Question about Haier HLP23E Top Load Washer
My haier HLP23e will not hold water, as soon as i start it the water just flows out of the drain hose
5 Suggested Answers
SOURCE: Haier XQB55-10 : water leakage from inlet hose jointer
Inside the connector is a flat washer and a mesh filter. one side of the mesh filter has a strip/bar across it, this filter goes into the base of the connector with the strip/bar upwards, make sure it is seated in the connector properly.
Then fit the flat washer ensuring that it is clean/undamaged and lying flat at the base of the connector, the mesh filter strip/bar has at either end a small lip, the washer goes underneath the two lips, if it is placed on top of these lips it leaks!
99% positive on this, if not buy another hose!
Posted on Mar 16, 2009
localwonder
  • 6784 Answers
SOURCE: haier washer machine HLP23E makes a noise
A washing machine may wiggle, rattle or move across the floor. It is often accompanied by excessive, or loud noise. There can be several causes and the problem is worse with some units more than others.The most common cause is an unbalanced wash load. Open the lid/door, and attempt to redistribute the clothing to balance the weight. Heavy loads, especially things like comforters, are more likely to become unbalanced than small loads. If you do a lot of heavy loads, you should consider a heavy duty/large capacity washer when it comes time to replace your current unit. A washer must be level both from side to side as well as from front to back. Washing machines have adjustable feet to enable you to level them. See your manual on how to level your washing machine.The outer tub/basket, is supported by springs, pistons or counterweights to keep it balanced. The weight of all that water in a wash load requires a powerful balancing mechanism. If the balancing system becomes detached from one or more points, it will not be able to balance the load properly. Furthermore, even if everything appears to be in place, as the appliance ages, the springs or pistons/shock absorbers, may begin to wear out and not support as much weigh as needed.
Unplug the washer and open the cabinet. Because of the variety of balancing mechanisms, you will have to inspect your machine to determine how it is balanced. Once you discover the mechanism, then inspect it for integrity. In the case of old parts that appear to be in working order, you may not be able to tell if they need to be replaced. They may be weak but appear to be in good condition. If no other solution resolves the problem, then replacing the balancing springs or other moving support parts may be the best action.Another common cause for excessive movement, or clunking, is the floor on which the washer rests. The washer is heavy and even more so when filled with water. Any floor, other than a concrete slab, will tend to pick up and amplify the vibrations from the machine.There are a couple things you can try. If you have access to the joists under the floor, you may be able to beef up the support. Another thing to try is placing a large sheet of plywood under the washer. It should be 3/4" or even 1" thick and as large as possible to distribute the weight. Use a sheet big enough for both the washer and dryer to sit on. If possible fasten the plywood to the existing floor.
NOTE_ Verify That the shipping system including shipping bolts, spacers and cables are removed. This is a common issue when a new washer is installed.
Posted on Jan 04, 2010
caroldon
  • 17130 Answers
SOURCE: how to change a pump on haier hlp23e
Check this link: drain valve
Posted on Jun 28, 2012
SOURCE: washer is Haier hlp23e portable automatic will not
Hey rosedunn i have the same problem :( ... So what you do with yours???thansk
Posted on Oct 25, 2012
Why does my washer only drain when the hose is at ground level? It also seems to be filling with more water than usual - almost overflowing for a small load of laundry.
the water pump on a washing machine is nothing more that a water stirrer as the vanes are straight out
the pump is full all the time and passes water if the hose is laid on the floor. the fact that it is not pumping indicates that it is not getting power at the right time. or the motor of the pump has malfunctioned O new pump) The over flowing machine indicates that the hose to the pressure switch ( what you turn for the water amount ) is blocked or has a hole in it
With both problems combined it may be a faulty control board so have a washer machine mechanic have a look at it.
May 10, 2015 | Haier HLP23E Top Load Washer
Haier HLP23E - When I press start, the water flows in and out at the same time.
Hi Lina, accordin to the Haier website, E4 stands for "water inlet problem. Water can not inlet or cannot reach the selected level in a proper time.". Unless the ingoing water pressure is really low, I think you need to service the machine. Anyway, hope this helps!
Dec 13, 2014 | Haier HLP23E Top Load Washer
Keep getting a E4 Code
This E4 Phenomena means "no water":
No or slow water fill (not
reaching the full level in 15 min),
therby computer sends display message "E4"
Reasons:
1) The house water tap is not open, or
2) This is the most common E4 reason- The water inlet valve (that the hose is connected to) is blocked.
3) The water pressure is too low and the flow is too weak.
Solutions;
1) Open the water tap, then push the START/PAUSE button again.
2) Clean the water inlet valve. Shut off house water supply on the wall then, unscrew (lefty loosy) each hose from the house and the machine and look for a screen and clean the junk away from the screens. You may have 1 or 2 screens depending on the hose there may be 1 screen where the hose connects to the house and another screen inside the machine valve. Then, return hoses and turn on the water pressure again, Then push the START/PAUSE button again.
3) Wait for the normal water pressure to return to the house before use.
Oct 08, 2013 | Haier HLP23E Top Load Washer
Leaking inlet hose
maybe the pump motor is clogged check that pls.
May 25, 2013 | Haier HLP23E Top Load Washer
WATER GOES INTO MY WASHER AND RUNS RIGHT OUT
tub rubber is torn or cracked can be replaced but for cost u might buy a new washer
Nov 18, 2012 | Haier HLP23E Top Load Washer
My haier front loader was working today then stopped and said error 5 it's model is a hwm1070kFL
The Haier hwm1070kFL error 5 indicates a problem with the incoming water. Either the water pressure is low, any filters in the inlet system are clogged or the water is draining out of the unit (pump malfunction or suction from the drain hose being below the water level in the washer).
The first thing to check is the incoming water pressure. Turn off the valves for the incoming water. Then disconnect the hose from both the washer and the pipe. Check any filters. Reconnect the hose to the pipe and place a bucket below the hose. Turn on the water valve and check the flow rate. (You may want to replace the hose while you have it disconnected. Many modern hoses are designed to seal themselves if they detect leakage. This will stop or reduce the flow of water through the hose.)
Next make sure that the drain hose outlet is 80-100 cm (~32-40 inches) from the floor.
If these steps do not help, you need to check the inlet valve, the pressure sensor and make sure that the drain pump is not moving the water out of the washer during a fill cycle. These may be steps for a service technician.
I hope this helps.
(I live in an area with a rural water district. It isn't uncommon for the water pressure to drop due to problems in the system. Until the maintenance person can find and fix the leak or pump issue, a washer with sensor like this that detects how long it takes to fill the tub will give the low flow error and stop working.)
May 20, 2012 | Haier Washing Machines
Haier HLP23E Top Load Washer Logo
73 people viewed this question
Top Haier Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you a Haier Washing Machine Expert? Answer questions, earn points and help others
