Question about Emerson THREADED SHAFT UP RATED - 1.00 HP - EB228
Emerson 1081 pool pump is working but running loud, should I oil it?
  • Emerson Master
  • 1,368 Answers
Fix it, but the longer you let it run the more damage done, search your area for your local pool pump repair guy with free testing,
some of these pumps can be CRAZY expensive NEW but cheap to fix/rebuild/repair/bearings. FYI
Posted on Jun 07, 2017
  • 4345 Answers
SOURCE: I have an Emerson 1081 Pool Pump Motor , every
Well, something is wrong. Either the pump or the wiring from the switch to the pump. Pull the pump and take it to a motor shop and have them check it out.
Posted on Oct 20, 2010
john224
  • 1378 Answers
SOURCE: Wiring up Emerson 1081 pool pump. Using 230V. Is
Thank you for posting your question here on Fixya.com.
There is no polarity associated with the leads in an AC system. You simply have 2 hot wires and you can hook either one to either Line 1 or Line 2. Motor rotation is not dictated by the connection arrangement of these leads. Ground the motor with the grounding wire and again with the bond wire if one is present.
You can remove the riser that is positioned under the motor to allow for a 56 size stator to fit in place of the 48 size stator the original Hayward (AOSmith) motor was.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Posted on Nov 02, 2010
adamh294
  • 310 Answers
SOURCE: Wiring up Emerson 1081 pool pump. Is L1 terminal
For your 240 volt operation L1 and L2 will both be Hot 120volt lines.
Ground to green ground screw and bonding wire to bonding lug (if needed)
Please vote positively for this post if i have helped you.
thanks
adam
john224
  • 1378 Answers
SOURCE: how to replace the seal on a amerson 1081 pool
What brand is your pump? Emerson and 1081 are motor related pieces of information. In general the process is the same for any brand...Disassemble the pump, lock the motor shaft at the end opposite the pump, spin off the impeller, replace both halves of the seal and assemble in reverse order. If you need more specific directions, please comment with the brand and model of your pump.
John
Posted on Dec 03, 2010
UglyPoolGuy
  • 46 Answers
SOURCE: where can i order the impeller (center dish cover)
The impellers for the motor depends on the actual brand of pump that the motor is actually bolted up to. Impellers are available anywhere and once you can let us know what the actual model of the pump (should be a Hayward, Jandy, or it may be an off brand) we can not only provide you with the part number, but also a location where to purchase. What is probably happening is that you are searching for the impeller for an emerson, instead of looking for the imepller for the appropriate pump.
Posted on Feb 07, 2011
I need a manual
For what?
its just a motor.
do you need wiring assistance?
what is the model, code or serial number of the Emerson motor?
and... 1081 does not help!
That just means it's a 'Pool' motor casing.
Feb 16, 2014 | Emerson Pool & Spa
Emerson pool spa pump leaking water-how to change gaskets
Emerson is not the name of the pump, that's the brand of the motor attached to the wet end, and the two together make a pump.
1081/1563 only means that it meets the standards for a pool motor.
provide make and model, for your pump.
Jan 23, 2014 | Emerson Pool & Spa
Emerson 1081 manual
What Emerson model, serial and or catalogue number do you have? 1081 is the basic and generic code indicating that it meets the standards for a pool motor, that's all.
Oct 16, 2013 | Emerson Pool & Spa
Emerson 1081
The 1081 is the designation for a motor that can run continuously (all pool pump motors have that). The motors are generally not cost effective to be repaired.
But, if you are looking for is the manual for the PUMP, see if you can see any identification on the part of the pump that the motor is attached to. Then it should be easy to find.
Oct 16, 2013 | Pool & Spa
How to replace the capacitor on emerson 1081 pool pump motor
remove the bump on the motor make sure power is off then discharge by shorting a screwdriver from the leads to the case then take a picture of wiring or make a note then match it up at a electrical supply store then replace
Jul 07, 2012 | Emerson Pool & Spa
Emerson THREADED SHAFT UP RATED - 1.00 HP - EB228 Logo
97 people viewed this question
Top Emerson Pool & Spa Experts
Jay Finke
Jay Finke
Mike
Ian Kime
Ian Kime
Are you an Emerson Pool and Spa Expert? Answer questions, earn points and help others
