Question about Craftsman 26 hp 54 in. Deck Deluxe Yard Tractor - CA Model
Diagram lawn how to get power to the coil
  • Craftsman Master
  • 2,478 Answers
From M on key switch.
Posted on Aug 14, 2013
Wiring diagram diagrams
I just rewired my 782. same wiring as the 682.
All the electrical to the Engine coil runs through the PTO switch. Not sure what your issue is but that's a big failure point
http://www.ihcubcadet.com/diagrams/Electrical%20Schematics.pdf
http://www.ihcubcadet.com/cgi-bin/discus/board-auth.pl?file=/217125/217125.html&lm=1291234823
Jul 29, 2014 | Cub Cadet Garden
How do i replace the coil on my sears craftsman power gear drive push mower?
Go to you tube. On the line type in how to repair lawnmower pull cord
Jun 27, 2014 | Briggs & Stratton Briggs Stratton...
My lawnboy starts but will not shut off. I replaced the coil recently and believe the woring is messed up. Does anyone have the correct wiring diagram for the engine shut off switch?
there should only be one wire to the coil. it plugs into a spade terminal and runs to a kill switch which is usually a piece of metal that comes in contact with a part of the throttle so when you either move the speed control to slow/stop or release the handle the two parts touch and ground out the module
Apr 17, 2014 | Tecumseh Lawn Boy Push Mowers Insight...
Wiring diagram
the wires you have are a ground wire a charging wire if you have a charger and the coil plug wire on a short blocked motor you might have a secondary stop wire to
Mar 23, 2013 | Briggs & Stratton Briggs Stratton...
Tv-5002 pro line, no spark, checked by removing plug and grounding the threads
sounds like the coil went bad but pull the cover and check the wires that go to the coil they could have rubbed on metal and shorted to ground shutting off the coil
Jun 30, 2012 | Toro Power Lawn Mower
Coil on Brigg straton lawn mower does not produce spark
If there is no spark and the wires are ok, face the fact that the ignition unit requires replacement, any amount of testing it is not goig to get you anywhere
Feb 12, 2012 | Garden
I was going to check points on tecumseh lawn mower took flywheel off and no points. someone else had worked on it last. Do you have a diagram Icould look at.
It has a CDI box now, if the spark quit then replace the flywheel key and make sure the coil is not accidentally grounded and test it again.
Jun 14, 2010 | Garden
Wiring missing from harness to coil to card
here is a picture from the breakdown of a 15.5 hp briggs engine hope this helps e8059e1.jpg
Nov 19, 2009 | Mtd Garden
Briggs & stratton 190707 wiring diagram
make sure your coil has not move ajust to 010. gap check magent on flywheel.see if strong.if all is ok yes coil is bad
Jul 21, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
No spark
Make sure you are getting spark from the coil. Then connect the coil wire to the distributor. Then check a plug wire for spark by grounding it with a screw driver. If you are getting spark from the coil, but not from the distributor wire there could be a wire broke in the distributor.
Aug 06, 2008 | Electrical Supplies
Craftsman 26 hp 54 in. Deck Deluxe Yard Tractor - CA Model Logo
15 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
