Question about Dryers
Panasonic AV Control Receiver SA-DT100 fan motor
Replacement of fan motor, part no?
Is there a docking device for connecting iphone with panasonic receiver
There are lots of docks, but they all connect via USB
https://www.google.ca/search?q=iphone+6+plus+dock+connector&rls=com.microsoft:en-CA:IE-ContextMenu&biw=1366&bih=643&source=lnms&tbm=isch&sa=X&ved=0ahUKEwjMh9Hpg97QAhVPVWMKHVosD3kQ_AUIBigB#tbm=isch&q=iphone+6+plus+dock
Your receiver only has s-video.
Total Harmonic Distortion 0.7% (6ohms) (at 20Hz-20kHz)
  • S-Video Inputs/Outputs 5 inputs, 1 output
  • Video Inputs/Outputs 5 inputs, 1 output
  • Video Rec Outputs 1 output (with S-Video)
  • Front Audio Inputs 1 input (S-Video)
  • Digital Inputs/Outputs 4 in (3 optical, 1 coaxial)
  • Audio Inputs/Outputs 6 in, 1 out
  • VIERA Linkā„¢ HDAVI Control 3
  • HDMI Input/Output 3 in, 1 out
  • Dimensions (H x W x D) 6 1/4'' x 16 15/16'' x 13 11/32''
  • Weight 11 lbs
    Panasonic SA BX500 AV Control Receiver with High Quality Amplifier Decoder...
  • Dec 05, 2016 | Panasonic Audio Players & Recorders
    The cord that goes from the receiver to the subwoofer. Where can I buy a replacement?
    It depends what kind of plugs are attached to it. But I am certain you can get one from Amazon. I don't think it is a specialised cable just made for the Panasonic.
    Just search for "subwoofer cable" on Amazon and see if it looks like yours.
    Aug 17, 2015 | Panasonic Technics Sa-gx170 Av Control...
    AV CONTROL RECEIVER SA_HE7 F70
    F70 error checking fixed contacts fuses.
    Oct 04, 2013 | Panasonic SA-HE7 Receiver
    HELLO, I NEED A REMOTE CONTROL FOR MY PANASONIC SA-DT100
    Improve the Fixya experience for everyone by voting.
    A replacement unit is available though the unit is no longer produced. My database shows a supplier who will ship you a new one for $34 including shipping. If you are interested, CLICK HERE.
    Apr 29, 2012 | Panasonic sa-ht800V Home Theater Audio...
    Panasonic AV Control Receiver SA HE7 error code F70
    solution about f70 on my amplifier to remove
    Jun 07, 2011 | Panasonic SA-HE7 Receiver
    Hello i get the F61 err on my Panasonic SA-DT100. i have cleaned the fan and it works but still i got the error
    Maybe the fan doesn't rotate at the proper speed. Try to put some oil on the bearing sleeve or even replace the fan.
    If it offers resistance it will show F61 and disconnect.
    Nov 16, 2010 | Panasonic SC-DT100 System
    Panasonic SC-DT100 flat cable
    ON SCDT100 has only TV/AUX IN the flat cable is only for Panasonic Devices, so you only option has TV/AUX IN,you need the comb. AV cable from WD media player and connect to TV/AUX INPUT
    Jan 17, 2010 | Panasonic SC-DT100 System
    Panasonic av control receiver sa-he200
    On any 5.1 system without 2 zone capabilities when you press speaker "B" the receiver uses the rear channel amplifiers to send signal to the remote speakers. As a result the receiver cannot output signal to both the rears and the remotes at the same time.
    Feb 26, 2009 | Panasonic Audio Players & Recorders
    Need 5 Digit Remote Code for a Panasonic Receiver HE-100
    Try 1518 or 1039
    /www.comcast.com/remotes/universal.html
    Dec 12, 2008 | Panasonic SA-HE100 Receiver
    PANASONIC Home cinema SC-DT100 - Flat cable connection
    Hi, when you say it doesn't work, will it just not play/read the disc? Mine has to be "initialized" every time or it shows "No Disc". To initialize I turn the unit on then press and hold "Stop" on the unit and the "10-" button on the remote, then it works fine.
    Aug 01, 2007 | Panasonic SC-DT100 System
    Dryers Logo
    175 people viewed this question
    Top Dryers Experts
