Need to repair a Roland PSB 13u switching adapter used on a Roland BA330 Amplifier.
Replacing ac power adapter.
If the polarity, voltage, and amperage are the same, there is no reason that you cannot use this device as an alternate.
Oct 16, 2016 | Roland Music
Where is the fuse for the roland kc 500????
The fuses are located within the amplifier, you will need to carefully disassemble the amp chassis from the cabinet to access the fuse....
Feb 27, 2015 | Roland KC-550 Keyboard Amplifier
How to fix roland js-8 eband plug it in and shorted out help
I would need a little more detailed description of the issue however I assume you plugged in the power AC adapter and "it shorted out" the Roland unit. did you use the correct AC adapter? Many time the original unit is lost and an alternate is used which is not of the same configuration. Let me know.
Dec 23, 2013 | Music
Analog test eror onroland td5
I have the same problem with my module and I can\'t find the solution anyware for the thing.Closest solution that I could find is something about Roland power adapter.Apparently module won\'t work with any adapter with the same voltage,only Roland or Boss B.R.A. adapters works.I have original Roland adapter and still shows an Analog test error.
Have you find the solution in meantime by any chance?
Sep 09, 2012 | Roland Music
Roland micro cube fuse replacement
If the fuse blew, it is for a reason requiring repair. Troubleshoot and use a 40 watt lamp in series to limit current until cause of fuse blowing is found and repaired.
Jul 14, 2011 | Roland Microcube Guitar Amplifier
My adapter or plug is broke and i need a new one. last night i used an adapter from the br-800 and it worked except that when i used the cd option the screen would flicker then it would shut off?
Sounds like the adapter for the 800 isn't quite up to delivering the required current, If it is a standard barrel plug type, you should be able to get a low cost replacement from a local electronics store like Jaycar (Australia) or Radio shack (america) to name a few examples. If possible, take the failed adapter from the 900 in with you when you go to get a replacement as this will help the staff get you the right adapter.
Alternatively you could try ordering one from roland, but that would be a much more pricey venture.
Here is the support site for roland products, it will give you an idea of how to go about having your adapter repaired or replaced.
http://www.rolandus.com/support/?tab=service_repair
Apr 05, 2011 | Roland BR900CD Digital Multitrack Recorder
I need to replace the power push button, but do not know what part number it is. Trying to get it ordered through Mouser, but there are too many listed. All I know is that it's an Alps switch, and it reads...
HI,
I've just had a Roland Micro Cube amplifier in for repair and it uses the same type of Alps switch you mention. ( It's also broken )
This is a simple single-pole latching push-button switch, so electrically, almost anything rated for an amp will be good enough.
Alps no longer make the same part, so you'll need to find something which looks the same and fits the original hole.
My repair is easier, because the replacement part doesn't have to match anything.
Graham.
Jan 27, 2011 | Roland CM30 CUBE Monitor Speaker PA...
The unit is in excellent shape, not used much and has been kept in the oringinal box. I got it out today and the power won't come on? I put brand new batteries in it and still no power. It has been...
Check for corrosion on battery contacts. If this unit can use an AC adapter, often the switch contact in the power plug that connects the batteries when adapter is removed gets bent and fails to connect the batteries.
Dec 19, 2010 | Roland Boss Dr670 Dr Rhythm W Bass Sounds
MMP2 seems to have no voltage selector. Manual states power as 230, 240, 110v. I am reluctant to plug my US 110v unit into UK 230v mains. Would appreciate any info?
Check the manual..It's on the Roland site
In that unit , it's most likely an auto-switching power supply ie; universal 105 - 230 volts AC 50-60 hz
Aug 07, 2010 | Roland MMP-2 2-Channel Amplifier
Computers & Internet Logo
156 people viewed this question
David Payne
David Payne
