Im looking for a firmware upgrade for qr130 multimedia standard player can any1 help
  • 19 Answers
SOURCE: Creative Zen Touch firmware problem
Before preceding, goto control panel, add/remove programs (vista equivalent) select windows media player and uninstall note the response it gives you. If it is going to allow you to uninstall OR downgrade windows media player to version 9 then keep going. If not, then find another computer that you've never used the player on try upgrading firmware there, make SURE it's got windows media player 9 by downgrading it in add/remove programs.
Now for the fun stuff:
Sounds like the same problem I've resolved several times in the past on here.
1. Plug in the device.
2. Goto device manager in control panel and remove the device drivers.
3. Reboot if it asks you to, make sure to unplug the device.
4. Goto device manager again, remove the USB hubs.
5. Don't reboot.
6. Goto control panel, add remove software or equivalent for windows vista ultimate.
7. Select creative labs, and uninstall any and every zen related software.
8. Don't reboot.
9. Goto my computer, find the creative directory located on your main hard drive at \program files\creative. Deleted it completely.
10. Select windows media player select uninstall, or downgrade accordingly.
11. Make sure your zen touch is not plugged in and reboot your system.
12. After system loads, plug in the device and run the firmware software again.
And if you wish, reinstall windows media player 10 and the creative software (which you don't need at all with vista) all the other drivers should reinstall themselves.
BTW it's a hell of alot easier to just use another CPU if you have access to one, I've done it both ways and it saves alot of time.
Posted on Mar 24, 2008
Psionics
  • 236 Answers
SOURCE: TGE MP4 Player Firmware Upgrade
Did you download the correct version of Firmware? There are 3 different types for your model (i'm guessing you have the HB500).
Not too sure if there is a reset button on the player.. If there is, use that..
Otherwise, download the firmware again and reinstall it
Posted on Mar 28, 2008
SOURCE: Sansa c250 firmware
Hi, try this link-It works
http://www.sandisk.com/sansa/#/support-0/
Posted on Sep 25, 2008
I had the same issue after trying to update firmware the PC kept saying the player was not connected, I have copied the reply below from Creative Customer Services on how I fixed this problem. I was lucky that I have access to an old PC that had WMP 10 so I didn't need to mess with my own PC. However, there was some messing about with the instructions to get the fix. My main tip is follow the instructions below, then go to device manager and uninstall the Zen from your USB list, it will probably be flagged with a yellow triangle. Remove it totally and then reinstall the Zen driver, this worked for me after I had taken the steps listed here;
1. Please uninstall all Creative software & Drivers.
2. If WMP 11 is installed, remove it including Media Player 11 runtime
(may require a reboot for each thing).
Go to add/remove programs and uninstall these two files (this will put
your pc back to wmp10). http://support.creative.com/kb/ShowArticle.aspx?sid=16737
Related topic is further explained on this page http://www.microsoft.com/windows/windowsmedia/player/11/readme.aspx#DevicenotrecognizedafterinstallingWindowsMediaPlay
3. Download the following files from the website and save them to a
unique folder.
http://support.creative.com/welcome.aspx
You may have to select your own Product > Choose your Specific Model>
then Double Click.
Down below; please ensure that your Operating System selected is Windows XP.
Driver : Creative Zen and Jukebox Driver Upgrade version 1.30.03
Firmware: Creative Zen Touch PlaysForSure Firmware 2.11.01
You may want to click the Show Details button on the right side for
additional information.
4. Re-install the Zen Driver and reboot the PC and then connect the
player.
5. Make sure the firmware update is ready,
Run the program but don't click the language bit yet), leave the mouse
hovering over your language selection.
6. On the Zen - select the option "reload OS"
7. As soon as it flashes up "reload new firmware now via USB" click the
language button on the firmware.
8. Now PC should find it and allow you to re-load the firmware. (it may
take a few attempts)
9. Once complete, click close and restart the pc. Everything should now
be fine.
10. If installation is successful, you can re-install your WMP11 and
everything should be okay this time.
Good luck
Posted on Oct 19, 2008
SOURCE: Samsung yp-p3 firmware upgrade
Place the bin just inside the P3(not in any of the folders) and then disconnect from the computer and power it back on. It will check the firmware and turn on and off a time or two. When it's off and doesn't turn back on power it back on yourself and you're done.
You can check your FW version by going to settings>about on your P3.
Posted on Aug 23, 2009
Any of the multimedia applications (Gallery, music player) are not responding on my Nokia N72
sir i am also using nokia n 72 !! it seems that there is some problem with your phone's firmware!! you should upgrade your phone's firmware!! it can be done at home using nokia pc suite and internet connection!!the firmware file is about 40 mb in size and you have to download it!! or go to nokia care !!they will take rs 200 from you and upgrade your phone's firmware!!
Upgrading at home is a little bit risky!!while upgrading if you accidentally sidconnect your phone, or there is a power cut off then your PHONE WILL BECOMES USELESS!!!
Oct 24, 2009 | Nokia N72 Cellular Phone
Recommended blue ray players??
The firmware upgrade issue for blu-ray players is one that is causing alot of consumers and enthusiasts alot of headaches. But upgrading firmware is not going to go away.
Therefore, I would have to advise that for ease of use, choose one that has an option to connect to the network directly, such as Sony's BDP-S350. A network connected device will find the firmware upgrades itself so you don't have to find it and burn it and load it, etc.
Oct 07, 2009 | Sony BDP-S300 Blu-Ray Disc Player
GETTING ERROR CODE HDD FATAL ERROR 50..CABLE TYPE RGA OR HDMI IS THE SAME ERROR CODE
Do you hear any clicking sound when the player is switched on?
If so the HDD has become faulty. This normally happens when the player is dropped. You need to replace the HDD but if you are on warranty get a replacement for free. Never say you dropped it as the warranty will be void.
If you do not hear a clicking noise try to format the player and see whether it helps. Also look for the latest firmware upgrade from the manufacturer.
Jul 26, 2009 | Iomega ScreenPlay TV Link Ultra-Compact...
PC OR VIDEO PLAYER HOW TO Firmware upgrade http://cgi.ebay.com/2-5-USB-2-0-Multimedia-Ext-IDE-HDD-Player-w-Remote_W0QQitemZ320300327353QQcmdZViewItem?hash=item320300327353&...
to upgrade your pc video card firmware you have to go to the manufacturers site that applies to the graphics card you have installed and there should be a section for you to download the latest firmware or supply me with the details of your parts installed and i will tell your where to find them or post a link
Sep 26, 2008 | Computers & Internet
Hellp !
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
-Tha Mp3 Doctor
May 23, 2008 | SanDisk Sansa e260 MP3 Player
Problems with charging my mp3 player!
-Tha Mp3 Doctor
Mar 29, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
NEED HELP WITH MP3 PLAYER
You need to update the firmware of your mp3 player, try to look for firmware upgrades for your specific brand or model...
Dec 09, 2007 | Audio Players & Recorders
Creative Zen Xtra nomad Jukebox 30gb
You probably have Winders Media Player 11. If you can find another computer that has WMP 10, you can use that computer to do the firmware upgrade, then go back to the original computer. Thingsa should work fine. Otherwise, you need to unistall WMP 11 and WMP11 runtime. Another case of Billy messing us up. And don't even get me started about vista....
Jun 02, 2007 | Creative Labs Nomad Jukebox Zen Xtra MP3...
*firmware problem*
did you have any news about it?
Aug 26, 2006 | Creative Labs Zen Touch MP3 Player
Computers & Internet Logo
152 people viewed this question
David Payne
David Payne
