Ion usb turntable
Is there a software patch that allows the ION USB Turntable on Windows 8?
  • 476 Answers
SOURCE: cant get sound out of speakers when connected to my ion usb turnt
How exactly have you got this equipment set up thanks ???
If you play another song on the computer from a cd original then what sort of output do you have???
Is the sound clear and complete???Bass Treble Mids etc
If the turn table has been set up properly the you will get a signal from the record deck to the computer and head phones too via the mixer.
Next is to check the way sound gets from the usb to the computer
Maybe the USB drivers are required for the computer before it will play correctly.
Try to uninstall then reboot and reinstall.Check again
If this doesnt work then try the make and model of the usb turntable and check to see if there is an updated driver for you computers type or brand or Operating System.ie - XP or Vista
Hope this helps ,let me know if you need more help,
Misterdj
Posted on Jan 19, 2009
  • 14 Answers
SOURCE: Need drivers for my ION Audio USB Turntable
Drivers are not necessary. Connect the TTUSB to a USB port on the computer (not on a hub or in the front panel) and the device will install as "USB Audio Device" From there, you can use Audacity (freeware from Sourceforge) or the Mixmeister EZ Vinyl Converter software they ship with the unit to record.
Here are direct links to the software and documentation:
EZ Vinyl Converter (PC)
EZ Vinyl Converter (Mac)
Audacity Software Guide
EZ Vinyl is pretty much get-up-and-go. The guide I have is basically "start it up, hit "record"
Note: when you hook up the TTUSB, it will become the default output device. You will need to go into the sound options in XP and Vista to change the default output device to your usual audio devices.
Posted on Jun 23, 2009
  • 14 Answers
SOURCE: HOW TOTRANSFER FROM CASSETE DECK VIA ION USB TURNTABLE
Ignore the smart-alec response above. He obviously doesn't understand the purpose of the "audio in" jack on the turntable.
I assume that you can record via the turntable ok so it's not a matter of getting the sound from the TTUSB to your computer..
You may have tried these already, but these standard troubleshooting steps are worth going over:
- Make sure the tape-to-tt patch cable is pplugged in to the LINE OUT on the tape deck and plugged into the 1/8" socket on the TTUSB. Make sure all conections are firmly seated. Do not make a connection from receiver to the TTUSB as it may overpower the TTUSB circuitry.
- Does the tape deck have an output volume control? Make sure it's turned up.
- Adjust the GAIN control on the bottom of the TTUSB
- If still no sound, change patch cables. You could have a bad one.
- If still no sound, then it's possible you have a defective unit with a bad audio jack.
Posted on Jun 25, 2009
  • 28 Answers
SOURCE: Ion USB turntable is not recording both stereo
CHECK TO SEE IF YOU ARE GETTING SIGNAL ON BOTH CHANNELS OUT OF THE TURNTABLE IF ONLY ONE SIDE FAULT IS AT THE CARTRIDGE CHECK CONNECTIONS AT REAR OF THE HEAD SHOULD HAVE 4 IN PLACE
Posted on Nov 04, 2009
CW Oly
  • 240 Answers
SOURCE: When using the ion profile lp usb turntable as
Check for lint or dirt on your stylus. Be sure that the player is grounded.
Posted on Jan 15, 2010
Bad sound quality
You cannot connect the turntable via a microphone port. You need to connect via a USB port. If you have not got a USB port to connect it as the others are in use, you can buy an extension USB socket which, will allow you to put more devices via one USB port.
Sep 04, 2013 | ION Audio Vinyl Recording Turntable
Ion USB turntable
You can only contact the maker of the turntable.
Jan 13, 2013 | ION Audio Vinyl Recording Turntable
I purchased a Vibe Sound 3 Speed Turntable w/USB to PC and it does not have sound when I plug it in to the USB. The record is spining and I can hear sound from the needle.
The turntable won't make sound on its own when connected to the USB port. There are probably some drivers on the CD packed with the table that you'll need to install, and then you'll need to select the device in the Windows sound control panel. You'll also need some software to record and edit your vinyl if you want to transfer your records to CD.
I'm not familiar with the brand of turntable you have, just the ION, but it probably came bundled with some application on a CD. The ION table comes with Audacity, as well as some trial versions of audio processing (click and pop filter, hiss remover, etc.). Audacity is free, open-source software you can download here if you want it. It allows you to listen to and record your vinyl audio as wave files, then edit it, split tracks, add effects, and other fun things.
Feb 13, 2011 | Computers & Internet
Will the Ion Turntable work with Windows 7? I only see XP and Vista listed in the manual.
If your ION turntable is a USB basedwith a USB plug it will work. Just plaug it into your USB posrt. A driver may need to be downloaded from the ION website for windows 7
Dec 02, 2010 | ION Audio Audio Players & Recorders
My ion USB turntable picks up sounds from the room and adds them to the file
Try reducing the audio imput to your computer and make certain the computer microphone isn't switched on during recording etc. IE the Sound Control on your computer (such as SoundMax).
Jun 26, 2010 | ION Audio Audio Players & Recorders
Can't hear playback. Windows Vista - Playback device says usb Audio Codec
here is what ION is telling people (short version) this is for vista or win7
1. Visit www.ionaudio.com/ezvc to download the latest EZ Converter software.
2. install new software if needed,
3. connect ION Audio USB. make sure its ON (if it has a switch)
Setup Procedure
1. Start then Control Panel.
2. double-click Hardware and Sound.
3. double-click Sound.
4. At top select Playback tab. choose the audio output device.
Don’t chose “speakers-usb audio codec” (that’s your ION) don’t chose modem
5. click Set Default.
6. select Recording tab at top of Sound Control Panel. choose "Microphone – USB Audio Codec" as the default device. (that’s the ION)
7. Click Set Default.
8. click Properties. select Advanced tab
9. set the Default Format setting to 2-channel, 16 bit 44100 Hz (CD Quality).
10. Un-check the two boxes under Exclusive Mode. Click Apply
11. select Levels tab from the top of the Sound Control Panel.
12. Set the level slider to 4. Click Apply, click OK to close the window.
Have everything set up and running, if you have to call this number for help.
401-658-3743 ext. 1405
Jun 25, 2010 | ION Audio iTTUSB Turntable
I'm thinking this is 100% impossible. There is absolutely no way you can get a cassette tape to play on a turntable.
Apr 07, 2009 | ION Audio Vinyl Recording Turntable
Do I need the latest EZ Ripper software download
always use the newest (highest) version number so in this case use the CD version of the software.
Jan 06, 2009 | ION Audio Vinyl Recording Turntable
109 people viewed this question
 Grubhead
Grubhead
