Question about PowerStroke 1700 PSI Electric Pressure Washer PS171433D
How to remove pump from pressure washer - PowerStroke 1700 PSI Electric Pressure Washer PS171433D
    Sergeant:
  • 402 Answers
If motor has great compression you should get 2200 psi
Posted on Aug 06, 2013
Will not pump above 3000psi?
probably has a relief valve in the pump head that prevents over pressure from damaging the pump
3000 psi is extreme for a pressure washer and will remove paint from a vehicle , blow out gaskets on engines , remove cement surface , peel timber surfaces
Sep 08, 2015 | Comet TW 5050 S - Pressure Washer...
Can't remove pressure washer pump from engine
Look closely. There should be a set pin or set screw on the shaft holding it in place. If not you will have to take apart the pump or the motor to get it off.
Apr 13, 2014 | Homelite Pressure Washer Pump 308653006
Can't remove pump from pressure washer
corrosion on shaft, keep tapping with hammer and levering off, spray shaft if possible and allow soak time, please be gentle, keep tapping. stay away from bolt holes as they are the weakest point, usually time to replace pump head,
How to remove pressure washer pump 308653006
There should be just 3 bolts that hold the pump and engine together.
then the pump should slide off
Apr 12, 2014 | Homelite Pressure Washer Pump 308653006
How to change powerstering pump chevy uplander
I just finished replacing mine.
It is much easier if you do these steps:
1. Remove the serpentine belt.
2. Remove the nuts holding the main fuse box over the battery.
3. Remove the reinforcing bar over the battery.
4. Remove the battery.
5. Remove the windsheild washer tank.
6. Now you have access to remove the pump pulley. Without removing the stuff, it may be possible, but it will be extremely difficult.
7. Remove the pump pulley.
8. Loosen the high pressure hose fitting.
9. Remove the return line clamp.
10. Remove the power steering pump mounting bolts.
11. Remove the high pressure hose fitting.
12. Remove the power steering pump while sliding off the low pressure hose.
13. Remove the clips holding the reservoir on the pump.
14. Remove the reservoir.
15. Install new o-ring on the reservoir.
16. Install reservoir on new pump.
17. Install clips to hold reservoir on pump.
18. Install new o-ring on high pressure fitting.
19. Place new pump in position while sliding on low pressure hose.
20. Loosely attache high pressure fitting.
21. Tighten pump to mounts.
22. Tighten high pressure fitting.
23. Install clamp on low pressure hose.
24. Install power steering pulley.
25. Install washer reservoir.
26. Install battery.
27. Install reinforcing cross member.
28. Install fuse panel.
29. Install serpentine belt.
30. Bleed the power steering system.
Dec 13, 2012 | 2008 Chevrolet Uplander
Cat pressure washer pump model 4hp40g1 no pressure and then quits, what could be wrong?
Sounds like you may need to remove the valves to check for any dirt etc. Is the machine juddering when on pressure. If so then it will be the valves that just want removing and cleaning
Jun 13, 2010 | Caterpillar Cat Pump Pressure Washer Pump...
Replace pump on a darcher k2400 hh pressure washer
There is a bolt item 8 below on the very end of the drive shaft that has to be removed before you can remove the pump assembly.
See page 16 item 8 of this Manual: (<-click and download
Then you should be able to remove the pump.
Thanks for using FixYa.
Kelly
May 11, 2010 | Karcher 2500 PSI Pressure Washer
My maytag washer leakes, all the water runs out on the floor.
Remove the rear access panel to check the source of the leak. The drain pump is most probably broken or the sump hose is damaged or detached from the tub.
Drain Pump Removal/Replacement Procedure (Maytag Neptune MAH5500B)
  1. Safety first. Unplug the machine.
  2. Remove the hose clamps and hoses from the pump.
  3. Disconnect the wiring harness from the pump and the pressure switch terminals.
  4. Rotate the pump assembly counterclockwise and remove it from the base of the washer.
  5. Remove the plastic bag covering the pressure switch.
  6. Press in the locking tabs on the back of the pressure switch and pivot the pressure switch off the pump bracket.
  7. Grasp the pressure switch and lift the nipple off the pump cap.
  8. Install the pressure switch on the new pump in reverse order of the removal steps.
  9. Install the new pump in reverse of the removal steps above.
Jan 21, 2010 | Maytag Neptune MAH5500B Front Load Washer
Poor pressure
i had this same problem on my pressure washer.the pump had some broken parts in it .i found my replacement pump on EBay.
May 29, 2009 | Karcher 2500 PSI Pressure Washer
How to change oil in a pressure washer
From the manual CleanShot 2050 Briggs and Stratton
Change Pump Oil
1. Drain engine oil and fuel from pressure washer
2. Use an 8 mm allen wrench to remove black pump oil cap between high pressure outlet and garden hose inlet.
3. Tiltl pressure washer to drain oil into an approved container until it drips slowly from pump.
4.Tilt pressure washer in opposite direction and empty premeasured pump oil bottle into same opening (a small funnel may be helpful) [THIS IS WHAT THE MANUAL SAYS-NOT CLEARLY WRITTEN IN MY OPINION OR WRITTEN BY SOMEONE FOR WHOM ENGLISH IS A SECOND LANGUAGE]
5. Install black pump oil cap and tighten firmly.
6. Set pressure washer in upright position. Add fuel and engine oil.
From the engine manual use synthetic 5w-30, 10w-30 from -20 degrees F to temperature of 100 degrees F.
Change oil after 5 hours of operation initially. Before tipping to drain oil, remove fuel from fuel tank by running until tank is empty. Remove oil cap and dipstick and tip engine. Keep spark plug side up. Or remove drain plug from the bottom of pressure washer with a ratchet and square extension and drain oil from bottom. (fuel does not have to be removed)
May 21, 2009 | Briggs & Stratton Pressure Washer...
PowerStroke 1700 PSI Electric Pressure Washer PS171433D Logo
168 people viewed this question
Top PowerStroke Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a PowerStroke Garden Expert? Answer questions, earn points and help others
