I have an athena iVoice stereo speaker, had it since 2006 and just recently after i cleaned my room and unplugged my stereo from the surge protector, i plug it in and it won't work. the blue light that indicates its on it doesn't blink the way it usually does. it quickly blinks for like a millesecond when you try to turn it on but usually when it was on, it would blink for a couple of seconds. someone help!
    Top Expert:
  • 12,223 Answers
Make this test and fix it. God bless you
  1. Verify TV is plugged-in and getting power.
  2. Verify your home's power breaker has not tripped.
  3. Verify the batteries in the remote control are good.
  4. Verify you have selected the right input for Cable/Satellite, antenna, DVD, VCR or Game Console.
  5. Verify the cable/satellite box is plugged in and getting power
  6. Verify you are getting cable/satellite in other parts of the house
  7. Verify the VCR is plugged-in,getting power, and turned on.
  8. Verify that all wires are connected to proper place
  9. Scroll through input screen to verify you are watching the correct inputs
Look at the FAQ on the manufacture's website or user manual
Posted on Jul 31, 2013
  • 1153 Answers
SOURCE: green blinking light
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source)
Posted on Sep 23, 2007
freetek
  • 5568 Answers
SOURCE: green timer light blinking tv won't turn on
My thanks to your husband (and all who are involved in this stupid conflict) for his service.
You didn't mention whether there was a pattern to the blinking which in some sets can be decoded  into a specific problem. I'll assume it is a regular blink rate you have.
All modern sets have a standby state that allows them to respond to the remote when they are 'off.'  The power for the LED that's blinking comes from this 'always on' power supply and the fact that it is blinking probably (and unfortunately) means that either the main power supply has failed or possibly the lamp in some brands.
Because this can come from more than one place, it's not possible to determine which source it might be.  The owner's manual might give info under 'Troubleshooting' as to the source.
If you don't have the manual available, you can download one here:
Mitsubishi Manual
If you find that it is the main power supply, this is likely on a separate board and may be user replaceable.
Pull the AC plug from the wall and let it sit for at least a couple of hours to allow certain components to loose any dangerous charge. Remove the lower panel from the set and look for a board with larger than average parts on it, particularly cylindrical objects (capacitors) and larger dark blocks (transformers). Look on that board for a part number for the board (not the components).
Locate the nearest Mitsubishi repair company and call to see if they repair failed boards or only sell new. Once you have the price for it (could be $90-$200 US), you can decide if you want to replace or repair it.
Replacing the board is probably not rocket science and have had several ladies do this on their own.
If you find it is the lamp that has failed, this is also something you can do without great technical skills and the prices for these ranges from ~$125 - $200.
Posted on Apr 29, 2009
SD Tech
  • 14553 Answers
SOURCE: green light blinks constantly. reset doesn't fix it.
This set has a lot of problems but I have news for you that I recently discovered from a authorized Mitsubishi repair center---
Mitsubishi has had so many problems with this set that now they sell a complete Chassis replacement for this set for about 200 dollars--You will have to go to a authorized center---no more trying to fix individual boards in this set...if you are in doubt--Google the model number and you will see all the problems this set has had---
Contact Mitsubishi and I think the best thing you can do is get the Chassis replaced--
If you have more questions about what I am telling you let me know---I think Mitsubishi is trying to avoid the class action lawsuits that are in progress against them for this model.
REGARDS, SD TECH
Posted on Oct 08, 2009
Testimonial: "Thanks for the tip. I left it blinking for 2 hours and tried reset again and it worked. But next time i'll use your tip to find the prob."
asnowman
  • 788 Answers
SOURCE: TV won't turn on
If the led is blinking one time there is a problem in the 140 volt circuit. Most likely a shorted Horizontal Output Transistor or a bad flyback transformer.
I would recommend that you contact a local servicer in your area and see if they can come to your house and diagnose the problem and give you an esimate for the repair. This can be tricky to diagnose and the potential for electrical shock is very high. So I would be careful if you wish to repair it yourself.
I would guess that you should be able to get a servicer to your home and repair the set for somewhere between $350.00 - $450.00 depending on the parts that are needed and the area in which you live.
I hope that this helps you with this issue. If you have any further questions, please post and I will try to help you as much as I can.
Thanks for using FixYa
asnowman
Posted on Oct 25, 2009
ladywinn
  • 5138 Answers
SOURCE: Screen keeps going black, green light blinks, then screen returns
Lamp- Mats has them 1-800-628-1118
Posted on May 29, 2010
My stereo just quit on me there was bad weather but it was on one of those power surge cords it is a pioneer stereo fm-am digital synthesizer tuner
If it was plugged into a surge protector, check the surge protector warranty. There are A LOT of surge protectors that will cover damage to items plugged into them through their warranty system. I've had full home computers and TV's replaced by surge protector companies to avoid having a hit to homeowners insurance.
Aug 16, 2016 | Pioneer Audio Players & Recorders
I recently purchased a Hitachi bread maker. We had a power surge and it stopped working. Is there a circuit breaker on this model?
Unlikely. This will need repair or replacement.
To avoid future issues , install a whole house surge protector on the main panel and use local surge protectors on expensive units.
Unplug the things not regularly used.
Aug 10, 2014 | Hitachi Kneading Paddle HBD103 Home Bakery...
Can i connect juster speakers 675 to my dell laptop?
Plug the power transformer into the bottom jack on the back of the right-channel speaker. This is the speaker with the on/off knob on the front. 2 Plug the audio cable attached to the left-channel speaker into the audio jack on the back of the right-channel speaker. The jack is immediately above the jack for the power cord. 3 Plug the audio jack attached to the back of the right-channel speaker into the headphone jack on a laptop computer (usually located along the left edge), or to the audio output jack on the back of a desktop PC. 4 Plug the speaker transformer into a surge protector and the surge protector into a wall outlet. 5 Turn the on-off and volume control knob clockwise on the front of the right-channel Inspiron speaker to activate the stereo speakers and adjust the volume.
Aug 07, 2012 | Juster : SP-801 Twintower Speakers...
My AV receiver turns off a couple of seconds after I turn it on. I did what the manual said, unplugged the power source and removed all of the speakers but it continues to do the same thing. Anything else...
you may have a bad Earth power 110 V AC cable connection which makes such hum / buzz even nothing connected..
Check the connections between components and make sure they are secure before proceeding to the next Step. Sometimes, loose connections can cause a hum.
  • Separate the audio cables from the power cables; electromagnetic interference from the power cables can cause stereo hum. Use cable ties to secure the audio cables away from the power cables.
  • Plug in a surge protector to the outlet, and then plug all the components into that surge protector
  • Connect a ground plug to the surge protector and then plug the ground plug into the main outlet. A ground plug is available at any hardware store, and turns a three prong connection into a two prong. Ground plugs help eliminate 60 cycle hum.
  • 5 Connect the ground wire from your turntable to the ground wire connection on the receiver. If this doesn't work, looking on the back there should be a grounding point,
    Unplug your receiver.. Split a wire and attach one of the splits to the receiver where you will see the text, "ground" or something similar. Attach the other end to something metal such as a pipe that goes into the ground. Secure with electrical tape. Plug in.
    connect the ground wire to a screw on the electrical outlet.
    Read more: How to Fix a Hum on a Stereo Receiver ' eHow.com http://www.ehow.com/how_5183193_fix-hum-stereo-receiver.html#ixzz1PpFHs1Mv
    Take care and please remember to rate me"AS THUMBS UP" Thanks
  • Jun 20, 2011 | Onkyo TX-SR606 Receiver
    No color
    Lets focus on the external portion of the TV set first (95 percent of all TV problems are related to things EXTERNAL To the tv itself) Check the physical CONNECTION of all cables by removing each wire bare or RCA and reinstalling it (Each power cable as well), once you have removed one cable, check it for fraying, and if it is already bare, splice a new fresh connection for it. 5. Check to make sure there are NO OTHER uneeded radios, system nearby. these systems, when powered on, will cause electromagnetic interference and prevent more than just severe tv interference SURGE PROTECTOR Surge protectors account for more than 75 percent of electric faults to stereo equipment. Lets start with your AC Wall outlet. It is standard in america that 220 Volts from out of these outlets. This implies that each device will be using 220 Volts (From within that grid zone). If anything including an alarm clock is plugged into any AC outlet socket in the vicinity of the stereo equipment/TV, it will cause electric outage, and prevent electronics from even turning on! Your TV needs dedicated electric power. If your TV is located in the living room then unplug everything else in the living room. Lets plug the TV set into a Dedicated socket. Check all light switches to ensure that power is on for that outlet. Check the TV cable for Fraying both on the ac wall end and where it plugs into the TV. Check all GFCI outlets to ensure that all red reset buttons are pushed in, check the circuit breakers for proper connection and they are turned on. Now, lets try the TV set without it connected to any cable services, vcr, dvd, stereo system, etc.
    Jan 15, 2011 | Memorex MVDT2402 24 in. TV/VCR/DVD Combo
    I recently installed Windows 7 and my Boston BA745 speakers will not work. I'm looking for driver or other solutions.
    1) Try the portable player test. Unplug the speakers from the computer and plug them into the headphone output of a portable-type stereo product. This test should produce sound. If it does the problem is most likely in the soundcard, or in your internal volume settings. You should contact your computer's support group for further help in those areas.
    2) Is the green power light illuminated? If not, you could have one of two possible causes. The first and less serious issue is that the power supply is not outputting the correct voltage. You can test the power supply with a voltage meter or you can always take the power supply to any electronics store and have it checked there. If it is not outputting the correct voltage (12VAC), contact our parts department for a new one at (978) 538-5136.
    If the power supply is working properly, then your problem is most likely in the amplifier. In this case, we will need to fix your system here, and you can contact customer service at the above phone number to set this up.
    3) If the system is connected properly and you have a green subwoofer light, disconnect the power supply from the wall for 10 minutes. This is a common problem on overloaded surge protectors. To many devices on the same surge protector can limit available power. Putting your speaker system on its own circuit (or a more dedicated one) should eliminate this problem.
    4) Check the bass level on the back of your subwoofer, (or on your desktop control pod. For best subwoofer performance place the woofer on the floor along a wall or better still in a corner. This "corner loading" will increase bass output.
    Nov 14, 2010 | Boston Acoustics BA745 Computer Speakers
    42" westinghouse flat screen wont turn on
    Some surge protectors fail just when most needed.
    Jun 19, 2017 | Westinghouse TX-52F480S 52 in. LCD TV
    Sony Bravia KLV-40U100M-screen is distorted, overlay or various vertical lines
    The resolution on this was to check the surge protector the television was plugged into. Once we unplugged and plugged into another surge protector, the screen went back to normal and the appearance was great. We believe this was due to one of the resistors within the surge protector may have become faulty.
    Oct 08, 2008 | Sony BRAVIA KLV-40U100M 40 in. HD-Ready...
    Protector flashing
    Protet mode is a special diagnostic mode that starts when a fault is detected.
    When in protection mode the unit is prevented from starting by protection circuit, so to prevent further damage.
    Check the speakers and speakers wiring, a contact in speaker wires, or faulty speakers can send the unit in protection.
    Try unplugging power cable for one hour or so. then connect cable back and see if you get rid of protect state. Sometimes accumulation of electrostatic charges inside circuit capacitors can kick in protect mode. In that case unplugging the unit from main for some times can get rid of electrostatic charges, and reset circuits by draining power completely.
    If that was the problem, you will not get Protect when plugging back power cable.
    If you do all the above and still get Protect, then there is a real fault.
    In that case the unit may be disassembled and tested to find the fault.
    If that is the case I suggest contacting the manufacturer at the number listed on the owners manual, or asking a quote on repair to a local technician.
    Oct 05, 2007 | Sony STR-GA7ES
    RCA rs-2522 Shelf system
    overload is the unit letting you konw that there is a problem with the speakers,speaker wires (shorted), or most likely that the audio output ic in the unit is bad. typical price on this part is around $15 to $40.00. the part is a little had to get to replace.\ good luck
    Jan 29, 2007 | RCA RS2522 CD Shelf System
    Televison & Video Logo
    78 people viewed this question
    Top Televison & Video Experts
    Electro Med Services...
