No sound on TV when using HDMI cable picture ok Zoostorm laptop
  • 3 Answers
Zoostorm laptop model????
Tv model????
I think that is a problem of driver or the type of hdmi, what can you recommend to do an update on both the video driver and sound driver of laptop. but please give me laptop and tv type as you can give more information.
Posted on Jul 30, 2013
  • 36 Answers
SOURCE: how to hook up a hp pavilion laptop to a hdtv
if it worked fine at some point then it should work fine now... i use hdmi to hdmi from my laptop to tv all the time dvi would only cause quality loss.
the first thing i would try would be to change your resolution on your laptop to a couple different settings. a lot of times, if its not set to one thats compatible with your tv, you won't see anything.
if that doesn't work, go to personalization and open the tab that says "connect an external display" and toy around with it. but yeah it doesn't sound like you have any hardware problems there.
hope this helps
Posted on Jan 16, 2009
SOURCE: cant get sound via hdmi connection from acer 6920g laptop
go into control pannel and acer hd set it there and also in sound, a wee bit of trial and error but its there. mine was the same, it cost me ouch on the phone! good luck mine works ok
Posted on Jan 19, 2009
SOURCE: no picture connecting laptop to LCD TV both Toshiba
Try the fn key and the monitor key (f4?)at the same time to activate external monitor
Posted on Feb 17, 2009
Crankstart
  • 696 Answers
SOURCE: HDMI cable from laptop to TV; picture on TV sound on laptop.
Sounds like you may have just had either a settings change when installing or adjusting one of your other media programs that has stopped it from working the way it should or, may have just got some automatic updates either from HP or Microsoft that forced a similar change.
The reason the sound isn't going through the HDMI is likely that the laptops soundcard is stuck on the speakers setting and needs to be switched back to digital.
For the moment, try opening your start menu, then control panel. If it's not in classic mode you can switch it by clicking the classic mode link in the top left of the window. Scroll down to the sound icon and double click it. You should have 2 or more icons in the middle. If the one that's called "Speakers" has a green check mark that means its set to use the laptops built in speakers. If this is the case to switch to the digital output on the HDMI simply put your mouse on the digital icon, right click it and set it to default.
If this only corrects the problem to the point where it now work on the tv but won't switch back then you likely had a windows update change something, if this doesn't work at all or if you no longer see the Digital icon then it likely means something in your Video driver may have been damaged(or just changed) due to an update. This is because the adiou out in the HDMI is actually coming from your video card.
Either way you can try two things to fix it. First go into start menu, All Programs, Recovery Manager if it's a single Icon just click it if there are 3+ look for the one about applications and drivers and click that. The recovery manager will ask what you want to do more than once say no or next until the "Application & driver" option presents itself then take that option. This will allow you to change both your sound and video drivers back to factory.
It will ask you Applications OR Drivers, select drivers then follow the prompts to find your sound card driver. Re-install the factory driver and then restart the laptop. If it Works you're done. If not repeat the previous sections but re-install the video card driver and restart then test again.
If that doesn't work drop me a comment here and I can give you a few more pointers
Posted on Apr 25, 2009
  • 55 Answers
SOURCE: can't view laptop display on panasonic plasma using hdmi cable
If you are using windows, try going to the screen resolution page(right click desktop and click properties and then click the last tab for xp, or right click desktop and click personalize and then screen resolution. There you should see two black rectangles. Click the second one(he one that's grayed out) and set a resolution in the dropdown menu. Then the tv should show your computer screen. You can also fool around with the resolutions. Good luck!
Posted on Sep 13, 2009
My Iomega mx mobile mass storage player has stopped sending signal through HDMI cable to TV all other functions are ok. HDMI cable changed still no picture
You need to try some tests.
  • Does the same cable work with any other TVs
  • Do any other devices work on your existing TV ?
You also need to check that you have set the output of your device to HDMI and the input of the TV to HDMI. In the past the TV may have automatically selected HDMI when the device is turned on but sometimes that does not work.
Mar 23, 2014 | Iomega Computers & Internet
I tried hooking up my laptop to my 37lh20 tv. I connected the avi to the pc input and an audio cable fro the headset jack on the tv. If I put the tv input on rgb pc I get the picture but no sound and if...
Unless you hook HDMI to HDMI, you won't carry sound across the HDMI cable. If you're using a VGA to HDMI converter, you'll get the picture but no sound.
I have a feeling the headset jack on the TV is an output rather than an input. Most TVs accept HDMI, RCA, or a digital audio input (either coaxial or optical). Unless you have a S/PDIF optical output from your laptop (and you obviously don't have an HDMI output), then your only other choice is likely to get a cable that splits a 1/8" headset type connector into two RCA plugs that you'll plug into an AUDIO IN input on your TV.
Jul 14, 2011 | LG 37LH20 37 in. LCD HDTV
Connecting my laptop to my sansui 42" lcd tv via the hdmi cable, i get clear picture but no sound
Does your laptop feed sound through the HDMI connection? You may have to use the HDMI 1 jack on the HDLCD3200. Change the HDMI setting in the audio menu on the tv to DVI and run a seperate audio cord from the laptop to tv. I hope this is helpful
May 17, 2011 | Sansui HDLCD3200 TV
No sound, picture ok, volume nil
What cable u are using?Like a RCA AV component cable or a HDMI cable?Tries another AV holes in the tv,if use a HDMI cable tries another HDMI hub on the tv.Or replaced with it the new RCA AV component cable or a HDMI cable.
Feb 10, 2011 | Bush DVD2038 DVD Player
No picture being displayed when using hdmi input. sound is working but no picture
If tv otherwise ok then suspect hdmi cable fault, but are you sure you are on the correct hdmi input. Your tv may have more than one hdmi socket.
pete
Nov 08, 2010 | Televison & Video
Trying to watch blue-ray using samsung 540 tv, but not getting any sound. We're able to watch the blue-ray on the laptop, but when we try to connect it to the tv, the sound does not work. The trails have...
Are you using an HDMI cable to connect the Laptop to the samsung 540 tv If you are not then try using an HDMI cable, you will get the sound and a better picture
Jan 30, 2010 | HP Pavilion dv5tse Notebook
No Picture on HDMI using Philips DVP5992.
You can try out by connecting the CVBS (Yello) out from player to TV and connect HDMI out from Player to TV. Goto CVBS input on Sony TV. Select set up and you should get the HDMI Video options availble. Try to change the resulution and check for Video on HDMI source.
Which disc you were playing PAL or NTSC? PAL should work for Europe.
Feb 08, 2009 | Philips DVP5990 DVD Player
Cant get sound via hdmi connection from acer 6920g laptop
Jan 19, 2009 | Acer Aspire 6920 Notebook PC
Rca hdtv m50wh754s
You need a audio cable for sound. HDMI cable is only for picture. I use the comp 1 plugs myself, better picture. I found with my TV that the HDMI cable is only good if you have a digital box for it. You can also use the plug to hook your computer to off your graphics card and watch downloaded movies on.
Oct 06, 2007 | RCA HD52W56 52" Rear Projection HDTV
Computers & Internet Logo
95 people viewed this question
David Payne
David Payne
