Question about Car Audio & Video
I have a 2003 Hyundai elantra and the power steering bet is not moveing when the car is running.... I have the alternator belt off could that be the problem?
    Problem Solver:
  • 15 Answers
Yep needs belt. You entered your problem under wrong heading
Posted on Aug 07, 2013
How many belts on a 2002 hyundai elantra gt?
You should be able to see the power steering unit, it has a pulley on the front and a cap for putting in fluid, if the pulley is empty belt is gone, check fluid in reservoir if belt is there.
Jun 11, 2017 | Hyundai Cars & Trucks
How do i change poer assist belt on hyundai coupe 2.0ltr 2001?
Check the attached links,similar models to yours power steering belt replace.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How To Install Replace Power Steering Belt 2001 06 Hyundai Elantra
Accessory Drive Belts Replacement 2001 Hyundai Accent
How To Install replace Alternator Belt 1999 06 Hyundai Elantra 2 0L
Mar 10, 2016 | Hyundai Cars & Trucks
How do I adjust the tension on the alternator belt for my 2003 Hyundai Tiburon?
Adjusting alternator belt tension - bolt & pivot bracket design ...
? 13:06
https://www.youtube.com/watch?v=8JN0RtZk_2Y
Nov 26, 2012 - Uploaded by backyardmech
Releasing tension on the alternator belt to remove the alternator- 4 cylinder Honda in this video. ... How to ...
How To Install replace Alternator Belt 1999-06 Hyundai ...
? 4:51
https://www.youtube.com/watch?v=6IWgXTijclo
May 15, 2013 - Uploaded by 1A Auto Parts
How To Install replace Alternator Belt 1999-06 Hyundai Elantra 2.0L .... Adjusting alternator belt tension ...
Dec 21, 2015 | 2003 Hyundai Tiburon
Hyundai elantra 2.0HVT drive belt diagram
if you mean the belt that drives the alternator /water pump/power steering pump etc the adjustment for the belt is at the idler pulley. loosen off the nut holding on the pulley and behind the pulley ther should be a long threaded bolt that moves the pulley up or down. When finished retension the idler pulley nut
Jan 19, 2013 | Cars & Trucks
My car is overheating and the power steering isn't working I noticed my belt I think its the the Water pump drive belt the pulley closest to the front of the car is loose, in turn making the belt loose,...
Yes, the serpentine belt runs all those pumps. Water , power steering, alternator ,ect. If its loose have the tensioner and belt checked out and replaced.
Mar 08, 2011 | 2001 Hyundai Elantra
Whats a difference between timing belt and drive belt , for my 2004 Elantra Hyundai cernter is asking to change the drive belt and flush the Hyd oil, car has 53,000 miles on it
a drive belt refers to belt driven items like alternator, power steering, water pumps and the like.
A timing belt is cogged to precicely hold the relationship between the crankshaft and the valve train. Timing belts are usually located within covers, as the loss or damage to this belt exposes engine damage and failure.
May 22, 2010 | 2004 Hyundai Elantra
Power steering pump--2001 hyundai elantra
If it's not a serpetine belt, max deflection of 3/4" on longest segment should be safe,  don't make alternator belt tight as a drum or you will burn out alternator bearings quickly.  If it has serpentine belt, the spring tensioner should keep the belt properly tensioned unless it's worn out.
It only needs to be tight enough to not slip, too loose will squeal and you will have to tighten,  to tight will kill alternator and you will spend $$.
Oct 08, 2008 | 2001 Hyundai Elantra
Car Audio & Video Logo
26 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
