I have a 42" Plasma Panasonic Viera model TC-P42S10B. I had been off power for 15 days. When I came back and tried to turn it on, the front led blinks quickly green once and than a cyle of: 12 times red blink, off for 2 secs, 12 times blink red, off for 2 secs, ...
  • Daniel Soares Aug 01, 2013
    Now I could find out that 12 blinks means SOS Sound. IC 701 (VILC87F2G081 POWER MICOM) is not signaling /BIAS_MAIN on pin number 21. Without this signal the power supply cannon generate some voltages, including 15Vsound. I have no clue on why isn't IC701 turning on /BIAS_MAIN (pin 21 is always 5V but should go to 0V to turn on the signal). Any clues?
  • 12 Answers
SOURCE: LOST POWER ON A VIERA 42 INCH PANASONIC PLASMA TV
Take the unit in to be serviced.
Posted on Jan 21, 2009
SOURCE: Magnavox 50" plasma Won't Power on/Shut's off/Blinking red LED
The above fix, listed by Tom saved us!! We did as instructed and took off the back of our 50 inch Magnavox plasma tv. We were not sure what we were looking for so we googled capacitator (image) & there was a photo of a fried capacitator! Sure enough we noticed ours were "fried", we took out the board and went to an electronic supply store, bought the 2 capacitators ($2.00 each!!) and then found someone who did tv repair to sauter the new capacitators onto the board. (It is important someone who know how to sauter and recognizes polarity do do this for you) All in all we fixed this following the above instructions for $34.00 and our time. For a month we were told to spend hundreds getting a new power board!
Kudos to you Tom & thanks so much!!
Posted on Feb 02, 2009
SOURCE: tv red blink no start42 plasma philips
Thank you for the help. I actually changed the whole main power supply board and it still did not fix the problem. When I put the new one in, I had the tv on for about 3 hours and then I shut it off. No sooner did I get it back up on the wall and the problem started all over again.When I pulled the original board, the caps all looked fine so I am not even sure the board is bad. Problem is there is no one around me to test it. I am not going back to the same shop that already told me that it was a bad main power supply board. Any other suggestions?
Posted on Jun 25, 2009
tvservice306
  • 458 Answers
SOURCE: Panasonic Viera TH-42PV7HS Plasma does not turn
replaced su or sd board and check sc board
Posted on Nov 10, 2009
phil_frye
  • 295 Answers
SOURCE: Panasonic plasma 50PZ85 power led blink 10 times
Either a bad power supply or a bad processor board.
A Good Service Shop should know what the 10 blinks are indicating.
May be a repair cost between $200 and 400 dollars.
Be prepared -
Blessings,
A/V Media Guy
Posted on Nov 22, 2009
Panasonic viera plasma tv 10 blink code
1. Hold the front panel power button for over 15~20 sec and try.
2. See the youtube video
https://www.youtube.com/watch?v=awnrE3k_G2M
Mar 09, 2016 | Panasonic Viera Tc-p50gt25 50" Inch Full...
Why does my Panasonic Viera VT50 have no picture and red led blinks 3 times
First thing, check the HDMI input and make sure it is firmly connected, same for the power cable, obviously. My Samsung goes similarly nuts if it detects no signal from the currently selected input but after 1-2 minutes it eventually stops and I can change the input source.
Aug 13, 2014 | Panasonic Smart VIERA TC-P55VT50 55" Class...
How to reset tv
hi Tracie,
is the set making a clicking noise?
is the power light flashing on the front?
or no power light at all just dead?
if the set is just dead, just put your ear to the back vents can you hear like a very faint screaming noise and can you smell and burning in the vent?
if so it just could be capacitors on the power board.
if its clicking the that will need a service kit on the power supply board.
if the power led is flashing then you will need to count how many flashers from start to finish when you first turn set on.
hope this helps.
Panasonic TH 42PX75 80 TH C42hD18 Dead TV Repair Fix TXN P1XGTUS HNTUS... Panasonic TV Won Turn On Learn How to Replace Your Power Supply FIX Panasonic Viera 42 inch Plasma SU BOARD TH 42PX75U Diagnosis Repair...
Jun 20, 2014 | Panasonic "Viera Tc P65 Gt30 65"" Class 3...
How to reset a viera panasonic model#tc-p42x5
A tutorial on how to reset your TV at http://shop.panasonic.com/docs/how-to/2013/tv/reset-procedure/How_to_Reset_your_Panasonic_Viera.html
Sep 20, 2013 | Panasonic Viera Tc-p42x5 42" Inch Flat...
Red led power light comes on and flashes 10x. TV will not turn on. What is the problem
Its a error code and usually indicates power supply or something loading that down.
Dec 12, 2012 | Panasonic VIERA TC-P42G25 42-Inch 1080p...
42 inch panasonic plasma television will not turn on
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Oct 19, 2012 | Panasonic Viera Tc-p42x5 42" Inch Flat...
How to hook sound bar to panasonic viera 42 inch model TC-P42X5
The aftermarket audio/video cannot allow you hook your Tv and Dolbys stereos becauses of incompatibility issues.
Jul 24, 2012 | Panasonic Viera Tc-p42x5 42" Inch Flat...
Televison & Video Logo
67 people viewed this question
Top Televison & Video Experts
