Question about Teac Audio Players & Recorders
My teac MA-7 amplifier makes a very loud bang (rather a very loud clicking noise) a few seconds after I turn it on, and then every 5 minutes or so. Even with volume all the way down, even with no inputs plugged in. The protection turns itself on but it's always too late for the poor speakers. It does thing on both channels simultaneously always. Recently one channel got fried after one of these loud pops. Please help?
  • Teac Master
  • 5,259 Answers
All I can tell you is that if the noise is on both channels the cause of it has to be something that is both channels running to it or is something to do with the power supply. If the main amp channels are outputted by one device I would blame it on that. But if they are separate you will need to look elsewhere.
Posted on Aug 19, 2013
SOURCE: Output volume has dropped in right channel
dear sir,pls check the HT voltage fuse, LTsupplay also and out put stage,and volume controle,
Posted on Feb 01, 2007
robotek
  • 1512 Answers
SOURCE: Protect Mode With Sony str-de595
Hi snark63
Ypou have an intermittent problem that sounds to be heat related... the more work the amp does, the more heat generated by the output stages. This will be aggravating some poor solder joints that are cracked or dry. The unit needs some repair work done in these areas. If you have good experience with a soldering iron, the cure for this is to resolder the power stages of the unit, or any other solder joints that look to be failing.
I am more than happy to answer any other questions you may have about it, please get back to me here, or use the ASK function to go straight to me :) If you are still unsure, have problems, or we need to look at the situation more deeply, then before you give a rating for this advice, hit the ASK button Thanks for using FixYa, If you consider the advice I have given you as sound, a FixYa rating is a great reward for my efforts to help you. Cheers.
regards robotek
Posted on Jul 06, 2008
petraman7
  • 1175 Answers
SOURCE: Yamaha AX-930 Audio Amplifier
HI...
Do a websearch for a competent repair shop in your region or ask the stereo folks where you got the amp.
It WILL need surgery.
Cheers,
Scott
Posted on Jan 03, 2009
petraman7
  • 1175 Answers
SOURCE: Adcom 7500, Adcom 5400(bi-amp), Marantz AV-9000, Dakiom HA103
Try just the power amp on ..nothing connected
no Dakiom thingy either. It's a matter of elimination. Start at the output device and work back. Keep the Dakiom out of the loop.
If there's hum with just the Adcom..then it's the ADCOM
Posted on Mar 25, 2009
StuartB
  • 807 Answers
SOURCE: crackling noise with my volume knob when i turn the volume
It's probably dust in the volume control. It gets in between the carbon track and the wiper that rotates on the track, or the resistive / carbon track inside the control is wearing out. As yours is stereo there will be 2 tracks and 2 wipers, one could be worn more than the other.
This should give you an idea. Inside Pot
Posted on May 06, 2012
I just had a new COZY L.P. GAS CDV336C installed... Every few minutes it makes a loud bang noise...It then makes pinging noises that gradually fade out...This happens 2-4 times every hour. The bang is loud...
Hi Loretta:
I'd contact the installer. This sounds as if there may be a slow leak. When the gas concentration is high enough it will ignite which would be the bang that you hear. The popping sound could be the flame at the leak source point re-igniting for a few times.
DEFINITELY CONTACT YOUR INSTALLER OR GAS INSPECTOR. THIS IS A SAFETY HAZARD.
Mar 11, 2015 | Dryers
Mod: kuds30ixss6 - Making a loud noise
You are going to have to remove the spray bars and the filter at the top of the pump housing to see if something is stuck in the pump
Jan 06, 2014 | KitchenAid Dishwashers
Loud popping noise
Check the filter caps on power supply
May 16, 2013 | Audio Players & Recorders
My dryer is making a loud banging noise a few minutes into the cycle
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Sep 05, 2010 | Whirlpool WED5100VQ Electric Dryer
Loud clicking, banging noise
We recently had the same problem. After cleaning both the furnace filter and the humidifier water panel, the clicking noise (electric air filter) and the loud bang went away.
Nov 30, 2008 | Aprilaire 550 Humidifier
Dryer making loud and louder noise after about 5 minutes of use
my dryer started making a very loud banging noise when I turned it on. It heats up and the drum turns, but I am afraid to use it.
Apr 22, 2008 | Kenmore Dryers
Panasonic TV Turned it self off, humming speakers, loud bang & Burning Smell
hi there, you do have a big problem at your tv, the loud bang means a part is broken, maybe you will cost 50 % of the original price of your tv. ty
Dec 26, 2007 | Televison & Video
TEAC Amp
The amp is going into "protect mode". This means there is a bad part or parts being detected. Professional service will be needed.
Sep 13, 2007 | Teac A-1D 2-Channel Amplifier
167 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
