Question about Bosch SHE56C02UC / SHE56C06UC Dishwasher
How do you get to control module how to replace bosch she46c06uc control unit
    Top Expert:
  • Bosch Master
  • 12,223 Answers
Go to www.repairclinic.com and get it and see the video attached.
God bless you
Posted on Jul 31, 2013
How do I reset Bosch dishwasher SHE46C06UC
try flipping the circuit off wait 30 seconds, then back on
Apr 30, 2017 | Bosch Dishwashers
My Bosch Nexxt 500 series dryer shows an error code of E:22. I'm hoping u can tell me what it relates to. The photo shows what it is doing. Start light and filter light flash but it won't turn on.
E:20 through E:26 Defective control module Unplug the dryer for 3 minutes to reset the control module. If the code returns when power is restored, replace the control module. Control module
Nov 03, 2015 | Bosch Dryers
Bosch shu5316uc filling fault
Test the water inlet electro valves.
May 26, 2017 | Bosch SHU5316UC Dishwasher
I Have a Bosch SHU5312/u11 that is showing 2H on
To answer your first question, in a word Yes. To address the second question, Yes. The control module is easy to replace but the better news is it is also repairable, ( you can make an educated decision when I'm through on whether to replace or repair, that is obviously up to you ) but I'd like to enlighten you if you'll allow on what to look for, and why.
The issue with your Bosch dishwasher likely lye`s within`the electronic timer/control, specifically the heater relay solder joint. ( a faulty flow switch, ntc or heater can also cause this, but not very probable ). This is why it runs forever unless pressing the two buttons for "cancel". It has nothing to do with a "delay". The 2H stands for two hours and is actually the estimated time the unit took to complete it's previous cycle based on data to the control gathered and stored in memory...it is not "actual" time, it never is on Bosch. there are far too many variables to be "actual" time and since it only goes to two hours in the display, that's what is displayed even if it runs for four hours.
To repair your unit It will require you to remove the control from the unit and then remove the control from it`s plastic housing and look for a burnt solder contact on the printed circuit board. This will be one of the pins from the heater relay, hence the unit sit`s at 2H ( because it can`t heat to advance or until canceled ) trying to heat the water.
**Further to this, if you or someone you know is proficient at soldering, a lot of times it can be remedied by simply repairing the solder...although Bosch recommend`s replacing the control and I don`t pretend to speak on there behalf nor do I profess to know better. This is just my experience (it work`s) and my opinion (why buy new if one can repair ?)**
**Please disconnect the power before attempting any service to the dishwasher. If you do not feel comfortable attempting this service, call a local pro, preferably one familiar with Bosch/Thermador/Gaggenau, to service your machine.**
Hope this answer`s your question's, let me know if I can assist you further. Thank`s for visiting "fixya" for your repair inquiries. Please take a moment and rate this solution to it's helpfulness to you and leave a testimony if you're satisfied.
Good luck.
macmarkus :)
Apr 29, 2010 | Bosch 24 in. SHU53 Built-in Dishwasher
My bosch dishwasher control panel displays 0H on the time delay. When I start it the OH go to 2H. It then starts running and does not stop. The cycle minutes don't display. It's model number SHU5302UC...
check to see if your unit has a recall on it because if it does you will get a free control module from bosch.
your problem is the control module. thermador .com is the site to lookup. gaggenau,bosch,thermador they are the same ccompany. let me know if this helps by sending a 4 thumbs up post
Feb 27, 2010 | Bosch 24 in. SHU53 Built-in Dishwasher
Should I buy a Bosch?
In my opinion, these do not live up to the Bosch name. They seem to come up on our radar here with "unusual" problems, and a lot of the questions posted go unanswered.
I replaced a beautiful stainless steel Kitchen Aid, after replacing the motor/impeller assembly because it was noisy, and the new one failed also. I bought a Samsung, and I like it. There a re several schools of thought about dishwashers, neither of them are very good, but here goes: One friend buys the brand name cheaper models. One buys only the higher end "best" types.
My best advice is to buy a brand with a high degree of reliability, and stay in the mid price range. The reason I say this is that the middle price range units generally have the better components of their "flagship" models, but don't have as many cycle choices, rack choices, etc.
GE, Whirlpool, (Samsung) are good brands. Frigidare is in there, too. I will never have another Kitchen Aid or a Maytag. I found them to be overpriced and unreliable, but this is just my opinion.
Best regards, --W/D--
Aug 11, 2009 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
ABS hydraulic control unit
Go to Module Master. I had the same problem sent mine in and came back. took less then 5 minutes to R/R. www.modulemaster.com
Prior to 2004, Durangos with 4 wheel ABS use the Kelsey Hayes Dodge controller attached to the hydraulic unit. Durangos with just rear wheel ABS use the Kelsey Hayes 125 located separately from the hydraulic unit.
2004 and later Durangos use the Bosch 5.4 controller.
Kelsey Hayes Dodge 1) Disconnect the negative battery cable.
2) Push the harness connector locks to release the locks, then remove the connectors from the CAB.
3) Disconnect the pump motor connector.
4) Remove screws attaching CAB to the HCU.
5) Remove the CAB.
Kelsey Hayes 125 1) Push the CAB harness connector lock to release the lock and remove the connector from the controller.
2) Remove the RWAL valve harness connector from the controller.
3) Remove the controller mounting screws and remove the controller from the mounting bracket.
Bosch 5.4 1) Pull out the side locking tab on the Bosch controller as shown.
2) Remove the connector.
3) Remove the 6 screws and separate the controller from the hydraulic unit.
durango.jpg 2008 Dodge Durango
kh_dodge_location.gif Kelsey Hayes Dodge Location
kh310_location.gif 1997 and earlier Durangos using the Kelsey Hayes 310
Kelsey Hayes 125 controller for Dodge trucks with rear wheel ABS only
Jul 12, 2008 | 2000 Dodge Durango
Bosch dishwasher cycle doesn't end
Try this link, http://www.applianceaid.com/boschDW.html for procedures for running self-tests on various Bosch models using the front door switches. Find your model and read and follow the procedure.
This remaining at '1' problem invariably relates to a 'heater fault' which has usually been traced to an open solder joint on the control board located behind the switches/indicator lights on front door. See pic here of open solder joint http://www.flickr.com/photos/zenzoidman/145089572/ In most cases, the heating element has not been at fault.
I got mine going again by resoldering the joint and saved ~$300 in parts & labour. If this is beyond your skill set, then replace the control board assembly, 266746, which is used on multiple Bosch models. See this page for more information if you want to try to DIY. http://www.appliancejournal.com/appliance-parts/bosch-appliance-parts/bosch-dishwasher-control-module-266746-37/
If this is still beyond your skill set, then call a tech & supply the Bosch model, serial number, and the results of the self-tests.
Jul 08, 2008 | Dishwashers
Timer module - correct name?
Control Module is what it is called..
Jun 22, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch SHE56C02UC / SHE56C06UC Dishwasher Logo
83 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
