Question about Whirlpool Duet Sport HT WFW8400TE Washer
Help.....Our duet sport is Very very loud and noisy from start to finish. Made sure it is leveled and balanced. It actually moves on the floor. Friends of ours are having the same problem. This has been a problem since day 1. The performance is good, the noise unbearable.
    New Friend:
Go to walmart and get the swimming pool noodles and put it in between the wall and the washer in between the washer and the dryer and it will help with the noise a hole lot
Posted on Aug 10, 2013
watugot
  • 290 Answers
SOURCE: Washer appears to be out of balance
Double check the screws holding the washer to the pedestal to make sure they are tight and make sure all the jam nuts on the leveling legs are tight. Loose jam nuts are the most common cause of this.
If they are tight, loosen the right front leg and screw it up until the weight is off the floor. Then run it back down until it contacts the floor. Put the washer in high spin and tighten it down to the floor until you get the spot where there is the least vibration. Tighten jam nut, and check it again in spin with a load of clothes.
Post back and let me know how this works.
Posted on Oct 18, 2007
  • 9 Answers
SOURCE: Whirlpool Duet GHW9150PW1 very noisy when spinning
its most likely bad bearings and basket. usually it happens over wear and tear or overloading.
Posted on May 21, 2009
GasPipe
  • 16 Answers
SOURCE: whirlpool duet sport makes very loud noises
How old is the unit?
I would venture to say that your drain pump is failing. Some will make a more louder than usual noise near the end of life. Have you checked the pump strainer yet? If it's clear, go ahead and replace the pump. It's a very easy DIY fix.
btw: remove the lower access panel to the washer. The strainer is located in the pump and will twist out w/a few turns. put something down on the floor (pan, towel, ect) before you remove the strainer for it will empty out whatever is left in the lower tub.
Posted on Jul 22, 2009
  • 53 Answers
SOURCE: My whirlpool duet sport washer often finishes it's
Slow drain. Check your drain hose for kinks and make sure it's not partially plugged. If it is going into a pipe make sure it isn't pushed too far into it.
Posted on Sep 11, 2009
  • 118 Answers
SOURCE: Very Loud and Active Whirlpool Duet Sport Washer
It looks like the transit bolts are still in there at the back and if you take them out it should be more quiet.
Posted on Sep 21, 2009
How to clean drum in fisher paykel washing machine ? Also why so noisy and moving across floor on spin cycle?
bowl out of balance
bowl not level
check for suspension bolts and insulators holding the bowl level
Jul 18, 2016 | Fisher and Paykel Washing Machines
WHIRLPOOL DUET SPORT FRT LODER WASHER VIBRATES VERY BAD
Might be a simple fix. First, make sure your machine is sitting level (or pretty close to level) on the floor. Next, using a Torx bit (probably, that's what my 9250 had), unscrew the screws holding on the front access panel. When you look inside, you'll notice several shocks (usually 4) that stabilize the drum as it turns and spins. Make sure they are all intact and mounted to the drum (they have a tendancy, especially after having been run in an excessively vibrating state, to dismount from the drum). If the mounting pin is intact, stretch the shock to reinsert it into the slot on the bracket mounted to the drum, and turn to lock it into place. If the mounting pin is broken, you'll need to order another (probably the entire shock, actually) to repair it. Also, be sure that you are not overstuffing your washer, as overloading will also cause excessive vibration. Hope this helps!
Dec 07, 2012 | Whirlpool Duet Sport HT WFW8400TW 3.7 Cu....
Extremely noisy!!!!!!
A washing machine may wiggle, rattle or move across the floor. It is often accompanied by excessive, or loud noise. There can be several causes and the problem is worse with some units more than others.The most common cause is an unbalanced wash load. Open the lid/door, and attempt to redistribute the clothing to balance the weight. Heavy loads, especially things like comforters, are more likely to become unbalanced than small loads. If you do a lot of heavy loads, you should consider a heavy duty/large capacity washer when it comes time to replace your current unit. A washer must be level both from side to side as well as from front to back. Washing machines have adjustable feet to enable you to level them. See your manual on how to level your washing machine.The outer tub/basket, is supported by springs, pistons or counterweights to keep it balanced. The weight of all that water in a wash load requires a powerful balancing mechanism. If the balancing system becomes detached from one or more points, it will not be able to balance the load properly. Furthermore, even if everything appears to be in place, as the appliance ages, the springs or pistons/shock absorbers, may begin to wear out and not support as much weigh as needed.
Unplug the washer and open the cabinet. Because of the variety of balancing mechanisms, you will have to inspect your machine to determine how it is balanced. Once you discover the mechanism, then inspect it for integrity. In the case of old parts that appear to be in working order, you may not be able to tell if they need to be replaced. They may be weak but appear to be in good condition. If no other solution resolves the problem, then replacing the balancing springs or other moving support parts may be the best action.Another common cause for excessive movement, or clunking, is the floor on which the washer rests. The washer is heavy and even more so when filled with water. Any floor, other than a concrete slab, will tend to pick up and amplify the vibrations from the machine.There are a couple things you can try. If you have access to the joists under the floor, you may be able to beef up the support. Another thing to try is placing a large sheet of plywood under the washer. It should be 3/4" or even 1" thick and as large as possible to distribute the weight. Use a sheet big enough for both the washer and dryer to sit on. If possible fasten the plywood to the existing floor.
NOTE_ Verify That the shipping system including shipping bolts, spacers and cables are removed. This is a common issue when a new washer is installed.
Dec 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My washer is on the 2nd floor and when its on the spin cycle it makes a very loud noise...why?
Nov 13, 2009 | Whirlpool Duet Sport HT WFW8400TE Washer
My Maytag goes out of balance and bangs loudly
This is usually due to the floor not being perfectly level, and as a consequence the washing machine not standing firmly on all 4 supports.
There should be at least 2 adjustable feet under the machine, try to make it stand as level as possible, with uniform load on all four.
If you have a bubble level it may help you establish, if there's an obvious slope on your floor and adjust the machine so that it's well levelled.
Oct 30, 2009 | Maytag HAV2557 Top Load Washer
Dec 01, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Sports unbalanced...
be sure the 4 screws that hold pedistal to bottom are tight ..next lower washer all the way down run all 4 feet up as far as possible next adj front legs until washer is firm on floor and has no motion when manually rocked ..tighten lock nuts to upper limit of legs to keep them from backing out if still have excess motion try adj 1 leg at a time while in spin ..also possible weak floor ..these machines are quite heavy and need solid flooring..also machine may rock some at low rpm but usually steady at max
Jul 31, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Washer Problem
the shocks have been redesigned, however that does seem to be an awful coinicidence that it would happen right after( sounds more like an unbalanced load your trying to wash, perhaps only a few items?? or maybe all light clothes and a heavy item throwing off the balance, but as far as the mildew smell, make sure your using HE detergent, specifically designed for the frontloaing washers, and use this product to clean your machine. www.affresh.com
May 28, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Oct 18, 2007 | Whirlpool GHW9100L Front Load Washer
Whirlpool Duet Sport HT WFW8400TE Washer Logo
51 people viewed this question
Dan Webster
Dan Webster
Sal De
