Question about Proform Cardio Smart iFit Treadmill with 16 Workouts
Proform cardio smart console is on but none of the buttons work
  • 64 Answers
SOURCE: stop button, fan button, up incline button are not
If some buttons work, you more than likely have a key pad problem. Unfortunately Icon doesnt sell kep pad seperately. As a last effort, try heating up those buttons wit a blow dryer. This will work temp. sometimes.
Posted on Jul 27, 2009
maxtreadmill
  • 832 Answers
SOURCE: proform treadmill doesnt work
Press the Stop and the Speed Up keys down while inserting the safety key and try to get this unit in calibration mode if you cannot then, the upper console will have to be replace.
Posted on Jun 01, 2010
SOURCE: console is unreposive, it lights up but none of
Same thing just happened to me. Anybody know the answer?
Posted on Oct 18, 2010
SOURCE: console buttons don't work,only ifit button works
Has anybody found the solution for this? I'm having the same problem on my 850T treadmill. It's really annoying..
Posted on Jul 04, 2011
ercupa190
  • 12223 Answers
SOURCE: proform 540 console doesn't work
If the console takesbatteries, replace them. If this does not work or your console does not requirebatteries, check the reed switch or optic sensor. Reed Switch: Unplug the treadmill andremove the motor hood cover. The reed switch is mounted on the frame next tothe front roller pulley. There is a magnet glued into the front roller pulley.When adjusting the reed switch, make sure it is pointing directly at themagnet. Move the tip of the reed switch within 1/8" of the magnet. Also,check to see that the wire is not damaged, and is connected to the console. clip_image002.jpgOptic Sensor: Unplug the treadmill and remove the motor hood cover. The optic diskand sensor are located either at the end of the motor or the right hand side ofthe front roller. The optic disk spins between two sensors on the optic switch.The disk must spin freely without touching either sensor. The sensors can bemoved by loosening the adjustment bolt holding the switch to its bracket. Theswitch can then be slid. Center the disk.
After you did these adjustments: Please tight the keypanel flexible cable vs display board and then tight the connector from display board vs lower board.
Try to clean the keypanel with spray contact cleaner with carefully and patience.
See diagrams. Good luck, sincerely. G-d bless you.
12_6_2011_5_46_41_pm.gif12_6_2011_5_46_57_pm.gifWith the block diagram that I did you will have a strong resultant if the keypanel board is faulty or display board completely. See how the main motor control has 90% functions in any treadmills.
E.CUADRA
MANAGUA, NICARAGUA.
Posted on Dec 06, 2011
What is the power source for the display console of a proform 650 cardio crosstrainer elliptical? The display on mine is not on.
you must see the schematic diagram coming with your treadmill, or read your owner manual, and follow the instruction in section assembly or parts manual
God bless you
Nov 01, 2013 | Proform 650 Crosstrainer Treadmill
Control panel lights up but not responsive on any function
The proform console sometimes freezes up and refuses to take the input from the user. Replace the console. The manufacturer do not sell parts for this console.
May 19, 2013 | Proform Pro Form 785ss 785 Ss Treadmill,...
Console
Dear Sir:
See the diagram attached for Reed switch, clean, tight the connector very well.
2) Change batteries by new ones, and clean the contact very well!
sincerely. God bless you
Apr 25, 2012 | Proform ZT5 Treadmill
The board lights up, but when you attempt to push a button (speed, program select) nothing happens. I do however have the stop and pace button beeping 3 times when you touch, but nothing works.
i think your console is shot check connections on the controller board. when pressing buttons, and some commands or none work, its the console
Feb 28, 2011 | Proform Exercise & Fitness
What is the weight max?
ProForm Treadmill Offers Low Impact Exercise and Cardio Fitness Maximum User Weight:325 lbs
I suggtes confirm this with your owners manual.
Good luck.
Feb 01, 2011 | Proform Exercise & Fitness
Have purchased a used Pro Form 900 Cardio Cross Trainer
If you can hear the adjustment motor running the problem could be related to two things:
1. Broken or stretched resistance adjustment cable.
2. Broken bracket for the magnet return spring.
If the resistance is on maximum all the time the second issue is most likely the cause.
Dec 31, 2009 | Proform PFTL79807 - 850 W/ Gamefit...
I need owner's manual for proform 900 cardio cross trainer
go to www.iconfitness.com and follow the instructions. You can do everything from that site. We are service dealer for them, and we like to help..
Aug 10, 2009 | Proform 675 Crosstrainer Treadmill
I have the proform 7.0 personal fitness trainer
Try to calibrate the incline threough the calibration mode.
Apr 13, 2009 | Exercise & Fitness
Console buttons don't work,only ifit button works
Feb 14, 2009 | Proform 540ls Treadmill Walking Belt
Proform Cardio Smart iFit Treadmill with 16 Workouts Logo
62 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
