Question about Amazon Kindle 2
HARD RESET KINDLE 2 - Amazon Kindle 2
    New Friend:
  • 167 Answers
Is it charged?
Hold down power button, may take up to 20 seconds, You should notice screen blink a few times, go black, finally come back to the "boy under tree" page. At this point let go of the button and let it finish resetting itself. After a minute or less it should be ready to go again.
Posted on Dec 12, 2013
I have a 2011 kindle fire, and it won't display a lot of web pages. Is there an update? Or some other fix?
Step 1: Hard Reset: Press and hold the power button for 20 seconds and then release.
Step 2: Power it back on: Wait until the device has completely turned off, then press the power button to restart your Kindle Fire.
If the above doesn't work, Amazon recommends that you try charging the Kindle Fire longer and then trying the hard reset again.
If you still can't get your device to work, you can contact Amazon at either amazon.com/contact-us or by phone at the numbers below:
U.S. and Canada: 1-866-216-1072 Kindle Support: 1-866-321-8851 International: 1-206-266-2992
May 10, 2017 | Tablets & eReaders
Tip
How to reset the Amazon Kindle (useful when the unit is frozen)
Hi.
The Amazon Kindle is known for having several firmware issues, and it is not unusual seeing the unit freezing and not starting.
To start you can attempt doing a soft reset. To do a soft reset press and hold the <ALT>, <Shift>, and <R> keys simultaneously. The Kindle display should go blank for few seconds, and then restart.
If your Amazon kindle is still frozen, try resetting the unit to factory default settings with the hard reset procedure below. Procedure is different, depending on the Kindle model.
All you have to do to reset the Amazon Kindle 2 and Kindle DX is pressing and holding down the power button for about twenty seconds, then release the button and let the unit restart.
If instead you have the previous model, the amazon Kindle one, then you will need to open the back cover by pressing it and sliding it to the right with your finger, same as when you have to replace the batteries.
Behind the cover you will see the reset hole switch.
Push and hold a sharp pointed object, like a paper clip, or the tip of a pencil inside the hole button located under the battery cover.
Wait about ten seconds until the Kindle restarts and resets to default settings.
The last procedure and the picture below refer to Kindle one only. If you have kindle two, then please use the first procedure.
If the above does not fix the problem, then the unit is faulty. In that case contact Amazon to get support.
Regards.
on Feb 21, 2010 | Amazon Kindle Wireless Reading Device
How to reset kindle
Hard and Soft Reset
  1. Make sure the Kindle is turned ON. ...
  2. Press the Power button for at least 20 seconds. ...
  3. Wait for it to reboot - wait a minute or two. ...
  4. Your kindle should be back to a responsive state.
  5. You will have to go through the setup again and then synchronize to put your e-books and other data back on the device.
Kindle Reset Procedures for all Kindles - Brainchamber Blog
www.brainchamber.com/2013/06/15/kindle-reset-procedures/
How to reset kindle Google Search
Dec 30, 2016 | Tablets & eReaders
My daughter bought me a kindle in Christmas 2014. For two days I have had it on charge. It will not open it is locked. I have pressed all knobs but it will not open.
youll need to preform a hard reset to remove the lock if you or daughter doesnt know code.
depends on kindle version.
hold power button in on position for 30-40 sec and let go and restart
or hold power and an android menu will appear
once you get into menu choose wipe cache first and then choose
wipe data/ factory reset and then reboot
this should remove lock
depending on kindle edition their may be a reset hole that needs to be pressed with a paper clip or saftey pin hold reset button for 30-40 sec.
look at second step here
Kindle Fire Reset to Factory Defaults
look at hard reset here
How to Reset Kindle
Nov 10, 2016 | Amazon Kindle
Where is the reset button on the kindle fire?
According to eHow.com: " E-Reader Soft Reset
  • 1 Open your Kindle's Menu while on the Home screen. Do so by pressing the Menu button, or the onscreen Menu icon for Kindle Paperwhite owners. Select the "Settings" option.
  • 2 Choose "Menu" again from within the Settings menu. This displays a different menu than before.
  • Sponsored Links
  • 3 Choose the "Restart" option. Wait while your Kindle powers off and on again.
E-Reader Hard Reset
  • 1 Charge your Kindle e-reader before performing a hard reset. Charging helps ensure your problem isn't related to the device having a low battery.
  • 2 Hold down the Power button for 20 seconds. The screen will change after a few seconds, but continue holding the power button for the full 20 seconds before releasing.
  • 3 Wait while your Kindle restarts.
E-Reader Factory Reset
  • 1 Press your Kindle's Menu button. Select "Settings" from the menu.
  • 2 Open the menu once more from within the Settings window. Select "Reset to Factory Defaults," or "Reset Device" if you're using a Paperwhite.
  • 3 Select "Yes" in the confirmation window after reading the warning. Wait while your Kindle restarts and restores.
Fire Soft Reset
  • 1 Hold the Power button down for three to five seconds. A Shutdown window appears.
  • 2 Tap the "Power Off" button in the Shutdown window. Wait for the Fire to shut down completely.
  • 3 Press the Power button to turn the device on again.
Fire Hard Reset
  • 1 Plug your Kindle Fire in and give it time to charge before performing a hard reset. This helps ensure your issues aren't related to having a low battery.
  • 2 Hold down the Power button for 20 seconds. The Kindle Fire will shut down.
  • 3 Press the Power button to turn the Kindle Fire back on.
Fire Factory Reset
  • 1 Swipe your finger down from the top of your Kindle Fire's screen, presenting the Quick Settings menu.
  • 2 Tap the "Settings" option and select "Device."
  • 3 Select "Reset to Factory Defaults," then tap the "Reset" button. Wait while your Kindle Fire restarts and restores.
Read more : http://www.ehow.com/how_6122863_reset-kindle.html
May 10, 2015 | Tablets & eReaders
How to unlock kindle fire
Forgot my password
Did you forget the password used to unlock your Kindle? If so, you'll need to reset the device to gain access. By resetting, your Kindle will be restored to factory defaults, which means your registration information and content will be removed, and all settings will return to the defaults.
To reset a Kindle Fire 1st Generation:
1. From the lock screen, slide the Unlock Bar from right to left
2. Use the keypad to enter characters into the password/PIN field four times
3. You'll be prompted to reset your Kindle Fire. Tap "Ok reset"
To reset all other Kindle Fire models:
2. Use the keypad to enter characters into the password/PIN field five times.
3. When prompted to reset your Kindle Fire, tap "Reset"
To reset a Kindle 2nd Generation, Kindle Keyboard, or Kindle DX:
1. Slide and release the power switch to turn on the device or exit sleep mode
2. Enter "resetmykindle" in the password field and press the enter key on the key pad
3. Wait several minutes while your Kindle restarts
To reset a Kindle (5-way controller):
1. Press and release the power button to turn on the device or exit sleep mode
2. Select the keyboard key once on the password screen and enter "resetmykindle" in the password field, then select "Enter"
To reset a Kindle Touch or Kindle Paperwhite:
2. Tap the password field to bring up the onscreen keyboard
3. Enter "111222777" and select "OK"
If you don't remember your Parental Controls password, you can deregister your device instead of resetting, as long as you're connected to a wireless network. You'll need to redownload your content, but items that were transferred via USB will be kept. Here's what to do:
1. Visit the Manage Your Content and Devices (www.amazon.com/manageyourkindle) page on your computer
2. Select the "Manage Your Devices" link
3. Select "Deregister" to deregister your device from your account
Sync your Kindle, then register again.
If you need help with your Wi-Fi password, please contact your Internet Service Provider or router manufacturer.
Feb 25, 2015 | Amazon Kindle Fire HD 8.9"
My Kindle won't turn on after I charged it. I charged it because the 2 books I bought did not show on the kindle.
The Kindle touch and the Kindle FIre are great devices for you reading needs. However, there are time when it becomes unresponsive and freeze on you. Amazon says it is because the battery isn't charged properly or does not have enough power on it. It is advisable to charge your battery first before trying to reset the Kindle touch/Fire. If theKindle still has issues, then try the steps below on how to reset your Kindle touch. Please note that you may lose you data during the reset process, make sure you have made a backup of your files before proceding.
Hard and Soft Reset
  • Make sure the Kindle is turned ON.
  • Press the Power button for 20-30 seconds until it turns OFF.
  • Wait for it to reboot, if it doesn't press the power button to turn it ON.
  • Your kindle should be back to a responsive state. hope this helps
Dec 20, 2014 | Amazon Kindle 1
My kindle will not turn off
Did you try
Instructions
  1. Frozen Screen or Unresponsive Kindle
    • 1 Unplug the Kindle.
    • 2 Move the power button to the right and release. You should see a green LED light for two seconds.
    • 3 Move the power button to the right and hold for five seconds. The green light should blink three times and then the screen will go blank. Release the power button after it does.
    • 4 Turn the device back on by sliding the power button to the right and releasing it.
    Perform a Hard Reset
    • 5 Perform a hard reset if the previous steps are unsuccessful or if the Kindle screen is showing lines.
    • 6 Slide the power button to the right.
    • 7 Hold for 15 seconds.
    • 8 Recharge the battery if the device continues to be unresponsive.
    • 9 Restart the Kindle after charging.
Read more : http://www.ehow.com/how_7655306_reset-kindle-3g.html
Jul 29, 2014 | Amazon Kindle 3G
How do you reset a kindle
Hold down the 'on' switch for 20 seconds and then release. This will reset your Kindle without losing any books.
If you want to restore it to factory settings (and remove all content) then follow these instructions:
http://www.hard-reset.com/amazon-kindle-hard-reset.html
Feb 23, 2013 | Amazon Kindle Wireless Reading Device
Amazon kindle reader reset
To perform a hard reset of the Kindle just press and hold the power on button for 20 seconds as described in the Kindle Support web site for dealing with Frozen devices.
If you want to reset your Kindle back to Factory defaults then you would need to press the Menu button, then go into Settings and you will find an option there to Reset to Factory Defaults.
Dec 30, 2011 | Amazon Kindle Wireless Reading Device
Amazon Kindle 2 Logo
79 people viewed this question
Top Amazon Tablets & eReaders Experts
Lesley Cameron
Lesley Cameron
castletech
castletech
Are you an Amazon Tablet and eReader Expert? Answer questions, earn points and help others
