Question about Briggs & Stratton Garden
Hi, I have just been given a rotavator with a briggs and Stratton engine, don't no anything about it, how old, how to start it, it has pull cord but nothing?? model number is 140202, serial is 37634 and type number is 504026 many thanks from ben
    Sergeant:
    Champion:
  • 320 Answers
Look at the: Model, Type and Code numbers. The first two numbers of the code should be the year the engine was made. What problems are you having?
Posted on Oct 18, 2013
SOURCE: Poor running engine on my lawn mower
I think you need more than a screw adjustment in the carburetor. It sounds as if you need a full tuneup. This means air filter, gas filter , carb. rebuild ,spark plug etc. Good luck. donnyb60
Posted on Mar 22, 2009
  • 138 Answers
SOURCE: Craftsman LT 1000 with Briggs and Stratton 20 OHV
lift your seat and look at the label that you got your model number from. to the right of the model number is the serial number. the first six digits of the serial number is the date your tractor was made - for example: serial no. 060802D002756 would make the unit made June 8, 2002
Posted on Aug 18, 2009
mowerman1857
  • 389 Answers
SOURCE: timing for briggs and stratton 15.5 engine
There are no timing marks, timing is correct when the flywheel key is in place, the flywheel is properly torqued and the air gap for the magneto is properly set
Posted on Sep 29, 2009
SOURCE: Walbro Carburetor on Briggs & Stratton Model 28R707
If the float don't float, the needle valve stays open and gas runs into crankcase.
If float floats (has no gas inside) then the needlel is probably worn and needs replacement.
Posted on Sep 30, 2009
SOURCE: The recoil starter on my Briggs & Stratton not engaging flywheel
Andy, Hi, well I would start at the Starter myself, usually the thing called the "Bendix" spring jams up and stops it dead. Pull of the Starter, and power it up, off the unit. This will show you if it snaps in and out.
Sometimes a few judicious whacks with a soft hammer will sometimes free up the spring, if thats is indeed what's wrong. Anyway try that first. before any disassembly.
Make sure the Motor CAN actually be turned, by turning the flywheel, this should show you if the Motor is "Free" enough to move.
Also check ALL electrical connection to the starter. Use a meter and see if you are actually getting a voltage to the starter too. make sure your starter battery is good too.
Below is your support site, for any manuals or parts required. http://www.briggsandstratton.com/maint_repair/
Posted on Jul 21, 2010
Briggs & Stratton 35 Classic. How to fit the cable to drive the tines. Help!
briggs and stratton 35 classic is the model of engine not the rotavator
May 06, 2015 | Briggs & Stratton Garden
Briggs and stratton lawn mower 4 stroke engine
did you hit something while mowing the key way between the flywheel and crank shaft might have sheared it will act like the blade is missing pull back on you while pulling the rope
May 25, 2012 | Briggs & Stratton Briggs Stratton...
I need to find a user manual for a briggs and stratton 4hp engine
always check spark and compression first spark needs to be blue and compression should be 120 but will barely run on 80psi if both are fine rebuild and acid dip carb
May 14, 2012 | Briggs & Stratton Measuring Tools &...
My 26 year old Briggs & Stratton 8 hp engine (on a
Did you remember to "wind" the cord when you replaced it. They normally have a spring type of set up that you have to wind before you bolt everything together.
Jun 30, 2011 | Briggs & Stratton Electrical Supplies
I have just purchase a Sears 22 Lawm mower, with a Briggs and Stratton 158cc engine. I prime the motor it act like it wants to start but then dies. I pull it and try to strat it several more times and it...
The procedure for starting an engine is as follows:
  • Check that you have the throttle in the start position and/or on high revs with choke on
  • Prime the engine by pushing the button about 5 times
  • Pull out the cord until you meet resistance. Then let the cord go fully back into the engine and then pull the cord out sharply. Repeat this until the engine starts but not more than a few times.
  • If the engine doesn't start, try pressing the primer button another few times then try to pull start the engine
  • If the engine doesn't start after a few pulls it may have flooded so leave it for a few minutes before pulling the starter rope
Apr 30, 2011 | Briggs & Stratton Briggs Stratton Intek V...
The pull cord is locking up and wont allow it to turn over
you need to remove the front cover where the pull start Cord is and check for anything that is blocking the Cord a broken spring under the Cord wheel can cause this as well
Sep 23, 2010 | Briggs & Stratton Briggs Stratton 6200...
Pull cord on B&S 6.5 HP OHV engine used on water pump occassionally will get "stuck". Cord pulls out 3-4" only, but then starts normally when pulled at later time (eg 2 hours later). Why? Can I correct...
The Sprag clutch need to be oiled.
Remove cover, remove the top part of the sprag clutch you will see some small balls ensure they are not rusty oil the shaft and put back together.
Hope this tip helps.
r/
David
Dec 20, 2009 | Briggs & Stratton Briggs Stratton Vanguard...
Briggs & Stratton 3hp engine Flymo won't spark/start
First thing, Have you put in New Petrol? You must.
Then all the basics, Air Filter, Clean Plug, Check a spark is there
Oct 13, 2009 | Garden
Garden Logo
70 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
