 2015 | Cars & Trucks
No fuel spray from injectos
1986 chevy s10 2.5l no gas coming from injector. - S-10 Forum
www.s10forum.com/.../1986-chevy-s10-2-5l-no-gas-coming-from-inject...
Sep 2, 2009 - 24 posts - ‎7 authors I have no gas coming from my injector it a 1986 chevy s10 2.5l I have replaced the fuel pump,oil pressure switch & I checked and oil would ...
Oct 12, 2015 | 1988 Chevrolet S-10
My oil gauge for my 2006 Chevy silverado v8, 2wd does not work. It reads 0 pressure and stays until at a stop and radically jumps.
Sounds like you need to replace the oil pressure sending unit. Should be located on the engine down by the oil filter.
Apr 21, 2013 | Cars & Trucks
2009 Chevy 2500 cranks but won't start
gas? diesel? if its a 6.0 gas they have problems with the crank sensor. check for fuel pressure and spark. read the computer codes. probably crank sensor or fuel pump
Mar 16, 2013 | Cars & Trucks
2009 Trailblazer randomly won't start
When it doesnot start you need to check for fuel and spark.Let me know if you have both.Maybe a crankshaft sensor or maf sensor.
Dec 28, 2011 | Chevrolet TrailBlazer Cars & Trucks
Where is the oil pressure sensor located on a 2005 chevy silverodo 6.0 V8 1500
The oil pressure sensor is located on the side of the oil pan and actually reads pressure from the oil pump.
Feb 06, 2011 | 2005 Chevrolet Silverado 1500HD
I have a 1988 Chevy K2500, V8-350 cu. in with TBI. I have fire, but there is no fire running to the fuel pump. There is a new fuel pump relay installed and the fuse is also good. Truck ran fine, then...
Oil pressure switch puts power to the pump after it is started.
Pumps also tend to loose their ground with age. I often splice in a new ground at the pump to eliminate that problem area.
Need some votes, thanks
Aug 22, 2010 | 1990 Chevrolet K2500
Vehicle Parts & Accessories Logo
55 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
