Question about LG 32LC5DC 32 in. LCD HDTV
32lc5dc reset thia was bought at a hotel auction how can i reset the chanels
My 32lc5dc is in hotel mode and won't unlock I've tried everything
Its a long shot but if you could get into the menu, select lock and try code 1105 it might unlock it, it might not.
However, some hotel TV's have a different main pcb, to stop them be worth anything if stolen.
Aug 24, 2016 | Televison & Video
Stuck in hotel mode
The pin is 9876, ENTER. The zeros won't change while you input the code.
May 16, 2015 | LG 32LC5DC 32 in. LCD HDTV
I am at a hotel for a couple months. There is an lg 32lc5dc for a tv. There is no box to order movies but I can not use the hdmi port. There is audio but no video. The hdmi 2 port does not work at all...
probably the tv is hotel mode ,which is the management or tech have lock the sys ,to avoid complication for guest ,u have to find the manual or through on line.
Oct 05, 2013 | Televison & Video
I just purchased a 32 LC5DC and it came with a remote, not the original though and we cant get the T.V to pick up all of our channels--Can you do this without the original remote?
if you can acsess the tv menu you can obtain a new channel search i would take the tv back if under garentee still if you can all ways but a free view box
Dec 20, 2010 | LG 32LC5DC 32 in. LCD HDTV
I bought a 32LC5DC Lg tv from an hotel auction. The side panel doesnt work. The thing I need to find is how to access the "setup menu" inside the regular menu. I can get into the regular menu just fine,...
The only thing that would cause this is a lock!
If you ever forget your password, key in ‘7’, ‘7’, ‘7’, ‘7’
on the remote control.
If unlocking does not free up the unit menu then the unit has most likely had a software upgrade at some point to disable these functions permanently. This is normal hotel based systems in order to prevent them being used if they are stolen. In this case you will have to contact LG directly with Model no and Serial No details to get them to assist you.
Oct 01, 2009 | LG 32LC5DC 32 in. LCD HDTV
I need to reset i dont know the code
please post it here if you do find it. thanks.
someone stated this
noavatar_s.gif Dish Fitter
Rank: Master
Rating: 70%, 17 votes
Press MENU for approx 5 seconds then enter, 1105 this will bring up the LG2.gif hidden menu then disable the hotel mode option.
Hope this helps
Cheers
Apr 06, 2009 | LG 32LC5DC 32 in. LCD HDTV
32lc5dc lg tv stuck in hotel mode
it is quite possible, if you bought this set from a hotel liquidation, it might still have it's lodgenet card. If it does, then it may be stuck on the channels the hotel had lined up. If there is a lodgenet card (where the cable jack is on the back) you can remove the 2 screws and just pull the card out an inch (leaving it attached to the black cable). Once that card is out, the tv should fall back to normal use. You might need to do a facotry reset to unlock TV options at that point. Only way around this would be to remove the 2 screws holding in the lodgenet card, and pulling it out of the back of the set (Don't have to pull it out all the way, just enough to disengage the data socket. Once the card is removed, you would need an actual LG remote (not the pay per view remote) and hit menu a bunch of times until it stops flashing menu on and off. Once it stops, you type in on the keypad, "98765" "ENTER". This will take you to an installer menu. Scrolling down to the highest numer there is (Should be one backwards from the "000" you start on" there is "Factory Reset" and you use the right arrow key and set it to "1" and then press enter. The TV will flicker a couple times, and then, all inputs are active.
Jan 17, 2009 | Philips RC2573 Remote Control
Rgb input is dissabled
If the TV has the lodgenet card installed, Which is what handles the pay per view stuff, there is no way to enable the inputs, if what they stream down from the hotel explicitly disabled the inputs. Only way around this would be to remove the 2 screws holding in the lodgenet card, and pulling it out of the back of the set (Don't have to pull it out all the way, just enough to disengage the data socket. Once the card is removed, you would need an actual LG remote (not the pay per view remote) and hit menu a bunch of times until it stops flashing menu on and off. Once it stops, you type in on the keypad, "98765" "ENTER". This will take you to an installer menu. Scrolling down to the highest numer there is (Should be one backwards from the "000" you start on" there is "Factory Reset" and you use the right arrow key and set it to "1" and then press enter. The TV will flicker a couple times, and then, all inputs are active. Once you are done with it all, pushing the lodgenet card back into it's socket, and installing the 2 screws will put the set back to the hotel settings. Now realize once that card is pulled, you won't be able to watch the hotel's PPV or inhouse channels, only a few Free to guest channels will show up.
Dec 12, 2008 | LG 32LC5DC 32 in. LCD HDTV
LG 32LC5DC 32 in. LCD HDTV Logo
117 people viewed this question
Computer Repairing
Computer Repairing
