Question about Freezers
My imperial heavy duty commercial freezer model UL1793CA11 will get cool (about the temp of a fridge) but will not freeze. Can you tell me why this might be?
  • 833 Answers
SOURCE: Can my kenmore chest freezer be in the garage during hot summers and cold winters in Minnesota?
Jeremy,
You can put a fridge/freezer in the garage. Be sure that the area is level so you don't warp the case which will cause sealing problems with the gasket. Also, clean the condenser frequently as dust and dirt will reduce efficiency.
Posted on Dec 04, 2007
johnr1959
  • 56 Answers
SOURCE: new Commercial True Freezer suddenly quit freezing
Check for freon leak>> is compressor running?
or Iced over?
Posted on Jan 29, 2009
TheMobilian
  • 8220 Answers
SOURCE: Fridge/freezer won't cool completely or freeze
Things to look for and fix yourself woulf be to clean the coils on the bottom and check the fan motor on bottom, make sure it is ok, Look on back of the freezer walls for frost buildup, a sign the defrost heater is dead.
Posted on May 09, 2009
victorwod
  • 157 Answers
SOURCE: I have lost my turnkey for an Imperial Upright
you can visit the website of the company and make a request for the key or get the door forced it to get open and get a new locker key for it.
Posted on Feb 20, 2010
SOURCE: I have a Superior heavy duty commercial upright
I have a superior hd freezer it is working but the out side sides get very hot any idea
Posted on Jun 09, 2010
Imperial heavy duty freezer is not freezing. Exterior very warm
You need a refrigeration engineer. It sounds like it needs refrigerant gas. Worst case scenario is that the compressor has failed. Both low gas and a failed compressor generate heat.
Jun 12, 2016 | Freezers
Our old Imperial heavy duty commercial model uf20x needs seal. Where to find it?
Commercial refrigerator parts supplier can make it same day. Check google for your nearest supplier.
Feb 01, 2014 | True 72 cu. ft. / 2039 liter Commercial...
I have an Imperial heavy duty freezer, model # UL2494ECW5. My door seal is ripped pretty good. Where could I purchase another rubber seal for that model?
The part number for that gasket is 216522312 it could be purchased from your local appliance parts store or online at;
searspartsdirect.com
apwagner.com
partselect.com
apdepot.com
repairclinic.com
GENE
Sep 09, 2011 | Freezers
What is the best way to defrost a heavy duty commericial Imperial freezer?
a commercial freezer should have it's own defrost cycle. I would look into what the issue is that is causing you to do a manual defrost.
The 2 most common AND safe ways to defrost any freezer is either using hot water or a hot air source such as a hair dryer.
Dec 04, 2010 | Freezers
We have an upright Commercial Grade heavy duty Imperial Freezer, model # UL4000ECW2, purchased a little over 10 years ago. Today I noticed that everything in it is thawing and when I close it, it no longer...
the suction noise is not something that will happen all the time.
check the current draw on the compressor and make sure it is in between 1.2 and 1.6 amps.also look at you evaporator coils and make sure there is no excessive frost build up.If there is ice build up then you need to defrost it check the heating element and defrost timer and make sure they are in proper working order.also check the evaporator fan and make sure it is working when the unit is in a cooling mode.
Sep 07, 2010 | Freezers
I have lost my turnkey for an Imperial Upright heavy duty Commercial Freezer. It is locked and I have no way of getting inside... Where can I get one?
Feb 16, 2010 | Amana 19.7 cu. ft. / 558 liter Upright...
FRIGIDAIRE FREEZER MODEL # LFFU1465DW3 WON'T FREEZE
Make sure freezer door seal is completely sealed. No gaps, Also, if you are up to the challange, you will need to remove the freezer panel, test thermometer, thermostat, for voltage and resistance. Also check that the flapper that seprates freezer from fridge air.; Is not frozen.
Jun 11, 2009 | Frigidaire Freezer Refrigeration White...
Jeremy,
Nov 27, 2007 | Kenmore 12.8 cu. ft. / 362 liter Chest...
Freezers Logo
62 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
