Dometic duo therm 620315
I need the part number for the capacitor for the Dometic 620315.321 air conditioner. I would also like to have a picture of it.
SOURCE: I have a dometic duo-therm. No air coming through ducts.
I have a new Montana Mountaineer with a Dometic Duo Therm as well and experience something similar.
It appears that there are two options:
1. Open the vents in the unit and all the cold air will blow out of the AC as that would be the shortest path and the there is hardly any air coming out of the ducts.
2. Close the vents in the unit and it will force all the air through the ducts.
We let the air blow straight out of the unit during the day and then force it through the ducts at night to force it in the bedrooms. You could also open the vents in the unit part ways to get a combination.
I didn't figure it out immediatly either, but just look close at the unit and you can see that you can close the vents on the unit itself
Posted on Apr 20, 2009
  • 400 Answers
SOURCE: Dometic Duo-Therm - 13,500 B.T.U. Model #3107541.009 - Serial # WA346967 - Yr. 1999-2000. Blower motor will not start. Replaced the start capacitor - no help. It will run by spinning the motor by hand
Yes you should try replacing the run capacitor.
Posted on May 08, 2009
motor1258
  • 6674 Answers
SOURCE: My Duo-therm Brisk-Air by Dometic rv ac wont cool.(The fan runs )
Usually just listening closely will give you a rough idea where to look for problem. When you have the fan on and switch to cool, (with temperature turned down low obviously) do you hear any type of "moaning" sounds from AC unit, or see lights in RV dim slightly indicating that compressor is trying to engage? Is the breaker tripping when compressor tries to engage? Do you hear a "click" from AC unit when switched to cool? If none of that happens, then I'd start thinking thermostat, or compressor relay. Normally if it's a faulty capacitor, the compressor will try to engage but will make a "moaning sound" and usually trip the breaker due to excess current draw. Someone experience in electrical should be able to test relays etc, but whoever does work on it, should be aware that those capacitors, as well as hydro in general are very dangerous to work with. The ("zap",- Shock) that you can experience from a capacitor or hydro, can be fatal.
Posted on May 30, 2010
motor1258
  • 6674 Answers
SOURCE: Rooftop RV Air Conditioner: replaced capacitor on dometic 59516-531 steal trip...
You need to borrow a clamp on style amp gauge, and check amp draw on black wire in box where hydro wires connect. (PLEASE, be careful, and if not experienced in this type of test, don't try it, due to likelihood of getting a shock. ) If it's the compressor kicking in that's causing the breaker to trip, and capacitor is good, then it's usually a problem with either low incoming (supply) 110-120 AC voltage, which will cause high amperage draw, or compressor on it's way out causing high amp draw. If it's only drawing 15-18 amps, and your tripping a 20 amp breaker, then breaker is getting weak.
Posted on Jun 05, 2010
heatman101
  • 43501 Answers
SOURCE: Dometic Duo-Therm Model 57915.622 Fan will not start.
Hi, Sounds like your fan motor has gone bad...
Here is a tip about trouble shooting your air conditioner...
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Posted on Jul 19, 2010
Duo-Therm A/C can not find model number.
try to remove capacitor from mounting bracket might be able to read mfd on cap.
Jul 12, 2010 | Dometic Rooftop RV Air Conditioner
Heating & Cooling Logo
56 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
