Question about Haier HLP21N Washer
Washer is leaving small flecks of dirt (not from clothing) on clothes after washing. Recently moved the washer and it was put on it's side not sure if this has something to do with it.
    Problem Solver:
  • 19 Answers
Try running it empty Bleach and detergent
Posted on Nov 29, 2013
  • 1294 Answers
SOURCE: Machine not spinning due to uneven load balance although clothes are loaded evenly initially
I suggest you stick to the maximum load capacity (or less) of the machine; and not over-load the machine with clothes.
Posted on Apr 14, 2007
Richie_asg1
  • 1036 Answers
SOURCE: every cycle on my haier
Listen for the pump working near the end of a cycle, and make sure it is pumping the water out.
Check the outlet hose is not kinked, blocked or pushed too far into the outlet pipe.
Check and clean the filter if accessible.
If there are no problems with the pump, and you can see/ hear water being added near the end of a cycle, then the control board needs replacing as the cycles are wrong.
Thanks for using Fixya! If this enables a solution, please rate as such. Thanks.
Posted on Jul 04, 2008
  • 106 Answers
SOURCE: hwd1000 washer dryer combo is not moving into the drying cycle
Its time you found out where your filter is to clean out thoroughly
Posted on Mar 02, 2009
  • 6277 Answers
SOURCE: We have just moved into
Manual first- for you later!
You will need to type into your search engine/web browser '(make) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
Now smell-
Sorry but I do not know your particular machine BUT I would gently suggest as a first step that you clean the drain motor lint tray/filter.
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Mar 23, 2011
  • 10 Answers
SOURCE: Washer leaves the clothes soaked when finished,
have u checked the filter?
you might be putting too much in to your machine
Posted on Oct 12, 2011
The problem is the wash comes out with brown flecks all over it. I have taken out the agitator and cleaned it, this hasn't changed the result, still brown flecks all over wash
WASH PERFORMANCE INFORMATION
9.1 Creasing
Creasing can be caused by over loading the washer or the dryer. Permanent Press or Delicate
cycles have been designed to minimise creasing as they use a lower spin speed. Do not leave wet
clothes to sit in the washer or laundry basket.
9.2 Soiling
Soiling is the result of insufficient detergent for the load. White clothes are better washed
separately. Separate lightly and heavily soiled items, as clothes can pick up soil from dirty wash
water. Cold water below 68oF / 20 oC does not wash effectively. Select the wash temperature
according to soil type. For example, blood and mud are better washed in cold water, while sweat
and oil based soil wash better in warmer water. Loads made up of articles of varying sizes will
wash better (e.g. full loads of sheets may not wash that well). Hard water requires more detergent
than soft water.
9.3 Linting
Wash lint givers (eg. towels, flannelette sheets) separately from lint collectors (eg. synthetic
fabrics). Over loading the washer can increase the likelihood of linting. Insufficient detergent for
the load can increase linting as there will not be enough detergent to hold the lint in suspension.
Over drying synthetic fabrics in a dryer can cause a build-up of static electricity and result in the
fabrics attracting lint.
9.4 Detergent Residue
Over loading the washer can result in detergent residue being caught in the creases of the fabrics.
If this occurs, decrease the load size. Some detergents need to be pre-dissolved. Check the
instructions for the detergent. Cold ambient temperatures, cold washes or short agitation times
may not let the detergent dissolve properly. In these cases pre-dissolve the detergent.
Overdosing of detergent can also cause residue when foam breaks down and will show as white
specs on the clothing. Poor quality detergents can result in residue.
9.5 Black Marks on Clothes
A build up caused by the interaction of fabric softener and detergent (scrud) can flake off and mark
clothes. Do not use too much fabric softener, maximum 75cc. If this is a problem, it is
recommended that the machine is periodically filled with hot water, plus 1-2 cups of dishwasher
powder and left to soak.
9.6 Grey Marks on Clothes
Not enough detergent for the amount of soil on the clothes can result in grey marks on clothes. If
this is a problem it is recommended that the machine be periodically filled with hot water, plus
detergent and left to soak.
9.7 Dye Transfer
Wash and dry non-colorfast clothes separately. Non colorfast clothes left sitting in a washer or
laundry basket can transfer dye to other clothes.
9.8 Tangling
Washing with too much water (i.e. under loading) can cause the clothes to tangle around each
other. Do not load the machine by wrapping clothes around the agitator.
Jun 14, 2012 | Fisher and Paykel IWL12 Top Load Washer
Tip
Eliminate washer Odor
To clean washer add 1 cup of bleach while washer is being filled with hot water and run entire small cycle. DO NOT add clothes. This will help to eliminate odors and any stuck on dirt/ grime on the sides of the drum before washing clothes. I'm not an expert, just an experienced clothes washer for over 30 yrs. ,
on Oct 19, 2013 | Washing Machines
Lg washer leaving black greasy marks on clothes
This is usually to do with fabric softener. Dilute it with more water. The fabric softener makes clots, and these make the marks on your clothing.
Hope it helps
* If you found this solution helpful, please vote positively.
Feb 17, 2011 | LG WM2077CW XL Front Load Stackable Washer...
Washing Machine not running the cycle.
What make and model is your washing machine?
Jun 07, 2017 | Miele W1903A Front Load Washer
Small flecks of dirt on clothes
If its noisy too then sounds like drum bearings gone / leaking oil/grease...
Apr 12, 2010 | Washing Machines
Washer is leaving dirty spots on clothes
If you use fabric softener it may be from the softener. Dilute your softener 50% before pouring it in.
Sep 08, 2009 | Maytag Neptune MAH5500B Front Load Washer
Dirt left in creases after washing clothes. Clothes never look clean
Too many clothes in the load , if it says 5lb then that is the maximum you should fill it with otherwise the clothes do not seperate as they are being agitated
Also
Not enough detergent (Try the old powder types)
Hard Water area (Use a small amount of Washing Soda)
Water level too low , use add water button if fitted
May 21, 2009 | Fisher and Paykel GWL11 Top Load Washer
My kenmore washer leaves fleece and dirt on my clothes always
Nwanne,
It truly sounds like you have something in the washer that may be trapped.
I would remove the lint trap and make certain it is cleaned. Then check under the rim of the washer between the upper tub and the upper seal area. And lastly, check between the agitator bottom and the tub.
There really isn't any part of the washing machine that will produce "fleece" so I believe you have an article of clothing that is trapped.
Good luck and let me know.
Regards
May 14, 2009 | Kenmore Washing Machines
My Whirlpool Calypso top loading washer (purchased in June of 2002) is starting to leave brown or dirt colored marks on clothing and sheets (I think they are permanent!) - I don't see any obvious place...
Run the washer empty with vinegar on the hottest, longest cycle. Usually this is caused from fabric softener and liquid detergent build up. Use powder detergent only and don't use cold water to wash in all the time. Only use cold water for your bright, finer cloths. Cold water use causes detergent build up.
Apr 05, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Haier HLP21N Washer Logo
81 people viewed this question
Top Haier Washing Machines Experts
Gerry Harvey
Gerry Harvey
Owen Barnes
shaun taylor
Are you a Haier Washing Machine Expert? Answer questions, earn points and help others
