Question about RIM BlackBerry Curve 8520 Smartphone
When start program stop and not finish starting start in medle
    Sergeant:
  • 314 Answers
Update o.s. wid new1
either do at home if you got any else go to service centre nearby
Posted on Jul 30, 2013
Please help! It turns on, command light is flashing green, no turn off, doesnt move if i dont put water in manually
Failures, which occurred during the program will store and indicate for customer by flashing start LED (light-emitting diode). Appliances which have no program sequence or no 7-segment display can't exatcly show the failure. On these appliances the failure can only be found by starting the test program.
The passive test program shows the stored failure. If there is no failure the passive test program runs normal.
1. Switch off the appliance
2. Push start button and hold it
3. Choose position 1 of the "turning knob" turning right side (program 1).
4. Finish pushing the start button when the start LED flashes.
5. Failure indication
6. Repair the failure
7. Solve the failure by pushing the start button for longer than 3 sec.
8. Start the passive test program again. If there is no failure detected, test all LED's and after that choose program 1.
9. Finish the passive test program by pushing the start button for shorter than 3 sec.
Thank's to your description of failure I will check all hydroulic inlet water circuit and electrical component in "inlet water" phase (electrical valve, flow meter (if exist), OWI, VWI, wiring, CB...etc)
Dado
May 30, 2015 | Whirlpool Dishwashers
How do I stop machine mid program to change to another program?
Go to stop or a program that ir a reset mode. Cheak the make and model and look in you manual that came with the machine. Normally there is a stop mode.
Nov 09, 2014 | Beko Washing Machines
Very,very slow freezes up
First download CC Cleaner. Just Google for it. Thereis a free and a paid version. The free works fine. Run the cleaner for cookies and Internet tracks. When finished, then run CC Cleaner registry cleaner. While you have I opened, uninstall any extra programs or bookmarks you don't need. Also check your start up menu and see if there is anything that can be turned off (doesn't need to run at startup). You can do all of this with CC Cleaner. Next google for Malwarebytes free. Download the program and install it. Scan your system with this program and do an extended scan (the second choice). This could take a while so go get a snack and something to drink from the kitchen. When Malewarebytes is finished scanning, you need to tell the program what to do with what it has detected. I usually check all entries and tell it to remove all. Using system utilities, do a disk cleanup followed by a disk defrag. Again this (the disk defrag) could take a while. Take the dog for a walk and, when you come back, if your computer is finished defragging
Sep 02, 2013 | Dell Inspiron 1501 Notebook
Startup very slow on my new dell 660 desktop
If it is updating it will take a while to load updates. Once all the updates are installed it should Boot and shut down faster. Just let it finish the updates. do not disturb until finished.
Dec 11, 2012 | Dell Computers & Internet
When i try to uninstall my lexmark x1190 it comes up printing not finished
Try to clear the Lexmark print queue from pending/stuck print jobs so you can successfully uninstall the Lexmark software/ printer driver. Here's how:
  1. Browse to Start -> Run... and type in NET STOP SPOOLER (this will stop the print spooler service)
  2. Browse to your windows\system32\spool\PRINTERS\ folder. You should see files there ending in .SPL and .SHD created around the time you tried to print - delete these files.
  3. Browse to Start -> Run... and type in NET START SPOOLER (this will restart the print spooler service)
After successfully clearing the print queue, uninstall the printer software by going to Start menu > Programs > Lexmark 1100 Series folder > Tools > Uninstall. Reboot your pc when prompted.
Hope this helps.
Apr 30, 2012 | Lexmark X1190 All-In-One InkJet Printer
Put clothes in washer HOTPOINT modelWML730 started
TURN MACHINE ON TO FINISH CYCLE THEN RE WASH WITH SOAP ETCH,DOOR WILL NOT OPEN MID CYCLE SAFTY LATCH,YOU CAN TURN PROGRAM TO FINAL SPIN TO EMPTY MACHINE AND FINISH PROGRAM THEN DOOR WILL OPEN
Jan 06, 2010 | Washing Machines
Problems Descaling
Hi You have finished the first part of the descale process if that machine is like all the others. Rinse out your water tank and put fresh water in it. Then put it back on the machine and close then open the knob for steam and let it run the whole tank out. When it is finished the descale light will disappear and your green light will blink and the water light will be steady. Refill the water tank and close and then open the steam knob to prime so the water light will go out.
Jun 12, 2009 | Gaggia Syncrony Compact Coffee...
Cannot change or erase one-touch/abbreviated dailing numbers
press function - 7- 2 - start- 1 press the one touch you want to program. - enter the number- start- name start- should go back to the machine asking to press another one touch then hit stop..
Dec 18, 2008 | Panasonic Panafax UF-885 Plain Paper Laser...
RIM BlackBerry Curve 8520 Smartphone Logo
20 people viewed this question
Top RIM Cell Phones Experts
Computer Repairing
Computer Repairing
Longtime User
Jason
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
