Question about Exercise & Fitness
T6i speed problem - Exercise & Fitness
    Top Expert:
  • 12,223 Answers
PleaSE Run the software calibration for fix it. Go under the HOOD cover and see the steps for s.calibration.
God bless you
Posted on Jul 31, 2013
In program mode why can't I program shift on my t6i. I turn the main dial and nothing is there.
You need to be in the creative modes e.g. Av, Tv etc. Functionality in program mode is limited
Nov 03, 2016 | Canon EOS T6i DSLR Camera with EF-S...
9.31 precor error 26 and loud noise
Precor Error Code 26 Error Code: 26 Manufacturer: Precor
Model: All Models
Error Description: Error 26, Motor Pulse Width Incorrect - Observation of the speed sensor signal and verification the signal from the speed sensor is appropriate for the requested speed. If an incorrect or erratic speed sensor signal is detected the error appears. Possible Reason:
  1. The line of sight between the speed sensor and the speed sensor target is obstructed.
  2. Incorrect gap between the speed sensor and the speed sensor target.
  3. Incorrect adjustment of the speed sensor potentiometer (when equipped).
  4. Damaged speed sensor target.
Recommended Action:
  1. Using a static safe vacuum cleaner, carefully vacuum out the drive motor compartment. Be sure to thoroughly clean the area between the speed sensor and the speed sensor target.
  2. Inspect the gap of the speed sensor to the speed sensor target. Proper gap is 3/16" and the speed sensor photo eye should be aimed at the larger portion of the targets wedge shaped section. If unit has a magnetic speed sensor, the gap between the end of the sensor and the flywheel tooth needs to be 3/16".
  3. Locate the speed sensor potentiometer (when equipped) on the lower PCA. Set the speed sensor potentiometer to mid-range. Start the treadmill and increase speed to 6 mph. Carefully adjust the speed sensor potentiometer until the treadmill is operating the smoothest. Increase the speed to full speed and again adjust the speed sensor potentiometer until the treadmill is operating the smoothest. These two adjustments are typically small and are generally only a matter of fine tuning.
  4. Inspect the speed sensor target for any scratches or tears that could cause incorrect readings. Replace the speed sensor target if
Jan 25, 2014 | Dmm Vision Fitness T9500 Treadmill
Precor treadmill err26
Model: All Models
Recommended Action:
  4. Inspect the speed sensor target for any scratches or tears that could cause incorrect readings. Replace the speed sensor target if necessary.
Dec 16, 2013 | Exercise & Fitness
My t6i treadmill speed up and down continuosly
please Run the software calibration for easy diagnostic and fix it.
Go under the HOOD cover motor, and follow the steps .
God bless you
Jul 30, 2013 | Exercise & Fitness
Precor 9.45 err 26
Model: All Models
Recommended Action:
Feb 04, 2013 | Precor Exercise & Fitness
Speed error 26
Model: All Models
Recommended Action:
May 18, 2011 | Precor 923 LowImpact Treadmill
What does Err26 mean?
Model: All Models
Recommended Action:
Jan 20, 2011 | Precor C956 Treadmill with Cardio Theater...
What is an Error 22, 23,and 26 on a precor 9.35?
Error 22 indicates that the drive motor (running belt) has been instructed to start, by either manual or program control, and the monitoring system has not received any response from the speed sensing system indicating that the drive motor has started.
Error 23 indicates that the speed sensor signal was lost while the treadmill was in operation
Error 26 this error monitors the speed sensor signal and verifies the the speed sensor signal is appropriate for the requested speed. If the speed sensor signal is incorrect or erratic an Error 26 will be displayed.
Unplug unit and remove motor shroud and try these procedures:
The treadmill utilizes an optical (infrared) speed sensor and the line of sight between the speed sensor and the speed sensor target is obstructed. The speed sensor position relative to the speed sensor target is incorrect. The speed sensor potentiometer adjustment is incorrect (when equipped). The speed sensor target is damaged
Carefully, vacuum out the drive motor compartment with a static safe vacuum cleaner. Pay special attention to the area between the speed sensor and speed sensor target. Adjust the speed sensor position so that the space between the speed sensor and the speed sensor target is 3/16 inch and so that the speed sensor photo eye is aimed at the larger portion of the targets wedge shaped section. On hall effect speed sensors (magnetic sensor) the space between the end of the speed sensor and the flywheel tooth should be 3/16 inch. If the treadmill utilizes a speed sensor potentiometer, locate the speed sensor potentiometer on the lower PCA. Set the speed sensor potentiometer at mid-range. Start the treadmill and increase the speed to 6 mile per hour. Carefully adjust the speed sensor potentiometer to the point where the treadmill is operating the smoothest. Increase the treadmills speed to full speed at repeat the previous adjustment. These two adjustments are typically small and are usually only a matter of fine tuning. . Most speed sensor targets consist of a circular arrangement of alternate black and silver sections. If the speed sensor target is torn or badly scratched the speed sensor may receive an incorrect reading. Replace the speed sensor target.
Jun 25, 2010 | Precor 935 Premium Series Treadmill
No Power To Console
treadmill will not start
Dec 16, 2008 | Endurance TF6iHRC Treadmill
Exercise & Fitness Logo
18 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
