Question about Garden
Starter motor runs but does not crank the engine
  • 1,807 Answers
May have stripped the gear on the starter.
Posted on Jul 30, 2013
1989 nissan pickup 4 cylinder when i turn the key to crank the engine i hear a click sound at the starter what could the click sound be?
could be battery . It needs a huge amount of charge to turn over the starter motor. It may work the headlights but be unable to turn the starter motor.
Suggest get battery tested at a battery seller to see if battery is really ok .
The click is most likely the solenoid on the starter motor clicking on.
You might be able to get someone to run jumper leads
Note +ve to + ve and negative to negative !
from their car while the engine is running and their car is not moving !
Wait 10 minutes
Then try to crank over your car engine .
I jump started a 4wd vehicle a month ago from my car and it took about 10 minutes to get enough charge in it to crank over the engine !
Apr 18, 2017 | Nissan Cars & Trucks
2004 windstar wont start plenty of power but wont start no clicking sounds
What year ? For the 2004 model year, the Windstar was renamed the Ford Freestar. Anti-theft light lit on instrument cluster ? Battery good ! How about the battery cables ? Voltage drop test the starting system . Videos on you tube Starter Voltage Drop
Starter System The starting system cranks the engine at a speed fast enough to permit the engine to start.
  • Heavy cables, connectors and switches are used because of the large current required by the starter motor (11002) while it cranks the engine.
  • The amount of resistance in the starting circuit must be kept to a minimum to provide maximum current for starter motor operation.
  • A discharged or damaged battery (10655), loose or corroded connections or partially broken cables will cause slower than normal cranking speeds and may prevent the starter motor from cranking the engine.
The starting system includes:
  • the permanent magnet gear-reduction starter motor with a solenoid-actuated drive.
  • the battery.
  • a starter switch (part of the ignition switch (11572)).
  • the transmission range (TR) sensor.
  • The TR sensor in the starter control circuit prevents operation of the starter motor unless the selector lever is in NEUTRAL or PARK.
  • Starter Relay-Interrupt The starter relay (14N089) interrupt-consists of:
    • pull-in coil and
    • contacts.
    When the ignition switch is in the START position:
    • Current passes through the starterrelay-interrupt from the engine compartment power distribution box to the starter solenoid (11390) .
    • Anti-theft controller module activates relay-interrupt.
    • Pull-in coil in the starter relay-interrupt is activated and pulls the contacts apart.
    The starter relay-interrupt is deactivated when the ignition switch is in the RUN or OFF position.
Oct 22, 2016 | Cars & Trucks
98 Honda crv want crank had tune up done two weeks later it want crank was running good.
Make sure battery has a full charge. Cranking is starter motor action, meaning the starter motor is cranking the engine. If the starter motor won't crank the engine, then we need to test starter motor wiring circuits.
If it cranks good, but, won't start, have a helper crank it while you check for spark at the spark plugs, where applicable. If spark everywhere, use a gage and check proper fuel pressure and also, check for fuel injector pulse, engine cranking.
Can you check for applicable trouble codes?
I can only make suggestions, you have to do the testing. I give the same info to guys and gals, I don't know how to do it any other way.
Apr 10, 2016 | Honda Cars & Trucks
How to diagnois problem with no scanner
Eliminate the battery as the issue first up.
Check if you can jump start the car from another vehicle with its engine running or at least have the starter motor kick over the engine. If it starts then you know your battery is the issue. Having lights does not mean the battery has enough cold cranking amps to turn over the starter motor.
2. If the starter cranks the engine over as normal with a jump start from another car but your engine does not start you have also eliminated the starter motor as the issue.
3. If it does not start and the starter motor will not crank the engine over either when you jump start from another vehicle, then there may well be a problem with the starter solenoid, the starter motor itself or with the wiring to the starter solenoid or to the starter motor. No power getting to the starter motor solenoid or to the starter motor and obviously the starter motor will not turn over.
4. So I need not write much more here, there is a very good guide to solving starting issues here which I suggest you might like to read.
No Start Problems
Jan 14, 2016 | 1996 Dodge Caravan
I have a 1976 jeep j10. I have replaced the starter, starter solenoid, ignition module, both battery cables(positive,negative), cable from starter to starter solenoid, coil, cap and rotar. it will click...
Could be: a) starter cannot turn the motor flywheel (motor frozen or jammed)
or b) the battery is weak (not enough power to crank the motor)
Turn the dome light on and see if it is bright, see if light diminishes completely when engaging starter (high current drawn by starter).
Try to turn engine by pulling the alternator belt with transmission in neutral to see if motor is jammed. Or engage in a high gear and push the car and see if motor turns.
If motor is not frozen, jump and boost the battery if you suspect weak battery and see if you have the same problem.
Jun 29, 2014 | Jeep J10 Cars & Trucks
Wont start
Do you mean the starter motor runs but the engine will not crank? If so the problem is at you starter there is a small gear that makes the conection between the starter motor and the engine. Some times you can tap the starter with a hammer while someone try's to start it and it will loosen the gear and start. if this works change the starter.
Sep 18, 2012 | 1998 Mercury Villager
Motor start but does not run
Are you saying that the motor runs until you stop cranking it? or just that it truns over while the starter is engaged but doesn't fire at all?
If it's running while cranking but stalls immediately after you release the key and allow it to go into the "Run" position, then the ballast resistor of the ignition system is most likely bad. The idea is that on older cars with electronic ignition, the starter motor caused such a big voltage drop on the cars electrical system that the ignition coil wasn't provided a high enough voltage for proper spark to occur, so they wired them such that the ignition coil could handle the low voltage which was present during the cranking of the starter, but when you stopped cranking and the engine was running normally, suddenly without the voltage drop of the starter, the voltage would be to high and would damage the ignition circuit. Thus a 'ballast resistor' was added to the ignition circuit and it is only in line when the car is in the "run" position. This allows the ignition system the proper voltage to operate whether cranking or running, but sometimes the ballast resistors go bad, causing the engine to run while cranking but causing an open circuit in the ignition system when placed in the "run" position.
Good Luck.
Mar 28, 2011 | 1993 Toyota Corolla
1990 300zx solenoid/starter relay
I would go for the starter motor personally first, as thats the part that cranks the engine over :)
that gets power, then it starts turning the flywheel, the starter motor also keeps the engine running inbetween the engines power strokes while its running.
Go for the starter relay & the starter motor :)
Thanks.
Apr 10, 2009 | 1990 Nissan 300ZX
Engine not cranking
check the fuel filter
Dec 30, 2008 | 2005 Chevrolet Cavalier
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
