Question about Pool & Spa
Catalina spa I just got a 2003 Catalina CL300 and the Pump keeps running all the time. It ran all night last night and it heated up to 104 when I have it set at 97. I have the filter cycle set for FC8. Does this sound like a sensor malfunction?
3 Suggested Answers
Coastsider
  • 331 Answers
SOURCE: older catalina spa with top controls showing two
Please provide your catalina spa model and year, as well as the spa control system info... You can contact us directly at info@coastsideservices.com. we are a Catalina Service Center and can help you troubleshoot this
Posted on Apr 14, 2010
Coastsider
  • 331 Answers
SOURCE: I have an older Catalina spa with acura controls.
These older style controls are easily repaired but require some electrical diagnosis expertise to determine the problem.
1. Check the pressure switch to make sure it is working properly - Use a continuity checker to see if the pressure switch is closed when pump is running. If not then check for proper water flow. Dirty filter, obstruction in plumbing. If flow is good, replace the pressure switch and see if heater works.
2. Check to see if the heater has 220V at the heater terminals when heater circuit is running. If not, then check to see if the heater contactor (relay) is actuating. Check Hi-limit switch, Thermostat and pressure switch for continuity. If heater has voltage, check for current draw, using a clamp style amp meter around on of the heater wires. look for about 20 amps. If voltage is present but no current draw, the heater is bad.
3. The spa light is a completely separate circuit, check the air switch, air line, button and light bulb. Its a 12V AC circuit.
Posted on Apr 16, 2010
At is my hottub overheating
recirculation pump bad
Oct 09, 2017 | Pool & Spa
My catalina spa keeps popping the breaker and won't turn on
First, we have to establish what you mean by turn on the unit. Is the GFCI breaker set on when you try to turn the "unit" on? What are you activating to turn the "unit" on? A switch, a disconnect, a button on the topside controller, etc.? Need clarification before we proceed to diagnose. At what level do you understand electricity? Is there a licensed electrician available?
Please answer and we will take it from there. OK?
Jul 14, 2014 | Balboa Instruments Duplex Digital Panel 2...
Catalina spa
When the control panel does not light up this means the panel is not working and needs to be replaced.
Rod
US Parts Center
Apr 15, 2014 | Pool & Spa
Catalina spam
Hi, Lori Thanks for the question. It sounds as though your tub froze over and tripped the freeze sensor. If the freeze caution is gone and the tub will not rise to temp, either 1 of the heat sensors or heating element has gone bad. With a bad element or sensor you should have an error code on your topside display. At this point I would recommend contacting a Spa Technician, unless you have some spa repair knowledge or feel comfortable attempting a self repair. I hope I was able to help, Thanks again!
Feb 12, 2014 | Pool & Spa
Catalina Desk assembly instructions
I suggest for you to contact Pottery Barn directly either by phone or email and ask them to send you assembly instructions for the catalina desk. Check out this website to get all the contact information: http://www.potterybarnkids.com/customer-service/?cm_type=fnav
Sep 30, 2012 | Pottery Barn Kids Catalina Storage Desk &...
Just established electric to my 1999 Catalina spa, I cannot get it to turn off
check air switches, or air button tubing disconnected. also if calling for heat and htr does not work pump will run continuously unless you turn t/stat down
Jun 21, 2012 | Pool & Spa
Older catalina spa with top controls showing two jet speeds but only the low speed jet is working???
Apr 06, 2010 | Pool & Spa
Can you locate front rotors for a 69 Pontiac Catalina?
Should be drums in the front of the Catalina?
www.rockauto.com sells RAYBESTOS Part # 1270 which are for the front of the 65-70 Catalina, and 68-70 Catalina Ventura.
"IF" you are talking about a conversion kit to run disc brakes on the front that is a different story.
Dec 04, 2009 | Pontiac Catalina Cars & Trucks
I have a catalina spa with BALBOA CONTROL PANEL
Where are you from?
If you live in the UK give me a call/email as I have worked on lots of Catalina Spas over the years.
http://hottub.synthasite.com
Regards,
Ian.
Jun 07, 2009 | Balboa Instruments Duplex Digital Panel 2...
Pool & Spa Logo
129 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
