Question about Nokia E5 Cell Phone
How to delete file which shows in galery when i was delete the files general system error show kindly confirm the solution plz
    Sergeant:
  • 314 Answers
System file you cannot delete
if personal file.....delete directly
if attacked by virus some file couldnt be
if it it so
backup yor data
make hard reset of your device to factory setting
Posted on Jul 30, 2013
SOURCE: music in music library shows corrupted cannot delete
Connect ur phone to ur PC in Data transfer mode.
Make sure u can view hidden files in ur pc.
Open E:\private\
where E: is ur memory card drive name
Delete all the files in "private" folder.(u can copy and save all the files before deleting incase anything goes
Disconnect ur phone and restart it.
Open music library it will refresh itself automatically.
Mines working fine now....
Posted on Jan 03, 2010
rebell26
  • 86 Answers
SOURCE: I cannot delete photos from my n97, there are 127
Use the Nokia Photos application on your PC. Connect your phone to the PC using for example USB cable. In the left top corner of the application the name of your phone should appear. Click on it - it will turn green. Now you will see the photos on your phone. Select the icons that you want to delete and press delete (on the keyboard).
Posted on Feb 12, 2010
SOURCE: i have N70...i could not open my messages from
take out ur mmc and format ur set using *#7370# ,,,hope it works
Posted on Feb 28, 2010
Testimonial: "Thanks a Lot"
  • 226 Answers
SOURCE: my nokia 5233 shows memmory
if you have no files, sounds like it is a hardware problem with the chip that stores the memory, so, what i would do, is back up your contacts, and via the nokia site with your data cable, download and update to the latest software
Posted on Aug 17, 2010
makoy32000
  • 302 Answers
SOURCE: I CANNOT INSTAAL NOKIA PC
It means that you have to set the date of your phone a year earlier for it to work.
After you have set the date a year before, try to install the file again.
Also, make sure that the certificate application allows all certificate. Check it in the Settings > Application Manager.
Posted on Mar 10, 2011
How to delete general system error Nokia E5 Cell Phone
when i deleted images & videos then shows general system error
Mar 16, 2012 | Nokia E5 Cell Phone
I have an acer aspire 5315 and my disk drive wont read any kind of disks its not showing up under the computer hard disk drive... how can i fix this?
It happens if the upper and lower filters are corrupted. My remove both or anyone of the files will resolve the issue. To do so, please follow the below steps (Note:
Please delete the excat entry in the steps below. If you do not find the entries ignore it. Do not delete any other files that will screwup your computer):
1. From the Windows Vista default Start menu, point to All Programs, Accessories, and then click Run.
2. In the Run dialog box, type: Regedit and Click OK.
3. In the User Account Control dialog box, click Continue.
4. In the Registry Editor window, locate and then click to select the following registry subkey:
HKEY_LOCAL_MACHINE/System/CurrentControlSet/Control/Class/{4d36e965-e325-11ce-bfc1-08002be10318}
5. From the File menu, click Export.
6. In the File name dialog box, type: Savedkey, and then click Save.
7. Click the REG_MULTI_SZ data type UpperFilters file, and then from the Edit menu, click Delete. When you are prompted to confirm the deletion, click Yes.
8. Click the REG_MULTI_SZ data type LowerFilters file, and then from the Edit menu, click Delete. When you are prompted to confirm the deletion, click Yes.
9. In the Registry Editor window, from the File menu, click Exit.
10. Shut down Windows® and restart the computer
Jul 01, 2010 | Acer Aspire 5315 Notebook
It runs really slow and will freeze up. Ran a virus scan and nothing shows up. Ran clean up a defragment and upgraded the memory. nothing works.
YOU CAN PERFORM A FEW MORE STEPS
Manually delete cookie files in Internet Explorer 6 1. Exit Internet Explorer 6, and then exit any instances of Windows Explorer. 2. Click Start, click Run, type inetcpl.cpl, and then press ENTER. 3. On the General tab, click Delete Cookies in the Internet Properties dialog box, under Temporary Internet Files. 4. In the Delete Files dialog box, click to select the Delete all offline content check box, and then click OK.
RUN DISK CLEANUP
DELETE TEMP FILES
1. Click on Start and then Run.
2. In the text box in the Run window, type %Temp% and click OK. A folder full of files and other folders will appear.
3 All of the folders and files you see in this Temp folder are no longer being used by Windows XP and can safely be deleted.
4. To remove individual folders or files, hold down your Ctrl key while left-clicking on each item you want delete. Release the Ctrl key when you're finished.
5. To delete these items, hit your Delete key or choose File and then Delete from the menu.
6. Confirm that you want to delete the files by clicking Yes on the Confirm Multiple File Delete window that opens.
7. To remove everything inside the Temp folder, choose Edit and then Select All from the menu. 8. Now that all of the files and folders are selected, hit your Delete key or choose File and then Delete from the menu.
9. Confirm that you want to delete the files by clicking Yes on the Confirm Multiple File Delete window that opens. 10. After all of the files have been deleted
DELETE PREFETCH
2. In the text box in the Run window, type “Prefetch” and click OK. A folder full of files and other folders will appear.
3 All of the folders and files you see in this Prefetch folder , Remove them.
9. Confirm that you want to delete the files by clicking Yes on the Confirm Multiple File Delete window that opens. 10. After all of the files have been deleted you can close the window and empty your Recycle Bin, permanently removing the files from your PC.
Note: If you are unable to clean up the Prefetch files follow these steps to remove the Prefetcher from the registry residual
Download Revo Uninstaller: http://www.revouninstaller.com/download/revosetup.exe
AND REMOVE UNWANTED PROGRAMS
DOWNLOAD CCLEANER CCleaner can be downloaded from http://www.ccleaner.com/ AND RUN IT
CREATE A NEW USER ACCOUNT
Jan 31, 2010 | HP Compaq Presario SR1602HM (CPQSR1602HM)...
What format of video for Touchmate Zeno?
Just get this tool to help you.
1. load your file to Video Sharer
2. choose AVI format
3. click" convert" button.
Then you will get the right format.
Here is the tool for you: http://www.asharer.com/download-video-sharer
Jun 14, 2009 | Audiovox MP4128 MP3 Player
How cn uninstall a word u r a victim of softwre counterfeiting on my desktop..plz help me
go to folder items unhide and show system files also uncheck it and ok. Now search for wbcn or whatever file name it is showing on tray icon. Delete it. Open regedit search for same file and delete the registry key. Kill task of same file through task manager. turn off automatic windows update. restart your pc. if you can't get the root name tell me i'll have to again download the file through microsoft for giving you the root
Jun 14, 2009 | Microsoft Computers & Internet
Deleting hidden files
mcpeak_jake
Ok here is a little hard drive 101 for you. With hard drives when the drive says it is a 2gb drive you really do not get 2gb of space to store your data on. The reason for this is every hard drive partition has what is called a file table. The file table help the computer keep track where the files are saved on the hard drive. It is kind of like a card index at the library. Unfortantly the file table will always take up a percentage of the drive. The bigger the drive the bigger the file table will be.
Note some times there are hidden system file on a drive. The link below will show you how to unhide them. However in most cases these are system files that the computer/device needed to work properly and shoudl not be deleted unless you are sure that you can delete the file. This is why they are hidden so they do not get deleted by mistake.
How To Show Hidden Files And Folders In Windows 7
Let me know if you have any more problems or questions
Issken
http://www.fixya.com/users/issken
Apr 02, 2009 | Sony USB2.0 Slim Enclosure 3.5" IDE Hard...
Ms office 2003
Generally  this error occurs because you have deleted your word.exe & excel.exe files to confirm of deletion of these application file you can check by following pathway.  If they are not there means you should restore deleted file from Recycle Bin.
      "C:\Program Files\Microsoft Office\OFFICE11
If the file are not available in Recycle Bin then you should reinstall M.S. Office Application.
Or
You can restore your system to an earlier date when it was working prpoperly.
Jan 13, 2009 | Microsoft Office Professional 2007 Full...
Error: P-1
I had this problem on a Fusic (LX-550). The error occurs because a picture mail is corrupted that you're currently trying to preview (inbox). The Fusic inbox shows 3 pic mails at a time. If one of the three is bad, you'll get that error. If the bad pic mail is the most recent in the inbox, then send 3 pic mails to yourself to bump the bad one to number 4. This should allow you to get to your inbox without the error, although you still have to avoid the bad pic mail page(move up in the inbox to see you're oldest mail). Sending pic mails to yourself one at a time is one method of narrowing down the bad pic mail. The permanent fix is to install bitpim, edit->detect phone, view->view file system, navigate to /EPM/MediaStore/MessageStore and delete the offending pic mail. The file name with the highest number is probably most recent. Right click on the file and perform a hex dump to read the message time stamp. Do a backup first and view the hexdump to verify you're deleting a pic mail file. Good luck!
-Joe
Dec 15, 2007 | Cell Phones
Unable to install nero 7.10
Do you know how to work in the Reg editor if you do then search for nero? delete it completely from the registry then it might install nero 7.10
Sep 03, 2007 | Computers & Internet
Nokia E5 Cell Phone Logo
53 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
