Question about Android Galaxy Ace
Phone is plugged in to charge, but no power seems to be getting to the phone from the charger. I have tried various plug sockets and there is no power cut. the phone has not been near water. Does the battery need replacing or is it likely the phone needs to be replaced?
    Sergeant:
  • 314 Answers
If itz under worranty better return back
yu may get a new1
problem is wid chrging point or charging ic
better contact customer care or service centre nearby
Posted on Jul 30, 2013
My phone will not turn on
Charge it. Once the battery is depleted, if you plug the phone into a charger, the phone will for some time refuse to show any life even while plugged into a charger. If you have some sort of fast charger, it may come to life almost immediately. Otherwise, you are in for a bit of a wait. How long? -An eternity if you need to make an immediate call or receive on. Otherwise, my "guess" is that it will at least work briefly within a half hour.
Make sure your charger IS plugged into the wall to a working wall socket.
If you accidentally completely powered it down, simply power it up. Seems obvious but you have to eliminate the possibility.
There is always a possibility that the battery is not holding a charge. Ask yourself how old is the battery.
Jul 31, 2017 | Cell Phones
Meos dvd92b not charging
Hello:
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Dec 29, 2012 | Cell Phones
My Nokia E73 won't charge
First Option:
Second Option:
Sep 15, 2012 | Nokia E73 Mode Cell Phone
AT&T Impulse 4g says phone is charging when it is not plugged in. Will not charge when plugged in!
First Option:
Second Option:
Jul 26, 2012 | Huawei Impulse 4G
My motorola Blur won't charge, I've tried other chargers and nothing, it will catch a charge for a second and then nothing, now my phone is dead
My Motorola Blur would not charge kept saying Connect Charger. I tried various power connecters including the Original one that came with the phone and the USB to no avail. This morning I took the phone apart and clean it and still would not recognize the charger.
Fix: I lifted up the connector where the charger plugs into on the actual phone and now it is making contact and appears to now be charging my phone.
Sep 15, 2011 | Motorola Mobility CLIQ Cell Phone
When i plug my charger in i have to move it around for it to start charging and if i move my phone it quits charging its not the chargers i have tired im thinking it my phone. what do i do?
The charging socket on you phone needs to be resoldered, OR the plug on the charging adapter is faulty and needs to be replaced.
To determine which is faulty, use a different charger and plug it into your phone and move the charging plug to see if the it quits charging. If it quits charging then the charging socket on the phone needs fixing (re-soldering).
May 07, 2011 | Cell Phones
Kyocera Wildcard charger doesnt work.
You can go to your carriers retail store and use one of their chargers for free. Then you can determine if it is the phone or the charger.
Mar 01, 2009 | Kyocera wild card Cellular Phone
Samsung sgh p310 wont charge
check to make sure it is connected properly and whether the pins in the phone's charging slot are not broken, because I have a samsung SGH-D807 and I forced the charger in the slot and the pins got broken, it won't charge. I have to repair it.
so connect it properly and check to see if the pins are broken, if not, try another power socket to plug the charger in, not all sockets are compatible with a charger.
Dec 13, 2008 | Samsung SGH-P310 Cellular Phone
Does leaving a cell phone charger plugged in to an outlet at home,without having the phone charging in it,drain energy from your home?
Yes. You are right. Here energy is not the criteria. It is always safe to unplug the charger (when not in use) to prevent the damage of a cell phone due to accidental over load of electricity or short circuits. Moreover Chargers do draw power when plugged in, whether or not a device is actually being charged.
If the charger is plugged in someplace easy to access, like right by where you keep your phone, you should unplug it. But if it would be difficult to have to plug it in every time you need to use it, you'll be fine just leaving it plugged in..and.It still uses energy even when not charging. Any electronic device plugged in a socket uses energy whether it is in use or not.
Oct 07, 2008 | Samsung SGH-D900 Cellular Phone
Sx700 charger
try useing phone charger as long as jack will fit yours
Oct 16, 2007 | Motorola Talkabout SX700 2-Way Radio
Android Galaxy Ace Logo
26 people viewed this question
Top Android Cell Phones Experts
Owen Barnes
Ron Durham
Gregg Errera
Gregg Errera
Level 1 Expert
Are you an Android Cell Phone Expert? Answer questions, earn points and help others
