Question about Skque SHOCK ABSORBING CASE FOR 2.5 EXTERNAL HARDRIVE
HOW DO YOU REMOVE THE TOP NUT OF THE SHOCK ABSORBER? AS I TURN THE NUT NOTHING HAPPENS....
    Sergeant:
  • 429 Answers
Your turning the stud ,you need to hold stud from turning normally use a ratcheting wrench and vise gip the end of stud or proper tool like smaller wrench:):)
Posted on Aug 14, 2013
I need to remove the entire passenger side rear suspension. Does it go through the trunk or the back seat? If so how do you remove the back seat?
REMOVAL & INSTALLATION 1983-86 Models
  1. On 4-door sedan, remove the package tray and vent duct.
  2. On hatchback, remove the speaker grilles.
  3. Disconnect the brake line from the wheel cylinder. CAUTION
    Brake fluid contains polyglycol ethers and polyglycols. Avoid contact with the eyes and wash your hands thoroughly after handling brake fluid. If you do get brake fluid in your eyes, flush your eyes with clean, running water for 15 minutes. If eye irritation persists, or if you have taken brake fluid internally, IMMEDIATELY seek medical assistance.
  4. Remove the brake line from the brake hose.
  5. Disconnect the brake hose from its bracket on the shock absorber.
  6. Loosen, but do not remove, the nut holding the suspension support to the shock absorber.
  7. Unbolt the shock absorber from the rear arm.
  8. Unbolt and extract the shock absorber from the body. To install:
  9. Attach the shock absorber to the body and tighten the 3 nuts to 17 ft. lbs. (25 Nm).
  10. Engage the shock absorber bracket with the carrier and install the hardware. Tighten the nuts to 119 ft. lbs. (162 Nm).
  11. Tighten the center suspension support nut to 36 ft. lbs. (49 Nm). There is a bearing located under the suspension support dust cover. Remove the dust cover and pack the bearing with multi-purpose grease. Once packed, reinstall the dust cover.
  12. The remainder of installation is the reverse of removal. Tighten each component to specifications.
  13. Have the rear wheel alignment checked.
1987-88 Models
  1. On wagon models, remove the toneau cover holder.
  2. Loosen the rear wheel lug nuts, raise the rear of the vehicle and support it safely. Block the front wheels.
  3. Remove the rear wheels.
  4. Using the proper size flare nut wrench, disconnect the backing plate hardware.
  5. With a flare nut and a back-up wrench, disconnect the brake tube from the brake hose and use a small plastic container to collect the brake fluid.
  6. Undo the clip and disconnect the brake hose from the shock absorber. NOTE: Before the axle bolts are removed, the axle carrier must be supported with a jack.
  7. Support the axle carrier with a floor jack and remove the mounting bolts and nut. Disconnect the axle carrier from the shock absorber.
  8. Support the shock absorber firmly by hand and remove the three mounting nuts. Remove the shock absorber from the body. To install:
  9. Position the shock absorber onto the body and support it firmly by hand. Install the three nuts and tighten them to 23 ft. lbs. (31 Nm).
  10. Attach the axle carrier to the shock absorber with the nuts and bolts. Tighten the nuts to 166 ft. lbs. (226 Nm).
  11. The remainder of installation is the reverse of removal. Tighten each component to specifications.
  12. Bleed the brake lines as described in Section 9.
1989-96 Models
  1. On the 4-door sedan, remove the package tray and vent duct. On 1992-96 models, it will be necessary to remove the rear seat back.
  2. On the hatchback, remove the speaker grilles.
  3. On the wagon models remove the tonnue cover and rear seat back.
  4. Loosen the rear wheel lug nuts, raise the rear of the vehicle and support it safely. Block the front wheels.
  5. Remove the rear wheels.
  6. Disconnect the brake hose and the ABS speed sensor from the shock absorber.
  7. If equipped with ABS, disconnect the Load Sensing Proportioning Valve (LSPV) spring from the lower arm.
  8. Disconnect the stabilizer bar link from the shock absorber.
  9. Support the rear axle and loosen the 2 bolts from the lower end of the shock absorber.
  10. From inside the vehicle, unbolt the upper support. Fig. 1: A rubber cap covers the rear shock absorber tower nut 89558p01.jpg
    Fig. 2: The upper shock absorber tower is retained by the center nut (circled) and three surrounding nuts 89558p02.jpg
  11. Lower the rear axle carrier and remove the two bolts.
  12. Remove the shock absorber from the vehicle. To install:
  13. Install the shock absorber assembly onto the vehicle.
  14. Connect the brake hose and the ABS speed sensor to the shock absorber.
  15. Connect the stabilizer bar link to the shock absorber.
  16. Install the wheel and tire assembly.
  17. During installation, please observe the following tighten specifications:
    1. Tighten the shock absorber-to-body bolts to 29 ft. lbs. (39 Nm).
    2. Tighten the shock absorber-to-axle carrier nuts to 166 ft. lbs. (226 Nm) on 1988-91 vehicles and 188 ft. lbs. (255 Nm) on 1992-96 vehicles.
    3. Tighten the suspension support-to-shock absorber nut to 36 ft. lbs. (49 Nm) on 1988-91 vehicles. On 1992-96 models, tighten the stabilizer bar link to shock absorber retainers to 47 ft. lbs. (64 Nm).
  18. Install the rear seat back, vent duct and the package tray as required.
Dec 18, 2010 | 1986 Toyota Camry
How do you replace shocks on 1991 buick skylark
REMOVAL & INSTALLATION Fig. 1: After you open the trunk lid, use a suitable prytool to remove the trim cover 86888036.jpg
Fig. 2: Some vehicles have a cover which must be removed to access the shock retaining nuts 86888037.jpg
Fig. 3: Unfasten the upper shock attaching nuts 86888038.jpg
  1. Disconnect the negative battery cable.
  2. Open the trunk lid and remove the trim cover. If equipped, remove the nut cover.
  3. Remove the upper shock attaching nut(s). If removing both shocks, remove one at a time.
  4. Raise and safely support the vehicle.
  5. Unfasten the lower shock absorber mounting bolts. One wrench will have to be placed on the bolt head side to retain the bolt as you loosen the nut. Usually a 15mm wrench is used to remove them. To install: Fig. 4: After the vehicle is raised and safely supported, use a socket to unfasten the lower retaining bolt 86888039.jpg
    Fig. 5: Remove the retaining bolt, then . . . 86888040.jpg
    Fig. 6: . . . remove the shock absorber assembly from the vehicle 86888041.jpg
  6. Connect the shock absorbers at the lower attachment and install the attaching bolt.
  7. Lower the vehicle enough to guide the shock absorber upper stud through the body opening, then fasten the upper shock absorber attaching nut loosely. Tighten the lower shock absorber mounting bolt to 35 ft. lbs. (47 Nm).
  8. Remove the axle support, then carefully lower the vehicle. Tighten the shock absorber upper nut to 21 ft. lbs. (29 Nm).
  9. If equipped, install the retaining nut cover, then install the rear trim cover. Close the trunk lid.
  10. Connect the negative battery cable.
Oct 08, 2010 | Buick Skylark Cars & Trucks
Need new struts on rear, Would like to replace with air shocks. Any suggestions on how I would do this?
Shock Absorber -The rear already has air shocks on the 1999 Cadillac Deville: REMOVAL & INSTALLATION Rear
  1. Before servicing the vehicle, refer to the precautions in the beginning of this section.
  2. Remove or disconnect the following:
    • Rear wheel Fig. 1: Exploded view of the rear shock absorber mounting 9300vg06.gif
    • Negative battery cable
    • Shock absorber electrical connector from the rear suspension support, If equipped
  3. Support the lower control arm with a jack to relieve the tension on the shock absorber.
  4. Remove or disconnect the following:
    • Lower shock absorber mounting bolt and nut
    • Upper mounting nut, retainer, and insulator
    • Shock absorber compress by hand and remove through the upper control arm
    To install:
  5. Position the top of the shock absorber with the insulator attached into the suspension support.
  6. Install or connect the following:
    • Upper shock insulator, retainer and nut. Torque the nut to 55 ft. lbs. (74 Nm).
    • Shock absorber lower mounting nut/bolt. Torque the nut to 75 ft. lbs. (102 Nm).
    • Shock absorber electrical connector to the rear suspension support, if equipped
    • Rear wheel
Jul 29, 2010 | 1999 Cadillac DeVille
How to change 2007 dodge 1500 front struts?
Removal & Installation Independent Front Suspension – 2WD Vehicles To Remove:
  1. Before servicing the vehicle, refer to the precautions at the beginning of this section.
  2. Safely raise and support the vehicle.
  3. Support the lower control arm outboard end.
    • Upper shock absorber nut, retainer and grommet
    • Lower nuts and shock absorber
To Install:
  1. Install or connect the following:
    • Lower retainer and grommet on the shock absorber stud and insert shock absorber through frame bracket hole
    • Lower nuts
      1. Torque to: 25 ft. lbs. (34 Nm)
    • Upper grommet, retainer and new nut (or existing nut with Mopar Lock N Seal or Loctiti 242) on the shock absorber stud
      1. Torque to: 40 ft. lbs. (54 Nm)
  2. Remove support from lower control arm outboard end.
  3. Lower the vehicle.
Independent Front Suspension – 4WD Vehicles To Remove:
  3. Remove tire and wheel assembly.
  4. Support the lower control arm outboard end.
  5. Remove or disconnect the following: dod_ram15_02-04_4wd_shock.gif
    • Upper shock nut with insulator and retainer
    • Lower shock bolt
    • Shock absorber
To Install:
    • Upper part of shock absorber into frame bracket with insulators and retainers and nut
    • Lower part of shock absorber into lower control arm with the bolt
      1. Torque to: 100 ft. lbs. (135 Nm)
  2. Remove support from lower control arm.
  3. Install tire and wheel assembly.
  4. Lower the vehicle.
Link/Coil Front Suspension To Remove:
    • Nut, retainer, and grommet from upper stud in engine compartment dod_ram15_02-04_shock.gif
    • Nuts from upper shock bracket
  3. Lower bolt from axle bracket and shock absorber from engine compartment
To Install:
  1. Position lower retainer and grommet on upper stud and insert the shock through the spring from the engine compartment.
  2. Install or connect the following:
    • Lower bolt
    • Upper shock bracket and nuts
      1. Torque to: 55 ft. lbs. (75 Nm)
    • Upper grommet, retainer and upper shock absorber nut
      1. Torque to: 35 ft. lbs. (47 Nm)
Jul 22, 2010 | 2007 Dodge Ram Truck
Replacing the rear shock in a 1993 Cadillac Sevile and the top nut is rusted on. Any advice to get the nut off?
This is a very horrible problem, at least for me. The last time that this happened to me, I decided to cut the top of the shock absorber, since the nut was frozen in place, and you don't have a lot of space to work in there with some special sockets. So I would advice you to cut the very top of the shock absorber rod.
May 16, 2010 | 1993 Cadillac Seville
How to replace shock absorber on a 1200 Sportster 2007
Simply remove the nut from the top stud and the bolt at the bottom and remove the shock absorber. Now, if you're talking about replace the shock dampening unit inside the shock absorber assembly, you need a shock compression tool. You put the shock in the tool and compress it far enough to remove the "lock" at the top of the shock. Then you can remover the spring and other external parts. Reassemble the shock parts, compress the assembly,and reinstall the lock.
Apr 09, 2010 | 2006 Harley Davidson FXDBI Street Bob
Do i have to remove the back seat to take rear struts off
Answer
REMOVAL - SHOCK ASSEMBLY
NOTE: Access for the nuts attaching the rear shock assembly upper mount to the vehicle is through the inside of the trunk.
Roll back carpeting on top of the rear shock tower to access shock mounting nuts.
Remove plastic cover from the top of the shock assembly.
Remove 2 nuts attaching the shock assembly upper mount/spring seat to the shock tower.
Raise vehicle on jackstands or centered on a frame contact type hoist. (Refer to LUBRICATION & MAINTENANCE/HOISTING - STANDARD PROCEDURE)
Remove the rear wheel and tire assembly from the vehicle.
Remove two fasteners holding the splash shield to the shock assembly upper mount.
Remove bolt attaching shock absorber to rear knuckle (Shock Absorber Attachment To Knuckle).
Remove the shock absorber from the rear knuckle first when removing the shock absorber from vehicle by pushing down on the rear suspension.
Move shock assembly downward and tilt top of shock outward, then remove shock assembly from vehicle through top of wheel opening
Nov 23, 2009 | 2002 Dodge Stratus
I need step by step instructions to replace front struts.
1.Turn ignition to OFF position to place steering column in unlocked position.
2.Remove hub nut
3.Loosen, but do not remove, three top mount-to-shock tower
4.Raise vehicle on a hoist.
5.Remove tire and wheel assembly
6.Move brake caliper and wire out of the way
7.Remove brake rotor
8.Remove cotter pin from tie rod end stud and remove slotted nut.
Discard cotter pin and nut
9.remove tie rod from knuckle
10.Remove stabilizer bar link nut, and remove link from strut
11.Remove and discard lower arm-to-steering knuckle pinch bolt and nut. (A drift punch may be used to remove bolt.) Using a screwdriver, slightly spread knuckle-to-lower arm pinch joint and remove lower arm from steering knuckle.
12.Press halfshaft from hub
13.Remove shock absorber strut-to-steering knuckle pinch bolt. Using a large screwdriver, slightly spread knuckle-to-strut pinch joint, if required, for removal
14.Remove steering knuckle and hub assembly from shock absorber strut
15.Remove three top mount-to-shock tower nuts and remove strut and spring assembly from vehicle
16.Compress spring with Spring Compressor
17.Place 10mm box-end wrench on top of shock strut shaft and hold while removing top shaft retaining nut with a 21mm 6-point crow foot wrench and ratchet
18.Loosen Spring Compressor , then remove top mount bracket assembly, bearing plate assembly and spring.
INSTALLATION
1.Place a 10mm box-end wrench on top of shock strut shaft and hold while tightening top shaft retaining nut with a 21mm 6-point crow foot wrench and ratchet to 53-72 Nm (40-53 lb-ft).
2.Install strut and spring assembly and three top mount-to-shock tower nuts
3.Install steering knuckle and hub assembly to shock absorber strut.
4.Install a new shock absorber strut-to-steering knuckle pinch bolt. Tighten to 98-132 Nm (73-97 lb-ft).
5.Install halfshaft into hub
6.Install lower arm to steering knuckle ensuring that ball stud groove is properly positioned and boot seal is not damaged. Install a new pinch bolt and nut. Tighten to 53-72 Nm (40-53 lb-ft).
7.Install stabilizer bar link to strut and install a new stabilizer bar link nut. Tighten to 77-103 Nm (57-75 lb-ft).
8.Install tie rod end onto knuckle.
9.Install a new tie rod end slotted nut. Tighten to 31-47Nm (23-34 lb-ft).
10.Install a new slotted nut retaining cotter pin.
11.Install brake rotor
12.Install brake caliper
13.Install tire and wheel assembly
14.Tighten three top mount-to-shock tower nuts to 30-40Nm (23-29 lb-ft).
15.Lower vehicle and tighten hub nut to 230-275 Nm (170-202 lb-ft)
16.Depress brake pedal several times prior to moving vehicle.
Hope this helps. Good luck !
Mar 14, 2009 | 1992 Ford Taurus
Shocks
rear
5955ba5.gif ------------------------------------------------------------------------------------------
front
Removal
  1. Remove front shock absorber-to-upper shock bracket nut and bolt.
  1. Disconnect the lower end of the front shock absorber bolt and nut from the U-bolt plate.
  1. Compress the front shock absorber and remove.
Installation
  1. Insert front shock absorber into the front shock absorber mounting bracket (18183). Insert bolt and tighten nut to 60-81 Nm (45-60 lb-ft).
  1. Attach the lower end of the front shock absorber to the U-bolt plate by installing the nut and bolt. Tighten to 60-81 Nm (45-60 lb-ft).
front
Feb 04, 2009 | 1996 Ford F350 Crew Cab
2004 dodge stratus SE
This is a dangerous job if you do not have the proper equipment for compressing the spring that is around the rear shock. I do not recomend performing this job without the proper equipment. Unloading the spring without it compressed can cuase injury.
If you have the proper equipment this is how you do it.
REMOVAL - SHOCK ASSEMBLY NOTE: Access for the nuts attaching the rear shock assembly upper mount to the vehicle is through the inside of the trunk.
  1. Roll back carpeting on top of the rear shock tower to access shock mounting nuts.
  2. Remove plastic cover from the top of the shock assembly.
  3. Remove 2 nuts attaching the shock assembly upper mount/spring seat to the shock tower.
  4. Raise vehicle on jackstands or centered on a frame contact type hoist.
  5. Remove the rear wheel and tire assembly from the vehicle.
  6. Remove two fasteners holding the splash shield to the shock assembly upper mount.
  7. Remove bolt attaching shock absorber to rear knuckle
  8. Remove the shock absorber from the rear knuckle first when removing the shock absorber from vehicle by pushing down on the rear suspension.
  9. Move shock assembly downward and tilt top of shock outward, then remove shock assembly from vehicle through top of wheel opening.
Aug 04, 2008 | 2004 Dodge Neon
Skque SHOCK ABSORBING CASE FOR 2.5 EXTERNAL HARDRIVE Logo
24 people viewed this question
Top Skque Computers & Internet Experts
David Payne
David Payne
Are you a Skque Computer and Internet Expert? Answer questions, earn points and help others
