Question about Whirlpool duet Washing Machines
Error Code S8E1 - Duet Washer 9150 - duet Whirlpool Washing Machines
Krazytech
  • 725 Answers
SOURCE: WHIRLPOOL DUET WASHER 9150 DOOR LOCK DOES NOT UNLOCK
Door Lock Error
A Door Lock Error occurs if the door cannot be unlocked. It will try to lock it 6 times before displaying the error.
  • Door Lock Mechanism broken or removed from the Door
  • Check Door Lock/Switch Assembly
  • Check the wire harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
  • Door Lock/Switch Assembly Failure
replace door lock and ccu sorry
Posted on Jul 28, 2008
jgwhomeequip
  • 1902 Answers
SOURCE: Whirlpool duet front load washer flashes F35 shortly after start
Sud= The unit has sensed there is too many suds in the unit it will flush and pump out for 5 min and restart on its own..This is caused by too much soap use..
From the book :
SUD Code=
If too much detergent was used:
—Run the unit through a Rinse/Spin cycle.
—Run a Normal cycle without adding any detergent.
This should clear the unit of the excess detergent.
1. Check the drain hose and make sure it is not plugged
or kinked.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the drain pump,
pressure switch, and Central Control Unit (CCU).
4. Check/clean drain pump filter of foreign objects.
5. Plug in washer or reconnect power.
6. Check drain pump.
7. Check the pressure switch.
8. Verify CCU operation by running a Diagnostic test or any
cycle.
Posted on Feb 13, 2009
jsrock516
  • 5911 Answers
SOURCE: Duet 9150 washer collecting water
The problem is more than likely your water inlet valve. The water inlet valve (also known as a mixing valve) is located in the rear of the washer where the fill hoses attach. There is a separate solenoid for the hot and cold water. These two valves are controlled electronically, but the small diaphragm that controls the water turning on and off can become clogged with sediment, or the solenoid can stop working, causing it to not close properly when not in use. With the diaphragm stuck open, the water will leak by and fill the drum over time, causing the problem you are describing.
Long story, short...you can attempt to remove the water inlet valve and clean it with some distilled vinegar and water solution. Or, you can simply replace it with a new one. In either case, you will need to access it and remove it from the washer. The following steps explain how:
1. UNPLUG the washer.
2. Turn off the water supply and remove the fill hoses from the back of the washer.
3. Remove the washer top panel by loosening the three screws that hold the panel in place in the rear of the washer. With the screws removed, the panel will slide back, then lift off.
4. The water inlet valve is in the rear of the washer on the left hand side (as viewed from the front). Remove the water dispenser hose and disconnect the electrical connections.
5. Loosen the mounting screw(s) that hold the valve in place and remove.
You can attempt to clean the assembly in a 50/50 solution of distilled vinegar and water by allowing it to soak for about a 30 minutes. Mix a solution in a container and submerge the valve portion only, leaving the electrical contacts dry. After 30 minutes flush with warm water water. Sometimes this works, sometimes the valve needs replaced. In my own personal opinion, if you're going to go the route of removing the valve, you might be better off to replace it to save yourself from having to repeat these steps twice.
Replacements can be purchased on line at appliancepartspros.com, searspartsdirect.com, repairclinic.com, or pcappliancerepair.com. All these sites offer great service with competitive pricing, so shop around for the best price. I hope this helps you.
If you have any questions, please let me know.
NOTE: I would recommend you turn the water supply off while not in use until you can resolve the problem. This will prevent the tub from filling.
Posted on Jul 06, 2009
jsrock516
  • 5911 Answers
SOURCE: Whirlpool duet washer F21 error code. Just bought
"F21" is a Long Drain error. The following link explains how to torubleshoot:
http://www.fixya.com/support/r1484065-f21_error_code_whirlpool_duet_kenmore
What this usually means is that you have something clogged in the drain pump and it needs to be cleaned out. In the majority of the cases, this corrects the problem. However, if you JUST purchased this washer, and it is brand new (not used), I would recommend you use your manufacturer warranty (good for the 1st year in most cases) to avoid the risk of voiding it. The conditions of some warranties, prohibit the consumer from opening the appliance and attempting any repairs. Read the find print just to be sure.
If you have any questions, please let me know. I hope this helps you.
Posted on Jul 09, 2009
SOURCE: Whirlpool Duet Washer Trouble Code F25
TOP SOLUTION
The thing is most people have never used a washing machine before, its alright. If you like calling Whirlpool they will track your phone number and in the future they know you like to buy repair parts. The front load washer for the home is a new concept especially with steam etc. use patience and common sense. no washer can really wash 15 pairs of jeans and spin 150 miles an hour several times a week in this you must see the problem . so use common sense when filling the drum and do not use the highest spin cycle unless you are washing very light items. to fix f25 (happened to me after 1 month and I purchased a floor model) the fix is easy and does not involve a circuit board even though there are many buttons that light up. A repair man would love to order you any part you want plus markup, suggest the balancing mechanism and you will have made a new friend. give it up if you know you had to push on the door , maybe take a running jump to get it to close.you cannot wash a months worth of clothes all at once 1. unplug unit 2. remove 2 to 3 screws from bottom of front panel 3. next gently check connections, some may need tightening but again be patient and use appropriate pliers but mainly use gentle pressure 4.many will discover how simple it would be to work on the washer especially if you opted for the pedestals (worth every penny) 5. notice the drain trap cleaning access white and circular and turns, with a towel underneath open and clean trap at least once a year ...before replacing panel do a test rinse and spin. you will notice that once the f25 code appears there is no resistance to turning the drum this only helps to protect certain parts, once the appropriate wire is no longer loose this resistance is no longer...test but still be patient wait while the machine goes through the motions. don't start pushing every button. drum starts turning properly then replace panel. there is taped to the panel a manual with a breakdown of all the error codes. remember this is a very expensive piece of merchandise and will do for you what dry cleaners would have done for you (yes it has a wash by hand button and the machine will not spin to remove water in clothes on this selection, it will only turn to agitate , just remove clothes, hand wring out into the drum then hang or place in a plastic bag and refrigerate for a day or so until you can hang items)** I was able to my surprise wash a 110 year old linen tablecloth using this feature (soak items that require special stain removers and rinse before putting them in this machine. this machine is fantastic BUT be patient, and do not overload and do not spin everything on the highest setting. In being patient I was able to wash a king size comforter and the slip covers of a 90" sofa (not together) the machine can do this, not every day, but choose the correct setting such as bulky or heavy duty and select appropriate settings. I know for the money one should not have to take off the front panel but remember the machine weighs 200 pounds and coming from whatever factory one can only imagine what happens to machines that are abused in transportation. The key is to be patient and use common sense, if waiting on the machine to finish or the door to unlock ( the reason for the multiple locking steps is to allow those who have decided to get into the machine the opportunity to get out) then I will use the dreaded word of multitask otherwise enjoy the experience. I know I love mine!!!
Posted on Jul 20, 2009
Fh error code wirpool duet washer
Display shows F20 or FH - Front-load washer ' Whirlpool ...
https://www.whirlpool.com/...fh-front-load-...
Whirlpool Home AppliancesQuestion: Display shows F20 or FH - Front-load washer. Answer. Image. or. Image. or. Image. This error code indicates a water supply problem. Are both the hot ...
whirlpool duet error code FH - Appliance Repair Forum
forum.appliancepartspros.com > Appliance Repair Help > Washer Repair
Jan 5, 2009 - 10 posts - ‎1 author
... Repair Help > Washer Repair » whirlpool duet error code FH .... FH No water detected entering machine or Pressure switch trip not detected. Whirlpool Duet diagnostic code C:03 error code FH
1 post
Dec 5, 2014
Whirlpool Duet Washer HF Error Code
Jun 10, 2013
FH Error Code on Whirlpool Duet Washer
Mar 11, 2013
FH error code
Sep 13, 2008
More results from forum.appliancepartspros.com
Stumped on error code FH for Whirlpool Duet front load washer .
Jan 08, 2016 | Washing Machines
I have the f13 error, on whirlpool duet ht, 9150. I have removed the top and I'm trying to run a drain and spin. The motor seems to work fine as it cycles through all four steps, but never seems to...
F13 codeindicates that the dispenser motor is not able to be driven to it's properposition.
*Check mechanical linkage from the dispenser motor to the top of thedispenser.
*Check wire harness connections to the dispenser motor and CentralControl Unit (CCU).
*Check the Dispenser Motor.
Toremove the error display, press Pause/Cancel twice. IfPause/Cancel does not work: *Unplug washer or disconnect power for oneminute.
*Plug in washer or reconnect power.
*Re-select the cycle and press Start. Hopethis helps.. Good luck! :)
Jun 09, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I have 2 duet washing machines and am familiar with fixing the F21 problem as described above, however, this time with our newest duet, only about 1.5 yrs old, I took the panel off and checked the...
F21 F 22 CCU /touchpad/LED assembly unable to transmit/receive data to/from the CCU central control unit
Possible causes/procedure:
1. Check the touch-pad/LED assembly by selecting different
cycles and changing the modifiers and options available to
confirm the touch-pad/LED is responding.
touch-pad/LED assembly and Central Control Unit (CCU).
9150 tech sheet
Jan 13, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Waher stopped with an sud code and will not do anything. water is in washer.
too much suds in washer--
try using HE detergent-
reset to rinse cycle I think will work-been awhile since I had that code-
ready to throw my GHW 9150 off a cliff-FDL codes-door locks up.
Nov 01, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Our wash machine will not spin after draining the water.
if this is really the old 9150 version then f21 is a ccu communication error with user interface. likely ccu is bad. 5d is not a error code.
bearings will make noise when out. unplug wait 1 min the reconnect power. If this doesnt work open top cover and check connections on ccu in rear. (unplug and replug). then buy new control. if your machine is newer duet (wfwxxxx) then f21 is different. (pressure sw) tech sheet on bottom front cover.
Apr 26, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Fault code F25
If you remove three screws along the bottom front the bottom panel comes off.
On the inside, on the right wall, is a plastic bag with a paper labeled "FOR SERVICE TECHNICIAN ONLY".
This has a section titled "FAILURE/ERROR DISPLAY CODES" with all the error codes along with an explanation and recommended procedure. For F25, this is:
DRIVE MOTOR TACHOMETER ERROR
If the control is unable to properly detect motor speed, the machine shuts down.
If a failure occurs during high-speed spin, the door unlocks after 3 Minutes.
Possible Causes/Procedure
1. Verify the shipping system including shipping bolts, spacers and the power cord are removed.
3. Check drive motor tachometer resistance. It should be approx. 115 ohms.
4. Check wire harness connections between the drive motor and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU).
6. Check the MCU by looking for operations of the drive motor.
7. Check the drive motor for powered rotations.
I got this working for many on this site :)
Thanks
Fame !
Apr 25, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F06 error code on Whirlpool duet washer
I have the whirlpool Duet 9150 with the same issue. I removed, reseated and reconnected every connector at least 4 times with the same random result of F06 to the point where it no longer finished the load. I then removed the motor control board again and sprayed it down with electronic cleaner along with all connections by disconnecting them , spraying them down and then reconnect and connected a few times to ensure good contact. I then tried again and the F -06 code came back. I then ordered the board for $ 150 online . When the new board arrived 4 days later, my wife tried the washer one more time and it worked. I have performed over 2 dozen loads . The board was never replaced. It appeared that spraying the board and connectors worked.
Nov 08, 2008 | Whirlpool GHW9400 Duet Washer
Door Lock Error
Jul 26, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
99 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
