Question about RCA 25250RE1 2-Line Cordless Phone
Display and caller ID no longer visible. Only a bright blue light after changing battery. What else can I do? Is my phone dead?
    Sergeant:
  • 314 Answers
Check the battery at bacside
else go to service centre
probbly display gone
Posted on Jul 30, 2013
4 Suggested Answers
  • 225 Answers
SOURCE: I cannot get the caller ID to work on all phones.
The RCA 25413 phone does not have caller ID capability. I have included a link where you can download the manual. On page 16 of the manual it says in a note that caller ID does not apply to the 25413 model phone.
http://www.rca4business.com/products/pc/pdf/instruction-book/25413RE3.pdf
Posted on Mar 25, 2011
Kumariluraje
  • 12 Answers
SOURCE: How to get Caller ID
give a application in exchange to activate service
Posted on Jul 30, 2009
  • 225 Answers
SOURCE: Hello, we were having phone problem with our main
According to the manual, the RCA 25413 does not support Caller ID. I have provided a link where you can download the manual. The manual is for model numbers 25413 and 25414. On page 8 it details how to turn caller ID on/off for each line under Ringer Tone heading item 6 Note, but the note says it does not apply for model 25413. Hope this helps.
Posted on Feb 24, 2011
I have caller id service with my phone company; Why does my Radio Shack heavy duty wall phone with caller id display all rows of 8's in the caller id area?
It's radio shack... kidding, depending upon the age of it, the lcd black/grey display may have gone bad... from dropping or age or defect.
Feb 12, 2015 | Radio Shack Lands Phones
Why doesn't the LCD display doesn't work?
Does the LCD not work at all? or do you mean that it doesn't display Caller ID information? If the LCD is completely dead, you'll need to get the phone repaired. On the other hand, if it's just the Caller ID that's on the fritz, try this: unplug the base from the power socket; remove any batteries in both the base and the handset; wait one minute; plug the base back into the wall and replace all batteries. This will reset the Caller ID so it works again. (Depending on the phone you may or may not lose settings and memorized numbers.) If this doesn't help, the problem will require a professional repair.
Aug 06, 2014 | Uniden D3097 LOUD & CLEAR Cordless Phone -...
Caller id is not working
hi,
this is because of display problem...or the brightness of the mobile may be low or replace battery.. or change the display...
thanking u
happy new year
Jan 01, 2011 | GE 29385GE1 Corded Phone
AT&T 974 Caller ID has quit.
Unplug everything then replug should reset the Caller ID
Dec 11, 2009 | AT&T ATT-974 Corded Phone
I have three handsets and two of the phones caller id is not show
yes if its fading out .its possible that the battery is causing this.also other possibility is that the internal cicuit of the device is moistened or may be needs to be resoldered as some connections may be loosened up too. its a common problem and will get fixed once above things are checked 1 by 1. thanks.
Jul 08, 2009 | Uniden Cordless Phone
Can't find caller id function on NEC ETW-16DC-1 BUSINESS PHONES SYSTEM
You have to make sure the phone system you have has CID cards in it. What kind of card is in the Electra phone system.
Sep 08, 2008 | NEC ETW 16DC-1 Corded Phone
Caller id display screen
I can't read my caller Id Screen numbers are disappering
Jul 27, 2008 | GE 25951EE2 Phone
Display interrupted
Just fixed mine tonight. Follow instructions on http://www.linux-hacker.net/InfoGlobe/ for globe removal. I used a .020" feeler guage. The solder joints on the small circuit board at the end of the arm are subject to vibration from operation and about a bazillion revolutions before failing. You'll need a good quality soldering iron with a fine tip, some solder wick, a bit of patience and a bright light and some reading glasses will not hurt. I removed the solder and then the small board. I'm using an 800 degree tip, so with something like that you want to get on/off the pads as fast as reasonably possible so you don't cook it. Then I re-tinned the traces and re-soldered the small board onto the end of the arm. At first it didn't want to light up, but on depressing the "Select" button, all was good. Happy to have ol' blue back up and running again :~)
Jul 06, 2008 | Olympia InfoGlobe Caller ID
Caller ID does not work
I FIXED IT!!!  YIPEEE!!
What I did was UNPLUG the base's power unit from the wall... waiting about one minute, and plugged it back in.  That caused it to "reboot" the entire system, and the CID now shows itself.
Mar 06, 2008 | Vtech ia5864 Cordless Phone
RCA 25250RE1 2-Line Cordless Phone Logo
64 people viewed this question
Top RCA Lands Phones Experts
David Burbee
David Burbee
Are you a RCA Lands Phone Expert? Answer questions, earn points and help others
