Question about Fisher and Paykel 24 in. DD603H W Built-in Dishwasher
I have a Fisher&Paykal DD6031 drawer dishwasher. Stopped running mid cycle. Lights flashing on drawer front green,red,yellow,red green,red,yellow . I don't know what that code means. On the inside Heavy ,fast,rinse were all lit Red. It sings "the star spangle banner" too!
    Top Expert:
  • Fisher and P... Master
  • 12,223 Answers
Follow this steps and fix it. GOD BLESS YOU
Heating Element
If lights are flashing on the control panel, the heating element might have burned out. The heating element heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element can be checked for continuity with an Ohm meter.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Heating Element Assembly
If lights are flashing on the control panel, the heating element assembly might have burned out. The heating element assembly heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element assembly can be checked for continuity with an Ohm meter.
Check Fault Codes
If the display lights are flashing and there is an error code in the display window, check the wiring diagram and tech sheet in the dishwasher that will provide information on the fault.
Drain Pump
If lights are flashing on the control panel, the drain pump might not be working properly. For two-wire drain pump motors check them for continuity using an Ohm meter. If it's defective You'll need to replace it. Drain pumps are not repairable.
Touchpad and Control Panel
If the lights are flashing on the display the entire touchpad and control panel assembly might be defective. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced.
Touchpad
If the display lights are flickering for no reason, the touchpad might need to be replaced. Sometimes when the touchpad is defective the display lights are flashing randomly.
Posted on Jul 31, 2013
SOURCE: haywire dishwasher contol panel
I had the same problem. Played Fur Elise and the Star Spangled Banner when you press and hold the middle button. Before that it was not draining and the lights were blinking blue and red.
I found the breaker to the power for the dishdrawer, turned it off, then back on. That seems to have worked. We are not thrilled with the number of times we have had to call for service or run an extra rinse cycle because the top drawer did not drain all the way. We got a full rebate for the cost of the unit when we bought a DCS range and hood so it was free. Not sure I would buy on though.
Good luck.
Posted on Nov 10, 2008
  • 8 Answers
SOURCE: I have the DD6031 fisher Paykel two drawer
Disconnect the power to the unit for at least 15 minutes to see if you can "reset" the unit.
Posted on Nov 25, 2009
Sheikhtijani
  • 1284 Answers
SOURCE: Fisher & Paykel DD60DCX6 Top
Hi, from the explanation made above, i sounds like the motor is faulty and needs to be replaced.......
Take care
Posted on Feb 02, 2010
  • 205 Answers
SOURCE: I have a F&P DD603I with NO lcd, just lights
HI- I think your controller is faulty. I've only encountered the Star Spangled Banner issue once and replacing the controller fixed the issues. You may try to unplug the power cord for a few minutes and plug it back in and see if it resets but I don't think that will resolve it. I'd give Fisher/Paykel a call and see if they can narrow it down for you, they are often helpful.
Posted on Sep 24, 2010
  • 3247 Answers
SOURCE: Fisher & Paykal DD6031 Integrated We have a
The fault you have described with the top drawer appears to be related to the lid seal becoming dislodged. However, I am slightly unclear if you can actually open the drawer or not. YOu mention it is hard to pull but you also say you see water at the bottom of the drawer. So I am assuming you are able to open the drawer. This is important otherwise it will become hard to check the problem.
It might help confirm if the lid seal is the problem if you can check which lights are on at the top of the drawer lid. For example NORMAL and RINSE. I am assuming since you have an integrated model there is no LCD display in the front.
If it is a lid seal problem then you may have to call the technician from Fisher and Paykel. It does involve a little patience and mechanical prowess to fix it. There is fiddling with motors etc involved.
You can check the parts out at this site.
Posted on Oct 04, 2010
Fisher Paykal 602 dishwasher - top drawer won't power on
Most likely the thermal fuse (inside heater assembly) is blown.
Not easy to repair. Need to replace the whole heater at the base of drawer.
Mar 28, 2013 | Fisher and Paykel Dishwashers
My top dishwasher drawer won't finish through the cycle. It runs fine on rinse only but not any of the wash cycles. It stops mid cycles, beeps like it has been paused, then tries to start again
Try to feel the temperature of water inside the dishwasher. If it is normal room temperature for the hot wash cycles then it is likely the heater is faulty.
It is not easy to replace unless you have good experience with repairing dishwashers.
Jan 17, 2013 | Fisher and Paykel 23 in. DD-603 Built-in...
Drawer stopped mid cycle
Have you tried to turn the mains power switch off and on to see if it resets the drawer to off state. Need a bit more detail of what you see on the display etc. when you try to turn back on.
Dec 10, 2012 | Fisher and Paykel 23 in. DD-603 Built-in...
How to get bottom drawer out of fisher paykel dd6031
I wasn't able to find an exact match to your reported model (DD603I?), but all of the DD60xx models appear to have the same drawer removal process:
2_23_2012_6_18_56_am.jpgI actually took this from the installation guide for the KitchenAid dishdrawer (also made by F&P), since it had the clearest images.
Dec 24, 2011 | Fisher and Paykel 24 in. DD603H W Built-in...
Fisher & Paykal Refrigerator. E 522 B Plastic piece in door hinge fell out . Door now travels around and has big dent in front panel. I need to replace outer stainless door panel and plastic piece in...
The plastic piece that is moulded to the inner door that holds up the shelf on a fisher & paykel fridge has cracked and no longer holds the shelf. Can I buy a new door liner or does the whole door need to be replaced?
Jan 29, 2011 | Fisher and Paykel E522BRXFD Stainless...
My fisher dd6031 bottom drawer doesn't seem to get rid of all the water,,and it keeps beeping and will keep beeping through the night if you don't catch it...we have been putting it through another rinse...
You will have to take the filter plate out the motor rotor out. Then clean the rotor cavity and replace in reverse order.
Are you getting any error codes?
Does the beeping stop if you turn the power off and on?
Sep 05, 2010 | Fisher and Paykel 24 in. DD603H W Built-in...
F & P Dishdrawer DD6031
The Problem is Related to the Dishdrawers Motherboard Control Center This usually happens when water condensation sits on the board to long and Short Circuits controls.
Jul 11, 2009 | Fisher and Paykel 24 in. DD603H W Built-in...
How can I fix my Fisher and Paykel DD 6031 Dishwasher? its leaking
I have Fisher & Paykle DW DD603-SS (5Y old)
The upper drawr started to leak H2O out and in to the bothom drawr???
What is the problem and also please what is the solution?
Thanks, JB
Jun 23, 2008 | Fisher and Paykel 24 in. DD603H W Built-in...
F&P dish drawers model DD6031
It may be that the DW thinks the drawer may have been pulled open. On the right side, near the top. there are two light pipes on the drawer. One sends an infrared beam of light to a reflective area on the cabinet, the other receives this light. This is how the drawer senses whether the drawer is open or closed. Wipe these areas with a clean dry cloth.
Apr 23, 2008 | Fisher and Paykel 24 in. DD603H W Built-in...
Fisher and Paykel 24 in. DD603H W Built-in Dishwasher Logo
210 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
